[MOAB-dev] Disable fortran in moab-5.0.0
Lorenzo Botti bottilorenzo at gmail.com
Thu Nov 16 02:57:19 CST 2017
Thank you very much Vijay. It worked.
To me this setup is really helpful.
Just a note. The disable fortran option should be taken into account also
on the hdf5 build when configuring moab with download-hdf5. Otherwise that
will fail.
Hope that the new option will be included in future releases.
Bests
Lorenzo
On Nov 15, 2017 2:58 AM, "Vijay S. Mahadevan" <vijay.m at gmail.com> wrote:
> Hi Lorenzo,
> Can you give the branch "vijaysm/osx-blas-lapack" a try on your
> machines ? I've added several additional configure options to control
> the mangling (when fortran is disabled), and an option to disable
> BLAS/LAPACK (only if Eigen is present). A combination of:
> --disable-blaslapack --with-eigen3 --with-fc-mangling-suffix="_"
> should give you the right result. Let me know if this gives you the
> result of not requiring a Fortran compiler.
> I will merge this branch to develop and run our buildbot tests on
> various configuration combinations. Paul, I'll also make some
> modifications to CMake if this approach is acceptable. Let me know.
> Iulian, any comments ?
> Vijay
> On Fri, Nov 10, 2017 at 5:14 PM, Vijay S. Mahadevan <vijay.m at gmail.com>
> wrote:
> > Paul, as Lorenzo mentioned, we need to modify configuration to enable
> > this cross option. I can look into that as well.
> > The more combinations/options we add, the more complicated the
> > configuration becomes. While things do become seemingly flexible, I
> > just want to make sure it doesn't become a maintenance nightmare later
> > on. Hence the decision originally to just make BLAS/LAPACK mandatory
> > and not allow Eigen (with/without external BLAS). The implication on
> > FC here was a side effect unfortunately of that decision.
> > Vijay
> > On Fri, Nov 10, 2017 at 3:29 PM, Lorenzo Botti <bottilorenzo at gmail.com>
> wrote:
> >> Dear Paul,
> >> I don’t think it’s actually possible. The build system should be
> modified to
> >> account for such a configure option.
> >> Anyway this is also what I need, a fix to run MOAB on OSX without
> fortran.
> >> On my laptop I’m not interested on performance but I do most of the
> >> development.
> >> Installing a fortran compiler on OSX is a pain, as far as I know this
> forces
> >> me to use gcc instead of clang.
> >> Accordingly I would need to use a package manager like macports or
> homebrew,
> >> or to compile gcc myself.
> >> A fallback on Eigen would be really welcome.
> >> Bests
> >> Lorenzo
> >> On 10 Nov 2017, at 21:19, Paul Wilson <paul.wilson at wisc.edu> wrote:
> >> I'm not sure if I follow how to actually do what you are suggesting.
> If I
> >> wanted to rely on Eigen instead of both BLAS/LAPACK, is there a set of
> >> options I can pass to either autoconf or CMAKE to do that?
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20171116/d82c34ec/attachment-0001.html>
