[MOAB-dev] MOAB in Windows (Cygwin/Msys) does not compile
Manuel Torrilhon
mt at mathcces.rwth-aachen.de
Thu Jan 5 15:45:28 CST 2017
Dear MOAB team,
I enjoy using MOAB for my pde simulation code. I have good experiences with
MOAB under Ubuntu, Centos and MacOS, but I have difficulties to compile it
in a Windows environment using either Cygwin or Msys unix emulation. Both
give the compilation error listed below, which I don't understand.
Any help is greatly appreciated.
Best regards,
Manuel
libtool: compile: g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src
-DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64
-DIS_BUILDING_MB -I.. -I./.. -I./../parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set
-Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast
-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG
-MT ExoIIUtil.lo -MD -MP -MF .deps/ExoIIUtil.Tpo -c ExoIIUtil.cpp -o ExoIIUtil.o
In file included from ExoIIUtil.cpp:17:0:
../../src/Internals.hpp:21:0: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning(disable : 4786)
In file included from ExoIIUtil.hpp:28:0,
from ExoIIUtil.cpp:16:
moab/ExoIIInterface.hpp:45:21: error: expected initializer before 'ExoIIInterface'
class MB_DLL_EXPORT ExoIIInterface
In file included from c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\ext\atomicity.h:35:0,
from c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\bits\ios_base.h:39,
from c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\ios:42,
from c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\ostream:38,
from c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\iterator:64,
from ../../src/moab/Range.hpp:167,
from ../../src/moab/Interface.hpp:44,
from ExoIIUtil.cpp:18:
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\mingw32\bits\gthr.h:30:37: error: expected '}' before end of line
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\mingw32\bits\gthr.h:30:37: error: expected declaration before end of line
make[5]: *** [ExoIIUtil.lo] Error 1
