[MOAB-dev] linking error on BlueGene?
Ron Rahaman rahaman at mcs.anl.gov
Mon Apr 24 11:46:13 CDT 2017
Hi all,
I'm building MOAB 4.9.0 Cetus at ANL and I'm getting these errors at link
time (see below).  I've also attached my config.log.  Thanks in advance for
your help.
Best,
Ron Rahaman
libtool: link: ar -X 32_64 cru .libs/libMOABpar.a  ParallelComm.o
ProcConfig.o ParallelData.o ParallelMergeMesh.o ReadParallel.o
SharedSetData.o gs.o WriteHDF5Parallel.o
ar: illegal option -- X
Usage: ar [emulation options] [-]{dmpqrstx}[abcfilNoPsSuvV] [member-name]
[count] archive-file file...
       ar -M [<mri-script]
 commands:
  d            - delete file(s) from the archive
  m[ab]        - move file(s) in the archive
  p            - print file(s) found in the archive
  q[f]         - quick append file(s) to the archive
  r[ab][f][u]  - replace existing or insert new file(s) into the archive
  t            - display contents of archive
  x[o]         - extract file(s) from the archive
 command specific modifiers:
  [a]          - put file(s) after [member-name]
  [b]          - put file(s) before [member-name] (same as [i])
  [D]          - use zero for timestamps and uids/gids
  [N]          - use instance [count] of name
  [f]          - truncate inserted file names
  [P]          - use full path names when matching
  [o]          - preserve original dates
  [u]          - only replace files that are newer than current archive
contents
 generic modifiers:
  [c]          - do not warn if the library had to be created
  [s]          - create an archive index (cf. ranlib)
  [S]          - do not build a symbol table
  [T]          - make a thin archive
  [v]          - be verbose
  [V]          - display the version number
  @<file>      - read options from <file>
 emulation options:
  No emulation specific options
ar: supported targets: elf64-powerpc elf64-powerpcle elf32-powerpc
elf32-powerpcle aixcoff-rs6000 aixcoff64-rs6000 elf64-little elf64-big
elf32-little elf32-big elf32-spu srec symbolsrec verilog tekhex binary ihex
make[3]: *** [libMOABpar.la] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20170424/fb7d3f36/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20170424/fb7d3f36/attachment-0001.bin>
