[Mochi-devel] running mochi examples
    Dorier, Matthieu
    mdorier at anl.gov
    Wed Nov  6 11:07:45 CST 2019
Hi Abid,
At this top of my head this could be a problem with the order in which libraries are linked. Could you send your CMakeLists.txt file?
Matthieu
From: mochi-devel <mochi-devel-bounces at lists.mcs.anl.gov> on behalf of Abid Malik via mochi-devel <mochi-devel at lists.mcs.anl.gov>
Reply to: Abid Malik <abidmuslim at gmail.com>
Date: Tuesday, 5 November 2019 at 00:01
To: "Carns, Philip H." <carns at mcs.anl.gov>
Cc: "Latham, Robert J. via mochi-devel" <mochi-devel at lists.mcs.anl.gov>
Subject: Re: [Mochi-devel] running mochi examples
Thanks.
I am getting the following linking error:
Linking C executable 01_margo_hello_server
/usr/bin/ld: CMakeFiles/01_margo_hello_server.dir/hello_server.c.o: undefined reference to symbol 'ABT_thread_create'
/gpfs/alpine/csc299/world-shared/amalik/mochi/spack/opt/spack/linux-rhel7-power9le/gcc-6.4.0/argobots-develop-uwvdjjdzrkn475ax7bw4w7hztawzidg3/lib/libabt.so.0: error adding symbols: DSO missing from command line
/usr/bin/sha1sum: 01_margo_hello_server: No such file or directory
collect2: error: ld returned 1 exit status
make[2]: *** [01_margo_hello_server] Error 1
make[1]: *** [CMakeFiles/01_margo_hello_server.dir/all] Error 2
make: *** [all] Error 2
currently, I have the following:
Currently Loaded Modules:
  1) xl/16.1.1-3                      6) darshan-runtime/3.1.7               11) boost-1.70.0-gcc-6.4.0-dw376xg
  2) spectrum-mpi/10.3.0.1-20190611   7) DefApps                             12) libfabric-1.8.1-gcc-6.4.0-d4kxa4p
  3) hsi/5.0.2.p5                     8) argobots-develop-gcc-6.4.0-uwvdjjd  13) mercury-master-gcc-6.4.0-nbp34rm
  4) xalt/1.1.4                       9) bzip2-1.0.8-gcc-6.4.0-mdsmice       14) margo-0.5.2-gcc-6.4.0-gniufvt
  5) lsf-tools/2.0                   10) zlib-1.2.11-gcc-6.4.0-nbedgs2       15) cmake/3.15.2
Argobot is there. Am I missing something?
Abid
On Mon, Nov 4, 2019 at 5:10 PM Carns, Philip H. <carns at mcs.anl.gov<mailto:carns at mcs.anl.gov>> wrote:
For the transport it should work Ok to just use "verbs://" now (the trailing colon and slashes are important, though).   Mercury will automatically convert that to the more verbose string internally.
thanks,
-Phil
From: mochi-devel <mochi-devel-bounces at lists.mcs.anl.gov<mailto:mochi-devel-bounces at lists.mcs.anl.gov>> on behalf of Latham, Robert J. via mochi-devel <mochi-devel at lists.mcs.anl.gov<mailto:mochi-devel at lists.mcs.anl.gov>>
Sent: Monday, November 4, 2019 3:11 PM
To: mochi-devel at lists.mcs.anl.gov<mailto:mochi-devel at lists.mcs.anl.gov> <mochi-devel at lists.mcs.anl.gov<mailto:mochi-devel at lists.mcs.anl.gov>>; abidmuslim at gmail.com<mailto:abidmuslim at gmail.com> <abidmuslim at gmail.com<mailto:abidmuslim at gmail.com>>
On Mon, 2019-11-04 at 07:37 -0500, Abid Malik via mochi-devel wrote:
> Hello,
> I am trying to play with the mochi examples at
>   https://xgitlab.cels.anl.gov/sds/sds-examples.git
> I am trying the example on summit:
> /mercury/01_hello/01_hg_hello_server
> How should I start the server/client? I am trying it on login2 node
> and trying to initiate it like:
> ./01_hg_hello_server bmi+tcp://login2:1234
I see you are using spack.  If so, I think you would have had to go out
of your way to request the 'bmi' transport.  You probably built
libfabric.  You can find out for sure with 'spack find'
You tell margo (mercury, really) which protocol to use but the string
for "libfabric using the verbs provider" is a little odd:
"ofi+verbs;ofi_rxm://"
> and getting errors.
> # NA -- Error -- /tmp/amalik/spack-stage/spack-stage-mercury-master-
> nbp34rmg6rkc2ayiqxxxuupamvmdusr7/spack-src/src/na/na.c:281
>  # NA_Initialize_opt(): Specified class name does not support
> requested protocol
This says mercury did not recognize 'bmi+tcp'.  You'd get the same
error if you requested "moon_rock".
I don't have a lot of guidance to offer you (yet).  I just got started
on summit a few days ago.  When I try to take the advice I gave you I
get an error, too:
$ jsrun -r1 -n1 ./margo-example-server  verbs
# NA -- Error -- /tmp/robl/spack-stage/spack-stage-mercury-master-
c6nwqortoqjsyviyinlg5t6sfay6wv7l/spack-src/src/na/na.c:279
 # NA_Initialize_opt(): Specified class name does not support requested
protocol
That's what we expect.  margo/mercury don't know what 'verbs'
is.  Instead, we need to tell margo/mercury to use OFI (libfabric):
$ jsrun -r1 -n1 ./margo-example-server "ofi+verbs;ofi_rxm://"
c6nwqortoqjsyviyinlg5t6sfay6wv7l/spack-src/src/na/na_ofi.c:1406
 # na_ofi_getinfo(): fi_getinfo() failed, rc: -61(No data available)
Uh, I'm still working on that one...
==rob
mochi-devel mailing list
https://lists.mcs.anl.gov/mailman/listinfo/mochi-devel
https://www.mcs.anl.gov/research/projects/mochi
Abid M. Malik
"I have learned silence from the talkative, toleration from the intolerant, and kindness from the unkind"---Gibran
"Success is not for the chosen few, but for the few who choose" --- John Maxwell
"Being a good person does not depend on your religion or status in life, your race or skin color, political views or culture. IT DEPENDS ON HOW GOOD YOU TREAT OTHERS"--- Abid
"The Universe is talking to us, and the language of the Universe is mathematics."----Abid
URL: <http://lists.mcs.anl.gov/pipermail/mochi-devel/attachments/20191106/36836168/attachment-0001.html>
More information about the mochi-devel
