[Mochi-devel] running mochi examples
Abid Malik
abidmuslim at gmail.com
Wed Nov 6 11:55:15 CST 2019
Hi Matthieu,
For simple cases, I am using
gcc test.server.c -o server $(pkg-config --libs margo)
I pretty much tried everything. I just installed libfabric manually. I am
not sure what to try next.
On Wed, Nov 6, 2019 at 12:07 PM Dorier, Matthieu <mdorier at anl.gov> wrote:
> Hi Abid,
> At this top of my head this could be a problem with the order in which
> libraries are linked. Could you send your CMakeLists.txt file?
> Thanks,
> Matthieu
> *From: *mochi-devel <mochi-devel-bounces at lists.mcs.anl.gov> on behalf of
> Abid Malik via mochi-devel <mochi-devel at lists.mcs.anl.gov>
> *Reply to: *Abid Malik <abidmuslim at gmail.com>
> *Date: *Tuesday, 5 November 2019 at 00:01
> *To: *"Carns, Philip H." <carns at mcs.anl.gov>
> *Cc: *"Latham, Robert J. via mochi-devel" <mochi-devel at lists.mcs.anl.gov>
> *Subject: *Re: [Mochi-devel] running mochi examples
> Thanks.
> I am getting the following linking error:
> Linking C executable 01_margo_hello_server
> /usr/bin/ld: CMakeFiles/01_margo_hello_server.dir/hello_server.c.o:
> undefined reference to symbol 'ABT_thread_create'
> /gpfs/alpine/csc299/world-shared/amalik/mochi/spack/opt/spack/linux-rhel7-power9le/gcc-6.4.0/argobots-develop-uwvdjjdzrkn475ax7bw4w7hztawzidg3/lib/libabt.so.0:
> error adding symbols: DSO missing from command line
> /usr/bin/sha1sum: 01_margo_hello_server: No such file or directory
> collect2: error: ld returned 1 exit status
> make[2]: *** [01_margo_hello_server] Error 1
> make[1]: *** [CMakeFiles/01_margo_hello_server.dir/all] Error 2
> make: *** [all] Error 2
> currently, I have the following:
> Currently Loaded Modules:
> 1) xl/16.1.1-3 6) darshan-runtime/3.1.7
> 11) boost-1.70.0-gcc-6.4.0-dw376xg
> 2) spectrum-mpi/10.3.0.1-20190611 7) DefApps
> 12) libfabric-1.8.1-gcc-6.4.0-d4kxa4p
> 3) hsi/5.0.2.p5 8)
> argobots-develop-gcc-6.4.0-uwvdjjd 13) mercury-master-gcc-6.4.0-nbp34rm
> 4) xalt/1.1.4 9) bzip2-1.0.8-gcc-6.4.0-mdsmice
> 14) margo-0.5.2-gcc-6.4.0-gniufvt
> 5) lsf-tools/2.0 10) zlib-1.2.11-gcc-6.4.0-nbedgs2
> 15) cmake/3.15.2
> Argobot is there. Am I missing something?
> Abid
> On Mon, Nov 4, 2019 at 5:10 PM Carns, Philip H. <carns at mcs.anl.gov> wrote:
> For the transport it should work Ok to just use "verbs://" now (the
> trailing colon and slashes are important, though). Mercury will
> automatically convert that to the more verbose string internally.
> thanks,
> -Phil
> *From:* mochi-devel <mochi-devel-bounces at lists.mcs.anl.gov> on behalf of
> Latham, Robert J. via mochi-devel <mochi-devel at lists.mcs.anl.gov>
> *Sent:* Monday, November 4, 2019 3:11 PM
> *To:* mochi-devel at lists.mcs.anl.gov <mochi-devel at lists.mcs.anl.gov>;
> abidmuslim at gmail.com <abidmuslim at gmail.com>
> *Subject:* Re: [Mochi-devel] running mochi examples
> On Mon, 2019-11-04 at 07:37 -0500, Abid Malik via mochi-devel wrote:
> > Hello,
> > I am trying to play with the mochi examples at
> > https://xgitlab.cels.anl.gov/sds/sds-examples.git
> > I am trying the example on summit:
> > /mercury/01_hello/01_hg_hello_server
> > How should I start the server/client? I am trying it on login2 node
> > and trying to initiate it like:
> > ./01_hg_hello_server bmi+tcp://login2:1234
> I see you are using spack. If so, I think you would have had to go out
> of your way to request the 'bmi' transport. You probably built
> libfabric. You can find out for sure with 'spack find'
> You tell margo (mercury, really) which protocol to use but the string
> for "libfabric using the verbs provider" is a little odd:
> "ofi+verbs;ofi_rxm://"
> > and getting errors.
> > # NA -- Error -- /tmp/amalik/spack-stage/spack-stage-mercury-master-
> > nbp34rmg6rkc2ayiqxxxuupamvmdusr7/spack-src/src/na/na.c:281
> > # NA_Initialize_opt(): Specified class name does not support
> > requested protocol
> This says mercury did not recognize 'bmi+tcp'. You'd get the same
> error if you requested "moon_rock".
> I don't have a lot of guidance to offer you (yet). I just got started
> on summit a few days ago. When I try to take the advice I gave you I
> get an error, too:
> $ jsrun -r1 -n1 ./margo-example-server verbs
> # NA -- Error -- /tmp/robl/spack-stage/spack-stage-mercury-master-
> c6nwqortoqjsyviyinlg5t6sfay6wv7l/spack-src/src/na/na.c:279
> # NA_Initialize_opt(): Specified class name does not support requested
> protocol
> That's what we expect. margo/mercury don't know what 'verbs'
> is. Instead, we need to tell margo/mercury to use OFI (libfabric):
> $ jsrun -r1 -n1 ./margo-example-server "ofi+verbs;ofi_rxm://"
> c6nwqortoqjsyviyinlg5t6sfay6wv7l/spack-src/src/na/na_ofi.c:1406
> # na_ofi_getinfo(): fi_getinfo() failed, rc: -61(No data available)
> Uh, I'm still working on that one...
> ==rob
> mochi-devel mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/mochi-devel
> https://www.mcs.anl.gov/research/projects/mochi
> Abid M. Malik
> "I have learned silence from the talkative, toleration from the
> intolerant, and kindness from the unkind"---Gibran
> "Success is not for the chosen few, but for the few who choose" --- John
> Maxwell
> "Being a good person does not depend on your religion or status in life,
> your race or skin color, political views or culture. IT DEPENDS ON HOW GOOD
> YOU TREAT OTHERS"--- Abid
> "The Universe is talking to us, and the language of the Universe is
> mathematics."----Abid
Abid M. Malik
"I have learned silence from the talkative, toleration from the intolerant,
Maxwell
URL: <http://lists.mcs.anl.gov/pipermail/mochi-devel/attachments/20191106/d9aca700/attachment.html>
More information about the mochi-devel
