[MOAB-dev] failed to run parallel test case: moab-5.1.0 with mpich-3.3
Vijay S. Mahadevan
vijay.m at gmail.com
Sun Jun 9 07:58:57 CDT 2019
Dear Lorenzo,
Sorry about my delayed response. I was on travel this past week and
couldn't reply to you immediately.
It is puzzling that the tests in parallel folder are getting built as
expected but "make check" does not run them correctly. I can see that
mpiexec program was set correctly during configuration and so the next
logical check here would be to try and launch the test programs
manually to see whether they succeed.
Can you do the following:
cd build/test/parallel && mpiexec -n 2 ./parallel_unit_tests &&
mpiexec -n 2 ./parallel_hdf5_test
Both those tests should run to completion successfully if everything
is setup correctly. If these succeed, I would be out of ideas until we
can replicate it locally. Let me know the result with the above
experiment.
Vijay
On Sun, Jun 2, 2019 at 6:22 AM Lorenzo Botti <bottilorenzo at gmail.com> wrote:
> > Can you do the following two variations:
> > 1) Re-verifying your current approach
> > a) Go to test/parallel and do `make clean && make check | tee make_check.log`
> > b) Send us make_check.log so that we can see if things compile but
> > do not run or nothing actually happens there.
> Please find in attachment the make_check.log... so yes this is the
> point where it hangs.
> > 2) Retry out-of-source
> > a) Perform `make distclean` in your in-source build
> > b) Do: `mkdir build && ../configure <configure arguments> && make
> > all && make check`
> > Let me know if (1) yields something useful and if not, (2) should
> > resolve the issue. If (2) does work, then we may have a problem with
> > in-source builds and I can check that on a workstation to replicate
> > the problem. Hope my instructions above aren't confusing.
> I got same behavior with out-of-source, following your instructions,
> see attached config.log
> Bests
> Lorenzo
