[MOAB-dev] Disable fortran in moab-5.0.0
Vijay S. Mahadevan vijay.m at gmail.com
Thu Nov 9 10:11:22 CST 2017
Hi Lorenzo,
Yes like Paul mentioned, we require BLAS/LAPACK libraries now for
configuring MOAB, and that unfortunately imposes requirements on the
Fortran compiler to see how the symbol mangling works.
I am unsure whether we can make an exception with OSX here since the
-framework vecLib linker options should take care of everything we
need. I'll play with this today and let you know whether we can push a
fix for this right away (specific for OSX).
Vijay
On Thu, Nov 9, 2017 at 6:46 AM, Paul Wilson <paul.wilson at wisc.edu> wrote:
> Hello Lorenzo
> As of v5.0 MOAB requires FORTRAN to link to lapack/blas.  I discovered this
> issue with building and the master branch does have this change in the CMAKE
> files.
> Paul
> Paul P.H. Wilson
> Grainger Professor of Nuclear Engineering
> 608-263-0807
> 443 Engineering Research Bldg
> 1500 Engineering Dr, Madison, WI 53706
> calendar: http://go.wisc.edu/pphw-cal
> Computational Nuclear Engineering Research Group
> cnerg.engr.wisc.edu
> [sent from my iPad]
> On Nov 9, 2017, at 03:57, Lorenzo Botti <bottilorenzo at gmail.com> wrote:
> Dear all,
> I’d like to move to the latest moab but I’m having trouble disabling
> fortran.
> I tried to modify compiler.m4 but it seems that this is not enough, see
> below
> dlm249-190:moab-5.0.0 digihabia$ ./configure --disable-fortran
> --disable-imesh --with-mpi=/Users/digihabia/src2/openmpi-3.0.0/openmpi/
> --download-hdf5 --prefix=/Users/digihabia/src2/moab-5.0.0/moab/
> checking build system type... x86_64-apple-darwin17.2.0
> checking host system type... x86_64-apple-darwin17.2.0
> checking target system type... x86_64-apple-darwin17.2.0
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... config/install-sh -c -d
> checking for gawk... no
> checking for mawk... no
> checking for nawk... no
> checking for awk... awk
> checking whether make sets $(MAKE)... yes
> checking whether make supports nested variables... yes
> checking whether make supports nested variables... (cached) yes
> checking for sed... sed
> checking for readlink... yes
> checking for dirname... yes
> checking for basename... yes
> checking for rsync... yes
> checking for wget... no
> checking for scp... yes
> checking for curl... yes
> checking for tar... yes
> checking for unzip... yes
> checking for bzip2... yes
> checking for md5sum... no
> checking for shasum... yes
> checking for shasum... /usr/bin/shasum
> checking whether ln -s works... yes
> checking for mkdir... /bin/mkdir
> checking whether make sets $(MAKE)... (cached) yes
> checking for style of include used by make... GNU
> checking for gcc... /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicc
> checking whether the C compiler works... yes
> checking for C compiler default output file name... a.out
> checking for suffix of executables...
> checking whether we are cross compiling... no
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicc
> accepts -g... yes
> checking for /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicc option
> to accept ISO C89... none needed
> understands -c and -o together... yes
> checking dependency style of
> /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicc... gcc3
> checking how to run the C preprocessor...
> /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicc -E
> checking whether we are using the GNU C++ compiler... yes
> checking whether /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicxx
> accepts -g... yes
> /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicxx... gcc3
> checking how to run the C++ preprocessor...
> /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicxx -E
> checking how to get verbose linking output from ... configure: WARNING:
> compilation failed
> checking for Fortran 77 libraries of ...
> compilation failed
> checking for Fortran libraries of ...
> checking for known C compilers... Clang
> checking for known compiler/OS combinations... Clang:x86_64
> checking for known c++ compilers... Clang
> checking for known compiler/CPU/OS combinations... Clang:darwin17.2.0:x86_64
> checking if platform is IBM BlueGene... no
> checking how to print strings... printf
> checking for a sed that does not truncate output... sed
> checking for grep that handles long lines and -e... /usr/bin/grep
> checking for egrep... /usr/bin/grep -E
> checking for fgrep... /usr/bin/grep -F
> checking for ld used by
> /Library/Developer/CommandLineTools/usr/bin/ld
> checking if the linker (/Library/Developer/CommandLineTools/usr/bin/ld) is
> GNU ld... no
> checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
> checking the name lister (/usr/bin/nm -B) interface... BSD nm
> checking the maximum length of command line arguments... 196608
> checking how to convert x86_64-apple-darwin17.2.0 file names to
> x86_64-apple-darwin17.2.0 format... func_convert_file_noop
> checking how to convert x86_64-apple-darwin17.2.0 file names to toolchain
> checking for /Library/Developer/CommandLineTools/usr/bin/ld option to reload
> object files... -r
> checking for objdump... objdump
> checking how to recognize dependent libraries... pass_all
> checking for dlltool... no
> checking how to associate runtime and link libraries... printf %s\n
> checking for ar... ar
> checking for archiver @FILE support... no
> checking for strip... strip
> checking for ranlib... ranlib
> checking command to parse /usr/bin/nm -B output from
> /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicc object... ok
> checking for sysroot... no
> checking for a working dd... /bin/dd
> checking how to truncate binary pipes... /bin/dd bs=4096 count=1
> checking for mt... no
> checking if : is a manifest tool... no
> checking for dsymutil... dsymutil
> checking for nmedit... nmedit
> checking for lipo... lipo
> checking for otool... otool
> checking for otool64... no
> checking for -single_module linker flag... yes
> checking for -exported_symbols_list linker flag... yes
> checking for -force_load linker flag... yes
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking for dlfcn.h... yes
> checking for objdir... .libs
> checking if /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicc supports
> -fno-rtti -fno-exceptions... yes
> to produce PIC... -fno-common -DPIC
> checking if /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicc PIC flag
> -fno-common -DPIC works... yes
> checking if /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicc static
> flag -static works... no
> -c -o file.o... yes
> -c -o file.o... (cached) yes
> checking whether the /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicc
> linker (/Library/Developer/CommandLineTools/usr/bin/ld) supports shared
> libraries... yes
> checking dynamic linker characteristics... darwin17.2.0 dyld
> checking how to hardcode library paths into programs... immediate
> checking for dlopen in -ldl... yes
> checking whether a program can dlopen itself... yes
> checking whether a statically linked program can dlopen itself... yes
> checking whether stripping libraries is possible... yes
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... no
> checking whether to build static libraries... yes
> GNU ld... no
> checking whether the /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicxx
> libraries... yes
> checking for /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicxx option
> checking if /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicxx PIC flag
> checking if /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicxx static
> checking if /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicxx supports
> -c -o file.o... yes
> libraries... yes
> checking whether byte ordering is bigendian... no
> checking for gunzip... gunzip -c
> checking for gzip... (cached) gunzip -c
> checking for zcat... (cached) gunzip -c
> checking if C++ compiler supports template class specialization... yes
> checking if C++ compiler supports template function specialization... yes
> checking if /Users/digihabia/src2/openmpi-3.0.0/openmpi//bin/mpicxx works...
> yes
> checking for vsnprintf... yes
> checking for vsprintf... yes
> checking for clock... yes
> checking for times... yes
> checking for cbrt... yes
> checking if std::vector has templatized insert method... yes
> checking if std::copy must be old SGI format... no
> checking for ANSI C header files... (cached) yes
> checking fcntl.h usability... yes
> checking fcntl.h presence... yes
> checking for fcntl.h... yes
> checking for strings.h... (cached) yes
> checking sys/file.h usability... yes
> checking sys/file.h presence... yes
> checking for sys/file.h... yes
> checking sys/time.h usability... yes
> checking sys/time.h presence... yes
> checking for sys/time.h... yes
> checking for unistd.h... (cached) yes
> checking for inttypes.h... (cached) yes
> checking for stdint.h... (cached) yes
> checking stddef.h usability... yes
> checking stddef.h presence... yes
> checking for stddef.h... yes
> checking for stdlib.h... (cached) yes
> checking ieeefp.h usability... no
> checking ieeefp.h presence... no
> checking for ieeefp.h... no
> checking termios.h usability... yes
> checking termios.h presence... yes
> checking for termios.h... yes
> checking for sys/types.h... (cached) yes
> checking sys/ioctl.h usability... yes
> checking sys/ioctl.h presence... yes
> checking for sys/ioctl.h... yes
> checking size of void *... 8
> checking for size_t... yes
> checking for ptrdiff_t... yes
> checking for dlopen in -ldl... (cached) yes
> checking for compress in -lz... yes
> checking for pow in -lm... yes
> checking for dummy main to link with Fortran libraries... none
> checking for Fortran name-mangling scheme... configure: error: in
> `/Users/digihabia/src2/moab-5.0.0':
> configure: error: cannot compile a simple Fortran program
> See `config.log' for more details
