[MOAB-dev] How can I prepare a .h5m file base on my own calculation
Grindeanu, Iulian R. iulian at mcs.anl.gov
Wed Jun 1 16:31:20 CDT 2016
You can try paraview to convert from vtu format to vtk;
Moab vtk reader is not very robust, in the sense that there are vtk files it cannot read.
You can also try VisIt to convert from vtu to vtk
Do you have a small vtu file that you can share? I can try to look at it, to see how it goes.
What kind of data do you have at nodes?
Iulian
Sent: Wednesday, June 01, 2016 2:42 PM
To: Grindeanu, Iulian R.
Cc: moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] How can I prepare a .h5m file base on my own calculation
Hi Iulian,
Thank you very much for your help. The format we use to store mesh and solution information is .vtu file.
I tried to run function ./mbconvert. It can successfully transfer from .h5m to .vtk, and vice versa.
But I cannot convert either these 2 format to/from .vtu file.
An example error message is like following.
Is there any solution for this problem? Any suggestion is greatly appreciated!
Best,
Jie
dyn-160-39-11-225:tools jiewu$ ./mbconvert in.vtu out.h5m
[0]MOAB ERROR: --------------------- Error Message ------------------------------------
[0]MOAB ERROR: in.vtu: File is not HDF5!
[0]MOAB ERROR: set_up_read() line 472 in src/io/ReadHDF5.cpp
[0]MOAB ERROR: NULL file handle.!
[0]MOAB ERROR: is_error() line 133 in src/io/ReadHDF5.hpp
[0]MOAB ERROR: ReadNCDF:: problem opening Netcdf/Exodus II file in.vtu!
[0]MOAB ERROR: load_file() line 303 in src/io/ReadNCDF.cpp
[0]MOAB ERROR: Trouble opening file in.vtu!
[0]MOAB ERROR: load_file() line 68 in src/io/ReadNC.cpp
[0]MOAB ERROR: Expected Keyword!
[0]MOAB ERROR: load_file() line 178 in src/io/ReadABAQUS.cpp
0x0 hahhahahah
[0]MOAB ERROR: This doesn't appear to be a .cub file!
[0]MOAB ERROR: load_file() line 310 in src/io/Tqdcfr.cpp
[0]MOAB ERROR: Parsing error at line 1: expected one of { $NOD $MeshFormat } got "<?xml"!
[0]MOAB ERROR: match_token() line 378 in src/io/FileTokenizer.cpp
[0]MOAB ERROR: in.vtu: No such file or directory!
[0]MOAB ERROR: ascii_read_triangles() line 201 in src/io/ReadSTL.cpp
[0]MOAB ERROR: in.vtu: not a binary STL file!
[0]MOAB ERROR: binary_read_triangles() line 312 in src/io/ReadSTL.cpp
[0]MOAB ERROR: in.vtu.node: cannot read file!
[0]MOAB ERROR: open_file() line 59 in src/io/ReadTetGen.cpp
[0]MOAB ERROR: in.vtu: Trouble reading vertices!
[0]MOAB ERROR: read_vertices() line 129 in src/io/ReadTemplate.cpp
[0]MOAB ERROR: Failed to load file after trying all possible readers!
[0]MOAB ERROR: serial_load_file() line 635 in src/Core.cpp
[0]MOAB ERROR: load_file() line 526 in src/Core.cpp
Failed to load "in.vtu".
Error code: MB_INDEX_OUT_OF_RANGE (1)
Error message: Failed to load file after trying all possible readers
On Jun 1, 2016, at 12:26 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov<mailto:iulian at mcs.anl.gov>> wrote:
Hello,
Coupler.cpp depends on a moab instance, so even if you do not use h5m format, if you want to use the coupler, your model has to reside inside a moab instance.
Do you care about parallelism or not? Then h5m format is required, otherwise it will be hard to employ parallelism
there are several converters available, to h5m format, you can do tools/mbconvert -l to see what is available based on your configuration
What format do you use?
Iulian
From: moab-dev-bounces at mcs.anl.gov<mailto:moab-dev-bounces at mcs.anl.gov> [moab-dev-bounces at mcs.anl.gov<mailto:moab-dev-bounces at mcs.anl.gov>] on behalf of Jie Wu [jie.voo at gmail.com<mailto:jie.voo at gmail.com>]
Sent: Wednesday, June 01, 2016 9:17 AM
To: moab-dev at mcs.anl.gov<mailto:moab-dev at mcs.anl.gov>
Subject: [MOAB-dev] How can I prepare a .h5m file base on my own calculation
Hi All,
In order to transfer variables from a Source mesh to a Target mesh, I am studying the use of function mbcoupler_test.cpp these days.
The stuff confusing me is the .h5m file. From the MOAB user guide, I know that .h5m is theMOAB’s native file format.
But I don’t know how to prepare a .h5m file based on my own calculation results (which usually contains node coordinates, node connectivities, and nodal variables). As a result, I cannot employ a function like ./mbcoupler_test to help me to transfer the mesh variables.
Any instruction is deeply appreciated!
Best,
Jie
Jie Wu, Ph.D. candidate
Department of Geotechnical Engineering, Tongji University
Visiting student at Civil Engineering & Engineering Mechanics, Columbia University
Add: 500 West 120th Street 641 S.W. Mudd New York, NY  10027
Ph: +1(917)822-0942
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160601/197d26fe/attachment-0001.html>
