[MOAB-dev] Mbconvert
Yu, Yiqi
yyu at anl.gov
Tue Mar 14 09:55:53 CDT 2017
Rajeev,
Because this mesh has 540 blocks. I do not know how NC_MAX_DIMS is counted in netCDF. As long as I decrease the number of the block number, It works well. I put the mesh on MCS /nfs2/yiqi/mesh/7pins.Could you take a look? I think you can load it into cubit. Let me know if there is other alternatives for assigning blocks regions without increasing the variable - NC_MAX_DIMS.
Thank you
Yiqi
-----Original Message-----
Sent: Tuesday, March 14, 2017 6:41 AM
To: Jain, Rajeev
Cc: Yu, Yiqi; Vijay S. Mahadevan; MOAB Dev
Subject: Re: Mbconvert
Does this have anything to do with the number of blocks in the problem? I don't think so, but want to make sure.
Sent from my iPhone
> On Mar 14, 2017, at 2:47 AM, "jain at mcs.anl.gov" <jain at mcs.anl.gov> wrote:
> Yiqi,
> The variable - NC_MAX_DIMS:
> is the maximum number of dimensions that can be used to specify the shape of a single variable.
> Why do you have that many datasets?
> Recompiling netCDF with increased NC_MAX_DIMS might solve your problem.If you point us to the file on MCS network, we can take a look.
> Rajeev Jain
> Mathematics and Computer Science
> Argonne National Laboratory
> 1134, Bldg 240, Chicago IL USA 60439
> O: 630-252-3176 jain at mcs.anl.gov
> ________________________________
> From: "Yu, Yiqi" <yyu at anl.gov>
> To: Vijay S. Mahadevan <vijay.m at gmail.com>; "Jain, Rajeev"
> Cc: "Shemon, Emily R." <eshemon at anl.gov>
> Sent: Friday, March 10, 2017 12:11 PM
> Subject: Mbconvert
> Hi Vijay and Rajeev,
> I tried to convert a .exo file to h5m file with mbconvert. It give me the following error.Do you have any idea?
> [yyu at blogin1 test]$
> /blues/gpfs/home/yyu/SHARP7ass/build/libraries/moab/moab-4.9.1/build/t
> ools/mbconvert hex8_NBC.exo a.h5m [0]MOAB ERROR: ---------------------
> Error Message ------------------------------------
> [0]MOAB ERROR: ReadNCDF: File contains 1090 dims but NetCDF library supports only 1024!
> [0]MOAB ERROR: read_exodus_header() line 375 in src/io/ReadNCDF.cpp
> [0]MOAB ERROR: --------------------- Error Message
> [0]MOAB ERROR: Failed to load file after trying all possible readers!
> [0]MOAB ERROR: serial_load_file() line 635 in src/Core.cpp [0]MOAB
> ERROR: load_file() line 526 in src/Core.cpp Failed to load
> "hex8_NBC.exo".
> Error code: MB_FAILURE (16)
> Error message: Failed to load file after trying all possible readers
> Best Yiqi Yu, PhD Nuclear Engineering Division Argonne National
> Laboratory
> 9700 S Cass Ave Bldg 208
> Argonne, IL 60439-4842
> www.anl.gov
> Office: +1-630-252-1604
> yyu at anl.gov
