[MPICH] Can't compile against mpich2 with visual c++ 6
David Ashton
ashton at mcs.anl.gov
Wed Aug 24 16:57:19 CDT 2005
imalone,
I apologize for using you to test our unreleased code. We fixed the problem
and this time I used VC 6 to check that the fix works. Attached is the new
mpicxx.h.
If you don't use C++ you can define MPICH_SKIP_MPICXX and when you do you
can define HAVE_NO_VARIABLE_RETURN_TYPE_SUPPORT before including mpi.h.
FYI, VC++ .NET 2003 is able to compile mpicxx.h as is.
-David Ashton
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Ian Malone
Sent: Wednesday, August 24, 2005 6:31 AM
Subject: Re: [MPICH] Can't compile against mpich2 with visual c++ 6
Thanks for your help. I'm now down to 2 errors, 2 warnings, both
about MPI::Comm::Clone(void) not being defined:
C:\PROGRAM FILES\MPICH2\INCLUDE\mpicxx.h(1390) : error C2259: 'Comm' :
cannot instantiate abstract class due to following members:
C:\PROGRAM FILES\MPICH2\INCLUDE\mpicxx.h(1033) : see
declaration of 'Comm'
C:\PROGRAM FILES\MPICH2\INCLUDE\mpicxx.h(1390) : warning C4259: 'class
MPI::Comm &__thiscall MPI::Comm::Clone(void) const' : pure virtual
function was not defined
C:\PROGRAM FILES\MPICH2\INCLUDE\mpicxx.h(1350) : see
declaration of 'Clone'
(At the compile stage, not linking)
Which seems a bit tangled. At the moment I can just use
#define MPICH_SKIP_MPICXX because I'm using C style bindings,
but if you want me try anything further I'd be happy to.
David Ashton wrote:
> imalone,
> We've added support for compilers that cannot handle the Clone functions
> correctly. It will be available in the next release. I've attached the
> current version of mpicxx.h. You would need to add "#define
> HAVE_NO_VARIABLE_RETURN_TYPE_SUPPORT" before including mpicxx.h.
> This new header file may not work with the cxx.lib in the current
> distribution but you can use it to see what needs to be changed in
the old
> header file. Simply copy the HAVE_NO_VARIABLE_RETURN_TYPE_SUPPORT
sections
> from the new file to the old.
> -David Ashton
> From: owner-mpich-discuss at mcs.anl.gov
> Sent: Wednesday, August 24, 2005 3:35 AM
> Subject: [MPICH] Can't compile against mpich2 with visual c++ 6
> I've already posted this to comp.parallel.mpi, but maybe this
> is a more appropriate place:
> Does anyone know what's going on here?
> I've got a set of programs written for mpi. As far as I remember
> they originally used MPICH2 and worked fine. Then my machine had
> to be reinstalled and I can't get them to build anymore. I'm
> pretty sure this is a different version of MPICH2 from the one I
> originally used, because I don't remember having to deal with
> SEEK_SET et. al. Visual C++ is patched to SP6 and the version
> of MPICH2 is the current one available for download.
<snip>
> I can go and use MPICH 1.2, but I get the impression it's deprecated.
> Any suggestions appreciated.
imalone
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20050824/92c8d57b/attachment.diff>
