[MOAB-dev] Error message when MeshTag is set and entities are removed from database.
Lukasz Kaczmarczyk
Lukasz.Kaczmarczyk at glasgow.ac.uk
Tue Jul 26 04:10:59 CDT 2016
Hello,
I found this bug, it always happens when MeshTag is defined and entities are removed from database. Bug is not
critical, but annoying making unnecessary printing on the screen when error not really happened.
[0]MOAB ERROR: --------------------- Error Message ------------------------------------
[0]MOAB ERROR: Cannot get/set mesh/global tag _FieldShift on non-root-set EntitySet 3!
[0]MOAB ERROR: not_root_set() line 18 in src/MeshTag.cpp
[0]MOAB ERROR: Cannot get/set mesh/global tag _FEShift on non-root-set EntitySet 3!
[0]MOAB ERROR: Cannot get/set mesh/global tag _ProblemShift on non-root-set EntitySet 3!
[0]MOAB ERROR: Cannot get/set mesh/global tag _MoFEMBuild on non-root-set EntitySet 3!
[0]MOAB ERROR: remove_data() line 332 in src/SparseTag.cpp
I think that problem is in Core::delete_entities
for (std::list<TagInfo*>::iterator i = tagList.begin(); i != tagList.end(); ++i) {
temp_result = (*i)->remove_data( sequenceManager, mError, range );
// ok if the error is tag_not_found, some ents may not have every tag on them
if (MB_SUCCESS != temp_result && MB_TAG_NOT_FOUND != temp_result)
result = temp_result;
when MeshTag through virtual functions is deleted, then error is printed from not_root_set. This is not
consistent how other tags are responding, for example in case of SparseTag an error is resulted
MB_TAG_NOT_FOUND and no error is printed.
I think that MeshTag should behave in exactly the same way.
I can make quick fix, my proposition is to not_root_set change that it return MB_TAG_NOT_FOUND in
case of non root meshset.
Kind regards,
Lukasz
