[MOAB-dev] Fwd: failed to run parallel test case: moab-5.1.0 with mpich-3.3
Lorenzo Botti bottilorenzo at gmail.com
Sun Jun 2 06:05:29 CDT 2019
---------- Forwarded message ---------
Date: Sun, Jun 2, 2019, 12:21
Subject: Re: [MOAB-dev] failed to run parallel test case: moab-5.1.0 with
mpich-3.3
To: Vijay S. Mahadevan <vijay.m at gmail.com>
> Can you do the following two variations:
> 1) Re-verifying your current approach
>   a) Go to test/parallel and do `make clean && make check | tee
make_check.log`
>   b) Send us make_check.log so that we can see if things compile but
> do not run or nothing actually happens there.
Please find in attachment the make_check.log... so yes this is the
point where it hangs.
> 2) Retry out-of-source
>   a) Perform `make distclean` in your in-source build
>   b) Do: `mkdir build && ../configure <configure arguments> && make
> all && make check`
> Let me know if (1) yields something useful and if not, (2) should
> resolve the issue. If (2) does work, then we may have a problem with
> in-source builds and I can check that on a workstation to replicate
> the problem. Hope my instructions above aren't confusing.
I got same behavior with out-of-source, following your instructions,
see attached config.log
Bests
Lorenzo
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20190602/4f6d4d10/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20190602/4f6d4d10/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20190602/4f6d4d10/attachment-0003.obj>
