[MPICH] Hi and question
JACOB_LIBERMAN at Dell.com JACOB_LIBERMAN at Dell.com
Tue Aug 9 20:39:57 CDT 2005
You can also use Jumbo frames (increased MTU size) which wouldn't require additional hardware. There are also a few Linux kernel parameters that can be changed to increases throughput. (tcp/udp tx/rx window sizes.)
Thanks, jacob
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Prakash
> Velayutham
> Sent: Tuesday, August 09, 2005 8:00 PM
> To: mpich-discuss at mcs.anl.gov; juliotrevisan at yahoo.com
> Subject: Re: [MPICH] Hi and question
> Hi,
> Way out of the list's context. You should ask this in one of
> the networking lists. But here is the answer.
> You could do something called channel bonding to load balance
> your network adapters in the master node. I think your switch
> also needs to support it. Just look it up on the web. Here is a link.
> http://www.redhat.com/docs/manuals/enterprise/RHEL-3-Manual/re
> f-guide/s1-modules-ethernet.html
> Hope it helps,
> Prakash
> >>> Julio Trevisan <juliotrevisan at yahoo.com> 08/09/05 3:52 PM >>>
> Hi everyone.
> I am a researcher from Florianópolis, Brazil (Federal
> University of Santa Catarina).
> I am already using MPICH2.
> We use in the lab a small cluster with 5 computers and there
> is no communication between slaves; only between master and slave.
> My questiont: is there any way to install 2 ethernet adapters
> inside the master computer to fasten the communication?
> Thanks
> Julio
> __________________________________________________
> Converse com seus amigos em tempo real com o Yahoo! Messenger
> http://br.download.yahoo.com/messenger/
