[MOAB-dev] subdomains, sparse tags
    Nico Schlömer
    nico.schloemer at gmail.com
    Thu Apr  7 10:41:23 CDT 2016
I'm kind of lost here on the tags side anyways. Is there a piece of code
that uses tags that I can look at?
Cheers,
Nico
On Thu, Apr 7, 2016 at 3:13 PM Nico Schlömer <nico.schloemer at gmail.com>
wrote:
> Hi everyone,
> I'm just reading up on tags, all starting from the problem that I have
> mesh on which there are multiple subdomains which may or may not overlap,
> may or may not fill the the entire mesh. What I will need to do is to set
> those tags on the mesh and then to iterate over all entities with that tag
> (probably multiple times).
> Do I see correctly that sparse tags [1] are the way to go then?
> Cheers,
> Nico
> [1]
> https://www.mcs.anl.gov/~fathom/moab-docs/html/classmoab_1_1SparseTag.html
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160407/e6ef55eb/attachment.html>
