[MOAB-dev] subdomains, sparse tags
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Thu Apr 7 11:54:03 CDT 2016
Hi Nico,
If the tags are dense or sparse affects the way they are stored in memory or on the hdf5 file;
Sparse tags are kept in pairs <entity handle, value>
dense tags are kept in contiguous arrays, corresponding to entity sequences
I would use dense tags if possible;
On those entities on domains, do you need to identify domains or the value of the tag?
I mean, are you using the tag for grouping entities or they have the same value ?
In general, we create sets, and then "tag" them with a tag to identify/classify the sets.
(partition sets, or material sets, etc, which are usually sparse tags)
If every entity has a different value, you should use a dense tag defined on entities (not on sets)
If the tags are dense you can access them more efficiently with tag_iterate
there are some examples here
http://ftp.mcs.anl.gov/pub/fathom/moab-docs/DirectAccessWithHoles_8cpp-example.html
http://ftp.mcs.anl.gov/pub/fathom/moab-docs/DirectAccessNoHoles_8cpp-example.html
Not sure what you need exactly.
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Nico Schlömer [nico.schloemer at gmail.com]
Sent: Thursday, April 07, 2016 10:41 AM
To: moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] subdomains, sparse tags
I'm kind of lost here on the tags side anyways. Is there a piece of code that uses tags that I can look at?
Cheers,
Nico
On Thu, Apr 7, 2016 at 3:13 PM Nico Schlömer <nico.schloemer at gmail.com<mailto:nico.schloemer at gmail.com>> wrote:
Hi everyone,
I'm just reading up on tags, all starting from the problem that I have mesh on which there are multiple subdomains which may or may not overlap, may or may not fill the the entire mesh. What I will need to do is to set those tags on the mesh and then to iterate over all entities with that tag (probably multiple times).
Do I see correctly that sparse tags [1] are the way to go then?
Cheers,
Nico
[1] https://www.mcs.anl.gov/~fathom/moab-docs/html/classmoab_1_1SparseTag.html
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160407/f0e4a004/attachment.html>
