[MOAB-dev] VTK structured mesh outpu
    Nico Schlömer
    nico.schloemer at gmail.com
    Mon Sep 19 15:40:29 CDT 2016
Hi Paul,
You're right, both MOAB and meshio deal with unstructured meshed right now.
Cheers,
Nico
On Mon, Sep 19, 2016 at 10:28 PM Paul Wilson <paul.wilson at wisc.edu> wrote:
> Hi Nico,
> Thanks for the meshio tip, but MOAB can natively write to an unstructured
> representation in VTK.  Does meshio do anything special to create a
> structured representation?
> Thanks,
> Paul
> On 09/19/2016 03:24 PM, Nico Schlömer wrote:
> FYI, you can convert H5M files to VTK (and a number of other formats)
> using meshio [1,2].
> Cheers,
> Nico
> [1] https://pypi.python.org/pypi/meshio
> [2] https://github.com/nschloe/meshio
> On Mon, Sep 19, 2016 at 10:22 PM Grindeanu, Iulian R. <iulian at mcs.anl.gov>
> wrote:
>> MOAB does not have a structured writer. Not even for h5m format
>> (it has the ability to create structured meshes)
>> even in that case, the mesh is written explicit (unstructured)
>> structured vtk format is relatively simpler, but do you plan to add
>> reader and writer or just writer?
>> How do you create structured mesh, with scd interface?
>> thanks,
>> Iulian
>> ________________________________________
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
>> behalf of Paul Wilson [paul.wilson at wisc.edu]
>> Sent: Monday, September 19, 2016 3:12 PM
>> To: moab-dev at mcs.anl.gov
>> Subject: [MOAB-dev] VTK structured mesh outpu
>> Hi all,
>> Does the MOAB VTK writer have a way to write structured mesh data using
>> VTK's structured mesh format?  For data that conforms to that, it saves
>> a substantial amount of disk space and also speeds up
>> processing/visualization times.
>> If not, we may be interested in helping add this...
>> Paul
>> Paul P.H. Wilson
>> Grainger Professor of Nuclear Engineering
>> 608-263-0807
>> 419 Engineering Research Bldg
>> 1500 Engineering Dr, Madison, WI 53706
>> calendar: http://go.wisc.edu/pphw-cal
>> Computational Nuclear Engineering Research Group
>> cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Initiative
>> aci.wisc.edu
> Paul P.H. Wilson
> 608-263-0807paul.wilson at wisc.edu
> Computational Nuclear Engineering Research Groupcnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Initiativeaci.wisc.edu
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160919/50e16e29/attachment.html>
