[MOAB-dev] Error message when MeshTag is set and entities are removed from database.
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Tue Jul 26 12:25:02 CDT 2016
Thanks Lukasz. We'll take a look at make the error non-verbose.
If you already have some changes, a PR would make things easier to
review and merge.
Vijay
On Tue, Jul 26, 2016 at 4:10 AM, Lukasz Kaczmarczyk
<Lukasz.Kaczmarczyk at glasgow.ac.uk> wrote:
> Hello,
> I found this bug, it always happens when MeshTag is defined and entities are removed from database. Bug is not
> critical, but annoying making unnecessary printing on the screen when error not really happened.
> [0]MOAB ERROR: --------------------- Error Message ------------------------------------
> [0]MOAB ERROR: Cannot get/set mesh/global tag _FieldShift on non-root-set EntitySet 3!
> [0]MOAB ERROR: not_root_set() line 18 in src/MeshTag.cpp
> [0]MOAB ERROR: Cannot get/set mesh/global tag _FEShift on non-root-set EntitySet 3!
> [0]MOAB ERROR: Cannot get/set mesh/global tag _ProblemShift on non-root-set EntitySet 3!
> [0]MOAB ERROR: Cannot get/set mesh/global tag _MoFEMBuild on non-root-set EntitySet 3!
> [0]MOAB ERROR: remove_data() line 332 in src/SparseTag.cpp
> I think that problem is in Core::delete_entities
>  for (std::list<TagInfo*>::iterator i = tagList.begin(); i != tagList.end(); ++i) {
>    temp_result = (*i)->remove_data( sequenceManager, mError, range );
>      // ok if the error is tag_not_found, some ents may not have every tag on them
>    if (MB_SUCCESS != temp_result && MB_TAG_NOT_FOUND != temp_result)
>      result = temp_result;
> when MeshTag through virtual functions is deleted, then error is printed from not_root_set. This is not
> consistent how other tags are responding, for example in case of SparseTag an error is resulted
> MB_TAG_NOT_FOUND and no error is printed.
> I think that MeshTag should behave in exactly the same way.
> I can make quick fix, my proposition is to not_root_set change that it return MB_TAG_NOT_FOUND in
> case of non root meshset.
> Kind regards,
> Lukasz
