[MOAB-dev] VTK structured mesh outpu
    Paul Wilson
    paul.wilson at wisc.edu
    Mon Sep 19 15:28:08 CDT 2016
Hi Nico,
Thanks for the meshio tip, but MOAB can natively write to an
unstructured representation in VTK.  Does meshio do anything special to
create a structured representation?
Paul
On 09/19/2016 03:24 PM, Nico Schlömer wrote:
> FYI, you can convert H5M files to VTK (and a number of other formats)
> using meshio [1,2].
> Cheers,
> Nico
> [1] https://pypi.python.org/pypi/meshio
> [2] https://github.com/nschloe/meshio
> On Mon, Sep 19, 2016 at 10:22 PM Grindeanu, Iulian R.
> <iulian at mcs.anl.gov <mailto:iulian at mcs.anl.gov>> wrote:
>     MOAB does not have a structured writer. Not even for h5m format
>     (it has the ability to create structured meshes)
>     even in that case, the mesh is written explicit (unstructured)
>     structured vtk format is relatively simpler, but do you plan to
>     add reader and writer or just writer?
>     How do you create structured mesh, with scd interface?
>     thanks,
>     Iulian
>     ________________________________________
>     From: moab-dev-bounces at mcs.anl.gov
>     <mailto:moab-dev-bounces at mcs.anl.gov>
>     [moab-dev-bounces at mcs.anl.gov
>     <mailto:moab-dev-bounces at mcs.anl.gov>] on behalf of Paul Wilson
>     [paul.wilson at wisc.edu <mailto:paul.wilson at wisc.edu>]
>     Sent: Monday, September 19, 2016 3:12 PM
>     To: moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>
>     Subject: [MOAB-dev] VTK structured mesh outpu
>     Hi all,
>     Does the MOAB VTK writer have a way to write structured mesh data
>     using
>     VTK's structured mesh format?  For data that conforms to that, it
>     saves
>     a substantial amount of disk space and also speeds up
>     processing/visualization times.
>     If not, we may be interested in helping add this...
>     Paul
>     Paul P.H. Wilson
>     Grainger Professor of Nuclear Engineering
>     608-263-0807
>     419 Engineering Research Bldg
>     1500 Engineering Dr, Madison, WI 53706
>     calendar: http://go.wisc.edu/pphw-cal
>     Computational Nuclear Engineering Research Group
>     cnerg.engr.wisc.edu <http://cnerg.engr.wisc.edu>
>     Faculty Director, Advanced Computing Initiative
>     aci.wisc.edu <http://aci.wisc.edu>
Paul P.H. Wilson
608-263-0807
cnerg.engr.wisc.edu
aci.wisc.edu
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160919/8fd3af76/attachment-0001.html>
