[MOAB-dev] Error message when compiling the mbcoupler_test.cpp
    Jie Wu
    jie.voo at gmail.com
    Fri May 13 14:12:22 CDT 2016
Hi there,
Thank you for your directions! Here is the results I get after issuing make -k check at directory test/parallel, and I think they look good.
dyn-160-39-10-173:parallel jiewu$ make -k check
/Applications/Xcode.app/Contents/Developer/usr/bin/make  pcomm_unit scdtest pcomm_serial par_spatial_locator_test parallel_unit_tests scdpart read_nc_par ucdtrvpart mpastrvpart gcrm_par   parallel_hdf5_test mhdf_parallel parallel_write_test uber_parallel_test parallel_adj parmerge_test augment_with_ghosts  imeshp_test mbparallelcomm_test partcheck structured3 parmerge
  CXX      pcomm_unit.o
  CXXLD    pcomm_unit
  CXX      scdtest.o
  CXXLD    scdtest
  CXX      pcomm_serial.o
  CXXLD    pcomm_serial
  CXX      par_spatial_locator_test.o
  CXXLD    par_spatial_locator_test
  CXX      parallel_unit_tests.o
  CXXLD    parallel_unit_tests
  CXX      scdpart.o
  CXXLD    scdpart
  CXX      ../io/read_nc.o
  CXXLD    read_nc_par
  CXX      ucdtrvpart.o
  CXXLD    ucdtrvpart
  CXX      mpastrvpart.o
  CXXLD    mpastrvpart
  CXX      gcrm_par.o
  CXXLD    gcrm_par
  CXX      parallel_hdf5_test.o
  CXXLD    parallel_hdf5_test
  CC       mhdf_parallel.o
  CCLD     mhdf_parallel
  CXX      parallel_write_test.o
  CXXLD    parallel_write_test
  CXX      uber_parallel_test.o
  CXXLD    uber_parallel_test
  CXX      ../adj_moab_test.o
  CXXLD    parallel_adj
  CXX      parmerge_test.o
  CXXLD    parmerge_test
  CXX      augment_with_ghosts.o
  CXXLD    augment_with_ghosts
  PPFC     imeshp_test.o
  FCLD     imeshp_test
  CXX      mbparallelcomm_test.o
  CXXLD    mbparallelcomm_test
  CXX      partcheck.o
  CXXLD    partcheck
  CXX      structured3.o
  CXXLD    structured3
  CXX      parmerge.o
  CXXLD    parmerge
/Applications/Xcode.app/Contents/Developer/usr/bin/make  check-TESTS
PASS: pcomm_unit
PASS: scdtest
PASS: pcomm_serial
PASS: par_spatial_locator_test
PASS: parallel_unit_tests
PASS: scdpart
PASS: read_nc_par
PASS: ucdtrvpart
PASS: mpastrvpart
PASS: gcrm_par
PASS: parallel_hdf5_test
PASS: mhdf_parallel
PASS: parallel_write_test
PASS: uber_parallel_test
PASS: parallel_adj
PASS: parmerge_test
PASS: augment_with_ghosts
PASS: imeshp_test
Testsuite summary for MOAB 4.9.2pre
# TOTAL: 18
# PASS:  18
# SKIP:  0
# XFAIL: 0
# FAIL:  0
# XPASS: 0
# ERROR: 0
Following is an example I run with mpiexec, and I think it also goes well.
Thank you very much for your help! Any help deal with the failing tests will be much appreciated.
Best,
Jie
dyn-160-39-10-173:mbcoupler jiewu$ mpiexec -np 2  mbcoupler_test -meshes /Users/wujie/SourceCode/moab/MeshFiles/unittest/64bricks_1khex.h5m /Users/wujie/SourceCode/moab/MeshFiles/unittest/64bricks_12ktet.h5m -itag vertex_field -outfile dum.h5m
ReadHDF5:             0.0324039
  get set meta        0.00103188
  partial subsets     0.000803947
  partition time      2.14577e-06
  get set ids         0.000556946
  set contents        0.00107098
  polyhedra           2.5034e-05
  elements            0.00174189
  nodes               0.0014832
  node adjacency      0
  side elements       0.000672817
  update connectivity 0.000102043
  adjacency           0
  delete non_adj      0.00338697
  recursive sets      0
  find contain_sets   0.000369072
  read sets           0.00147104
  read tags           0.01667
  store file ids      0.00191593
  read qa records     0.000133038
Parallel Read times:
  0.0473361 PARALLEL READ PART
  0.0138111 PARALLEL RESOLVE_SHARED_ENTS
  0.0113361 PARALLEL EXCHANGE_GHOSTS
  0.00113177 PARALLEL RESOLVE_SHARED_SETS
  0.00648403 PARALLEL_AUGMENT_SETS_WITH_GHOSTS
  0.079994 PARALLEL TOTAL
ReadHDF5:             0.0714378
  get set meta        0.000261784
  partial subsets     0.000660181
  partition time      9.53674e-07
  get set ids         0.00101304
  set contents        0.000728846
  polyhedra           0.000128031
  elements            0.0155201
  nodes               0.00354886
  node adjacency      6.19888e-06
  side elements       0.00422001
  update connectivity 0.00184798
  adjacency           0
  delete non_adj      0.0100739
  recursive sets      0
  find contain_sets   0.00218511
  read sets           0.00258899
  read tags           0.0235598
  store file ids      0.0044961
  read qa records     9.5129e-05
  0.0779119 PARALLEL READ PART
  0.0667319 PARALLEL RESOLVE_SHARED_ENTS
  0.0397439 PARALLEL EXCHANGE_GHOSTS
  0.00435901 PARALLEL RESOLVE_SHARED_SETS
  0.0243261 PARALLEL_AUGMENT_SETS_WITH_GHOSTS
  0.209468 PARALLEL TOTAL
Proc 1 iface entities:
    446 0d iface entities.
    1080 1d iface entities.
    Proc 0636 2d iface entities.
    0 3d iface entities.
  iface entities:
    108   (446 verts adj to other iface ents)
rank 0 points of interest: 6155
rank 1 points of interest: 6155
Max time : 0.101124 0.0461781 0.00104499 (inst loc interp -- 2 procs)
WriteHDF5:           0.0779669
  gather mesh:       0.00237203
  create file:       0.0655501
    create nodes:    0.00201201
    negotiate types: 2.19345e-05
    create elem:     0.000785828
    file id exch:    0.0234561
    create adj:      0.000414848
    create set:      0.019654
      shared ids:    6.19888e-05
      shared data:   0.014715
      set offsets:   0.00447798
    create tags:     0.0160849
  coordinates:       0.00199103
  connectivity:      0.00162005
  sets:              0.0010829
    set descrip:     0.00019598
    set content:     0.000527859
    set parent:      0.000226021
    set child:       0.000128984
  adjacencies:       5.96046e-06
  tags:              0.00700402
    dense data:      0.00127792
    sparse data:     0.00569224
    var-len data:    0
Wrote dum.h5m
mbcoupler_test complete.
> On May 13, 2016, at 2:58 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov> wrote:
> yes, can you try make -k check  ?
> It will not stop at the first failed test, it will try to test everything
> From: Vijay S. Mahadevan [vijay.m at gmail.com]
> Sent: Friday, May 13, 2016 1:53 PM
> To: Jie Wu
> Cc: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] Error message when compiling the mbcoupler_test.cpp
> Jie,
> We are looking into the failing tests and will update in case there is
> a bug in the code. Our nightly tests are running cleanly and so I'm
> curious to see if other tests are failing. Can you go to test/parallel
> and run "make check" there to verify if the parallel job launch is
> working correctly ? Also, can you verify if you can run MPI programs
> with mpiexec ?
> Vijay
> Vijay
> On Fri, May 13, 2016 at 1:31 PM, Jie Wu <jie.voo at gmail.com> wrote:
>> Hi Vijay,
>> Deleting the auto-installed packages under sandbox before issue new
>> configurations works good! No error message emerged until I input the
>> command make check, which is as following.
>> Do you have any idea for this problem?
>> Best,
>> Jie
>> PASS: reorder_test
>> FAIL: test_prog_opt
>> PASS: coords_connect_iterate
>> PASS: elem_eval_test
>> PASS: spatial_locator_test
>> PASS: test_boundbox
>> PASS: adj_moab_test
>> PASS: uref_mesh_test
>> PASS: verdict_test
>> PASS: test_Matrix3
>> PASS: mbfacet_test
>> PASS: gttool_test
>> PASS: cropvol_test
>> FAIL: mergemesh_test
>> PASS: mbground_test
>> PASS: lloyd_smoother_test
>> # TOTAL: 36
>> # PASS:  34
>> # SKIP:  0
>> # XFAIL: 0
>> # FAIL:  2
>> # XPASS: 0
>> # ERROR: 0
>> See test/test-suite.log
>> Please report to moab-dev at mcs.anl.gov
>> make[4]: *** [test-suite.log] Error 1
>> make[3]: *** [check-TESTS] Error 2
>> make[2]: *** [check-am] Error 2
>> make[1]: *** [check-recursive] Error 1
>> make: *** [check-recursive] Error 1
>> On May 13, 2016, at 1:08 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>> Jie, since you now changed the compilers used to configure the stack,
>> I would advise deleting the auto-installed packages under sandbox
>> directory and then re-configuring. This will force the rebuild of
>> HDF5/NetCDF packages with the parallel MPI compilers and you should
>> get the HDF5-parallel support enabled after that. Makes sense ?
>> Vijay
>> On Fri, May 13, 2016 at 11:27 AM, Jie Wu <jie.voo at gmail.com> wrote:
>> Hi Vijay,
>> Thank you for your reply. The new configuration do works. Here shows the
>> command I inputed and the message while I input: make check.
>> dyn-160-39-10-173:moab jiewu$ ./configure --with-mpi=/usr/local
>> CC=/usr/local/bin/mpicc CXX=/usr/local/bin/mpic++ FC=/usr/local/bin/mpif90
>> F77=/usr/local/bin/mpif77 --download-metis --download-hdf5 --download-netcdf
>> --enable-docs --with-doxygen=/Applications/Doxygen.app/Contents/Resources/
>> The results are
>> configure: WARNING:
>> *        MOAB has been configured with parallel and HDF5 support
>> *     but the configured HDF5 library does not support parallel IO.
>> *            Some parallel IO capabilities will be disabled.
>> After that, I inputted the command, make -j4, and then command make check.
>> Here are the results it shows
>> PASS: elem_util_test
>> PASS: element_test
>> FAIL: datacoupler_test
>> FAIL: mbcoupler_test
>> FAIL: parcoupler_test
>> # TOTAL: 5
>> # PASS:  2
>> # SKIP:  0
>> # XFAIL: 0
>> # FAIL:  3
>> # XPASS: 0
>> # ERROR: 0
>> See tools/mbcoupler/test-suite.log
>> Then I was trying to run the mbcouple_test with command
>> Now the results look like,
>> [0]MOAB ERROR: --------------------- Error Message
>> [0]MOAB ERROR: MOAB not configured with parallel HDF5 support!
>> [0]MOAB ERROR: set_up_read() line 355 in src/io/ReadHDF5.cpp
>> [0]MOAB ERROR: NULL file handle.!
>> [0]MOAB ERROR: is_error() line 133 in src/io/ReadHDF5.hpp
>> [1]MOAB ERROR: --------------------- Error Message
>> [1]MOAB ERROR: MOAB not configured with parallel HDF5 support!
>> [1]MOAB ERROR: set_up_read() line 355 in src/io/ReadHDF5.cpp
>> [1]MOAB ERROR: NULL file handle.!
>> [1]MOAB ERROR: is_error() line 133 in src/io/ReadHDF5.hpp
>> [0]MOAB ERROR: Failed to load file after trying all possible readers!
>> [0]MOAB ERROR: serial_load_file() line 635 in src/Core.cpp
>> [0]MOAB ERROR: Failed in step PARALLEL READ PART!
>> [0]MOAB ERROR: load_file() line 553 in src/parallel/ReadParallel.cpp
>> [0]MOAB ERROR: load_file() line 252 in src/parallel/ReadParallel.cpp
>> [0]MOAB ERROR: load_file() line 515 in src/Core.cpp
>> [1]MOAB ERROR: Failed to load file after trying all possible readers!
>> [1]MOAB ERROR: serial_load_file() line 635 in src/Core.cpp
>> [1]MOAB ERROR: Failed in step PARALLEL READ PART!
>> [1]MOAB ERROR: load_file() line 553 in src/parallel/ReadParallel.cpp
>> [0]MOAB ERROR: main() line 172 in mbcoupler_test.cpp
>> [1]MOAB ERROR: load_file() line 252 in src/parallel/ReadParallel.cpp
>> [1]MOAB ERROR: load_file() line 515 in src/Core.cpp
>> [1]MOAB ERROR: main() line 172 in mbcoupler_test.cpp
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 16.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> [dyn-160-39-11-172.dyn.columbia.edu:26361] 1 more process has sent help
>> message help-mpi-api.txt / mpi-abort
>> [dyn-160-39-11-172.dyn.columbia.edu:26361] Set MCA parameter
>> "orte_base_help_aggregate" to 0 to see all help / error messages
>> The other excitable file in mbcoupler folder, like ./element_test now can
>> run successfully.
>> Any direction for this was deeply appreciated!
>> Best,
>> Jie
>> On May 13, 2016, at 11:54 AM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>> I also forgot to mention that you can be more explicit in the
>> specification of compilers during configuration, if you really want.
>> This would avoid headaches since the user specified wrappers will
>> directly be used. For example:
>> ./configure --with-mpi=/usr/local CC=/usr/local/bin/mpicc
>> F77=/usr/local/bin/mpif77 <OTHER_CONFIGURE_OPTIONS>
>> Vijay
>> On Fri, May 13, 2016 at 10:52 AM, Vijay S. Mahadevan <vijay.m at gmail.com>
>> wrote:
>> Please use --with-mpi=/usr/local as the configure option. If you have
>> MPI pre-installed, either through PETSc or natively in your system,
>> always try to re-use that to maintain consistency. This will help
>> avoid mix-up of MPI implementations when you try to launch a parallel
>> job later.
>> Let us know if the new configuration works.
>> Vijay
>> On Thu, May 12, 2016 at 6:32 PM, Jie Wu <jie.voo at gmail.com> wrote:
>> Thank you very much for your reply. I search in my src/moab/MOABConfig.h
>> file, and I did not find the MOAB_HAVE_MPI. So I think the MOAB on my laptop
>> cannot run in parallel yet.
>> I have this from my terminal.
>> dyn-160-39-10-173:moab jiewu$ which mpic++
>> But I cannot get anything by inputing which mpi. So I don’t know where the
>> mpi is in my laptop.
>> I have petsc installed which has mpich, and linking that directory to the
>> MOAB configure option also did not work.
>> Should I install mpi solely? I am afraid it might conflict with the one
>> installed in petsc.
>> Is there any method that the mpi could be installed with MOAB automatically,
>> or maybe other proper manner? Thanks a lot!
>> Best,
>> Jie
>> On May 12, 2016, at 6:11 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>> Can you send the config.log. Looks like MPI is not getting enabled
>> (possibly), even with --dowload-mpich. Or you can check
>> src/moab/MOABConfig.h in your build directory and grep for
>> MOAB_HAVE_MPI.
>> Vijay
>> On Thu, May 12, 2016 at 4:46 PM, Jie Wu <jie.voo at gmail.com> wrote:
>> Hi Iulian,
>> Thanks for your reply. I think my configure is with mpi. Here is my
>> configure command
>> dyn-160-39-10-173:moab jiewu$    ./configure --download-metis
>> --download-hdf5 --download-netcdf --download-mpich --enable-docs
>> Best,
>> Jie
>> On May 12, 2016, at 5:43 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>
>> wrote:
>> Hi Jie,
>> Did you configure with mpi? What is your configure command?
>> Iulian
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf
>> of Jie Wu [jie.voo at gmail.com]
>> Sent: Thursday, May 12, 2016 4:23 PM
>> To: moab-dev at mcs.anl.gov
>> Subject: [MOAB-dev] Error message when compiling the mbcoupler_test.cpp
>> Hi all,
>> My name is Jie and I am part of computational mechanics group at civil
>> engineering dept. of Columbia university.
>> I am working on large deformation problems which may lead mesh distortions
>> and a re-meshing become necessary.
>> I would like to compile mbcoupler_test.cpp to learn how it transfer the
>> variables from old to the new mesh.
>> Now I can successfully compile the codes in build/examples and they works
>> good! But I cannot compile the codes in folder build/tools/mbcoupler by
>> following the instructions in build/tools/readme.tools, which shows error
>> message like following.
>> Do you have any idea for this problem? Thanks a lot!
>> Best,
>> Jie
>> DataCoupler.cpp:136:25: error: member access into incomplete
>>   type 'moab::ParallelComm'
>> if (myPcomm && myPcomm->size() > 1) {
>> ./DataCoupler.hpp:34:7: note: forward declaration of
>> class ParallelComm;
>> DataCoupler.cpp:161:12: error: member access into incomplete
>> myPcomm->proc_config().crystal_router()->gs_tran...
>> class ParallelComm;
>> DataCoupler.cpp:187:12: error: member access into incomplete
>> class ParallelComm;
>> 3 errors generated.
>> make[2]: *** [DataCoupler.lo] Error 1
>> make[2]: *** Waiting for unfinished jobs....
>> Coupler.cpp:344:45: error: no member named 'gs_transfer' in
>>   'moab::gs_data::crystal_data'
>> (myPc->proc_config().crystal_router())->gs_trans...
>> Coupler.cpp:388:45: error: no member named 'gs_transfer' in
>> Coupler.cpp:611:45: error: no member named 'gs_transfer' in
>> Coupler.cpp:638:43: error: no member named 'gs_transfer' in
>> myPc->proc_config().crystal_router()->gs_transfe...
>> 4 errors generated.
>> make[2]: *** [Coupler.lo] Error 1
>> make[1]: *** [all-recursive] Error 1
>> make: *** [all-recursive] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160513/9920f1ae/attachment-0001.html>
