[MOAB-dev] Is cubit now required by cgma
JR Cary cary at txcorp.com
Sat Dec 19 15:18:18 CST 2015
One more data point -- the autotools build does not require cubit.
I configured with
'/Users/cary/projects/composerall/cgm/configure' \
   --prefix=/opt/volatile-clangcxx11/cgm-master.r1494-ser \
   CC='/usr/bin/clang' \
   CXX='/usr/bin/clang++' \
   FC='/opt/homebrew/bin/gfortran-4.9' \
   F77='/opt/homebrew/bin/gfortran-4.9' \
   CFLAGS='-fPIC -pipe' \
   CXXFLAGS='-std=c++11 -stdlib=libc++ -fPIC -pipe' \
   FFLAGS='-fPIC -pipe' \
   FCFLAGS='-fPIC -pipe' \
   --with-occ='/opt/volatile-clangcxx11/oce-stable.r1462-sersh'
and all just worked.
So it looks like the cmake build system is not yet ready?
Thx.......J
On 12/19/15 11:54 AM, JR Cary wrote:
> Hi Andy,
> Thanks for your help.
> The issue is that I do not have Cubit, so I have no cubit/bin directory.
> But I do have OCE, which I am using for CAD, so I *think* I need to build
> CGM with OCE to get CAD finally into MOAB, but I certainly need to build
> without CUBIT.
> Is this making any sense?
> Thx......John
> On 12/19/15 11:39 AM, Andrew Davis wrote:
>> Hi John
>> I've found that on Linux if you at the cubit/bin directory to your
>> LD_LIBRARY_PATH that fixes that. Try adding the equivalent to the
>> DYLD_LIBRARY_PATH.
>> Thanks
>> Andy
> On 12/19/15 11:41 AM, Andrew Davis wrote:
>> Hi John
>> Its also not required, you can build without CGM. If you choose to
>> build with CGM then it will pick up the Cubit shared libraries via
>> the CGM dependency.
>> Thanks
>> Andy
>> On Dec 19, 2015 12:00 PM, <moab-dev-request at mcs.anl.gov> wrote:
>>     Message: 1
>>     Date: Sat, 19 Dec 2015 06:57:17 -0700
>>     From: JR Cary <cary at txcorp.com <mailto:cary at txcorp.com>>
>>     To: moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>
>>     Subject: [MOAB-dev] Is cubit now required by cgma?
>>     Message-ID: <5675623D.6000001 at txcorp.com
>>     <mailto:5675623D.6000001 at txcorp.com>>
>>     Content-Type: text/plain; charset=utf-8; format=flowed
>>     I recently updated cgm and tried building it as I had been,
>>     configuring with
>>     '/opt/contrib-clangcxx11/cmake-3.2.2-ser/bin/cmake'
>>     -DCMAKE_INSTALL_PREFIX:PATH=/opt/volatile-clangcxx11/cgm-master.r1494-ser
>>     -DCMAKE_BUILD_TYPE:STRING=Release
>>     -DCMAKE_COLOR_MAKEFILE:BOOL=FALSE -DCMAKE_VERBOSE_MAKEFILE:BOOL=TRUE
>>     -DBUILD_WITH_SHARED_RUNTIME:BOOL=TRUE
>>     -DCMAKE_C_COMPILER:FILEPATH='/usr/bin/clang'
>>     -DCMAKE_CXX_COMPILER:FILEPATH='/usr/bin/clang++'
>>     -DCMAKE_Fortran_COMPILER:FILEPATH='/opt/homebrew/bin/gfortran-4.9'
>>     -DCMAKE_C_FLAGS:STRING='-fPIC -pipe'
>>     -DCMAKE_CXX_FLAGS:STRING='-std=c++11 -stdlib=libc++ -fPIC -pipe'
>>     -DCMAKE_Fortran_FLAGS:STRING='-fPIC -pipe'
>>     -DOCE_DIR:PATH='/opt/volatile-clangcxx11/oce-OCE-0.17-txc.r1462-sersh/OCE.framework/Versions/0.17/Resources'
>>     /sources/projects/composerall/cgm
>>     The configure worked fine, but the build failed at
>>     /usr/bin/clang++  -std=c++11 -stdlib=libc++ -fPIC -pipe -O3 -DNDEBUG
>>     -dynamiclib -Wl,-headerpad_max_install_names  -o
>>     ../lib/libcubit_util.dylib ...
>>     Undefined symbols for architecture x86_64:
>>        "CubitColor::CubitColor(unsigned char, unsigned char, unsigned
>>     char,
>>     unsigned char)", referenced from:
>>            __GLOBAL__sub_I_GfxDebug.cpp in GfxDebug.cpp.o
>>        "CubitColor::CubitColor()", referenced from:
>>        "CubitEvent::~CubitEvent()", referenced from:
>>            CubitCoordinateSystem::~CubitCoordinateSystem() in
>>     CubitCoordinateSystem.cpp.o
>>     Is CUBIT now required?
>>     Thx...John Cary
>>     PS - looking at geom/CMakeLists.txt, I see that I needed to add
>>     -DCGM_OCC:BOOL=ON
>>     to pick up OCC/OCE, but that did not help the build.....
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151219/36d5c39d/attachment-0001.html>
