[MOAB-dev] VTK structured mesh outpu
    Tim Tautges
    timothy.tautges at cd-adapco.com
    Thu Sep 22 12:03:47 CDT 2016
I'd choose to use tags/conventions to denote rectilinear boxes rather than class distinction, unless you're really
concerned about the space required to represent a rectilinear scd mesh. I'm not sure a 4-6x savings (from the already
reduced space required to store a scd mesh) would be worth the work. I doubt that the current MOAB allows you to
allocate vertex handles w/o allocating space for coord storage, though I could be wrong on that.
- tim
On 09/21/2016 10:02 AM, Paul Wilson wrote:
> Hi Iulian,
> I'm reasonably sure that the SCDBox class can handle this.  We'll investigate further and let you know.
> At this point, I just wanted to make sure we weren't duplicating any effort :)
> Paul
> On 09/21/2016 09:56 AM, Grindeanu, Iulian R. wrote:
>> Hi Paul,
>> I am not sure what would be the best way to accomplish this.
>> I think it would need a new class/ type, similar to SCDBox. Maybe SCDRectilinear.
>> The entity handle space for vertices AND hexahedra will need to be reserved, the same way hexa entity handle space is
>> reserved for an SCDBox. (Maybe that class can be derived from SCDBox?)
>> Tim developed SCD Interface and SCDBox about 10 years ago, and it is used for climate readers right now.
>> His opinion on this would be very valuable.
>> An SCDRectilinear object could be used for VTK readers/writer only, the rest of the readers/writers would fall back to
>> unstructured representation.
>> Hmmm, maybe I am over-complicating things.
>> Iulian
>> ________________________________________
>> From: Paul Wilson [paul.wilson at wisc.edu]
>> Sent: Wednesday, September 21, 2016 6:14 AM
>> To: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
>> Subject: Re: [MOAB-dev] VTK structured mesh outpu
>> Hello Iulian,
>> On 09/20/2016 11:12 AM, Grindeanu, Iulian R. wrote:
>>> Hello Paul,
>>> I am not sure I understand what dagmc needs
>>> (I should probably read the code in moab :)
>> This is not for DAGMC, but related to other ways that we use MOAB to
>> assist with visualization & analysis of mesh data.
>>> Moab SCD interface is aligned with VTK structured grid  (legacy format, we do not do anything with XML)
>>> ( DATASET STRUCTURED_GRID)
>>> in that, all points' coordinates are explicit, and in a specific order ( I think c style, need to check; need to
>>> check if it is the same convention in vtk)
>>> all cells are "implicit", their connectivity is never stored, it is just derived from the dimensions (2d or 3d)
>>> Moab's SCD interface allows all kinds of access. You can request neighbors, etc, and it works in parallel too, in the
>>> sense that each task has a very specific partition , it knows about neighbors, can do ghosting, etc. Pretty cool
>>> stuff, but rather verbose. Not sure if you need anything for parallel
>>> An SCDBox from moab will correspond to a DATASET STRUCTURED_GRID from vtk
>>> vtk has other "structured" meshes dataset types, that are simpler: STRUCTURED_POINTS and RECTILINEAR_GRID
>>> Which one of those 3 does dagmc need?
>> We are looking at the "DATASET RECTILINEAR_GRID" option, in which the
>> points are NOT explicitly stored.  Instead, the set of x, y, and z
>> locations are stored in separate lists and the connectivity is never
>> stored.  This change allows some of our larger files to go from 6GB to
>> <900MB!!
>> We're looking into the steps it will take to accomplish this, hopefully
>> as an addition to MOAB.
>> Paul
>>> Iulian
>>> http://www.vtk.org/Wiki/VTK/Writing_VTK_files_using_python
>>> http://www.vtk.org/wp-content/uploads/2015/04/file-formats.pdf
>>> Sent: Monday, September 19, 2016 4:13 PM
>>> Hi Iulian,
>>> We are much more interested in the writer, but might be convinced to
>>> support a reader as well :)
>>> We would want to explore the SCD interface to see how it could best
>>> support this.
>>> Our use case begins with MCNP mesh tally output files that are always
>>> structured mesh.  There is a native reader in MOAB for these files, but
>>> not as rich/robust as we'd like, and it does NOT use the scd interface,
>>> instead making an unstructured representation.  There is also a reader
>>> in the PyNE toolkit that does ultimately use the scd interface, but then
>>> also relies on MOAB's vtk writer which stores an unstructured
>>> representation.
>>> The key to a structured (Cartesian) mesh VTK writer is having access to
>>> the x,y,z bounds without having to infer them from the set of vertices.
>>> The rest is probably straightforward.
>>> Paul
>>> On 09/19/2016 03:22 PM, Grindeanu, Iulian R. wrote:
>>>> MOAB does not have a structured writer. Not even for h5m format
>>>> (it has the ability to create structured meshes)
>>>> even in that case, the mesh is written explicit (unstructured)
>>>> structured vtk format is relatively simpler, but do you plan to add reader and writer or just writer?
>>>> How do you create structured mesh, with scd interface?
>>>> thanks,
>>>> Iulian
>>>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Paul Wilson [paul.wilson at wisc.edu]
>>>> Sent: Monday, September 19, 2016 3:12 PM
>>>> To: moab-dev at mcs.anl.gov
>>>> Subject: [MOAB-dev] VTK structured mesh outpu
>>>> Hi all,
>>>> Does the MOAB VTK writer have a way to write structured mesh data using
>>>> VTK's structured mesh format?  For data that conforms to that, it saves
>>>> a substantial amount of disk space and also speeds up
>>>> processing/visualization times.
>>>> If not, we may be interested in helping add this...
>>>> Paul
>>>> Paul P.H. Wilson
>>>> Grainger Professor of Nuclear Engineering
>>>> 608-263-0807
>>>> 419 Engineering Research Bldg
>>>> 1500 Engineering Dr, Madison, WI 53706
>>>> calendar: http://go.wisc.edu/pphw-cal
>>>> Computational Nuclear Engineering Research Group
>>>> cnerg.engr.wisc.edu
>>>> Faculty Director, Advanced Computing Initiative
>>>> aci.wisc.edu
>>> Paul P.H. Wilson
>>> 608-263-0807
>>> cnerg.engr.wisc.edu
>>> aci.wisc.edu
>> Paul P.H. Wilson
>> 608-263-0807
>> cnerg.engr.wisc.edu
>> aci.wisc.edu
Timothy J. Tautges
Sr. Manager, Directed Meshing, CD-adapco
Phone: (631) 629-3139 (internal: x29130)
Mobile/Gvoice: (608) 354-1459
