[MOAB-dev] Is cubit now required by cgma
JR Cary cary at txcorp.com
Sat Dec 19 12:54:46 CST 2015
Hi Andy,
Thanks for your help.
The issue is that I do not have Cubit, so I have no cubit/bin directory.
But I do have OCE, which I am using for CAD, so I *think* I need to build
CGM with OCE to get CAD finally into MOAB, but I certainly need to build
without CUBIT.
Is this making any sense?
Thx......John
On 12/19/15 11:39 AM, Andrew Davis wrote:
> Hi John
> I've found that on Linux if you at the cubit/bin directory to your
> LD_LIBRARY_PATH that fixes that. Try adding the equivalent to the
> DYLD_LIBRARY_PATH.
> Thanks
> Andy
On 12/19/15 11:41 AM, Andrew Davis wrote:
> Hi John
> Its also not required, you can build without CGM. If you choose to
> build with CGM then it will pick up the Cubit shared libraries via the
> CGM dependency.
> Thanks
> Andy
> On Dec 19, 2015 12:00 PM, <moab-dev-request at mcs.anl.gov
> <mailto:moab-dev-request at mcs.anl.gov>> wrote:
>     Message: 1
>     Date: Sat, 19 Dec 2015 06:57:17 -0700
>     From: JR Cary <cary at txcorp.com <mailto:cary at txcorp.com>>
>     To: moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>
>     Subject: [MOAB-dev] Is cubit now required by cgma?
>     Message-ID: <5675623D.6000001 at txcorp.com
>     <mailto:5675623D.6000001 at txcorp.com>>
>     Content-Type: text/plain; charset=utf-8; format=flowed
>     I recently updated cgm and tried building it as I had been,
>     configuring with
>     '/opt/contrib-clangcxx11/cmake-3.2.2-ser/bin/cmake'
>     -DCMAKE_INSTALL_PREFIX:PATH=/opt/volatile-clangcxx11/cgm-master.r1494-ser
>     -DCMAKE_BUILD_TYPE:STRING=Release
>     -DCMAKE_COLOR_MAKEFILE:BOOL=FALSE -DCMAKE_VERBOSE_MAKEFILE:BOOL=TRUE
>     -DBUILD_WITH_SHARED_RUNTIME:BOOL=TRUE
>     -DCMAKE_C_COMPILER:FILEPATH='/usr/bin/clang'
>     -DCMAKE_CXX_COMPILER:FILEPATH='/usr/bin/clang++'
>     -DCMAKE_Fortran_COMPILER:FILEPATH='/opt/homebrew/bin/gfortran-4.9'
>     -DCMAKE_C_FLAGS:STRING='-fPIC -pipe'
>     -DCMAKE_CXX_FLAGS:STRING='-std=c++11 -stdlib=libc++ -fPIC -pipe'
>     -DCMAKE_Fortran_FLAGS:STRING='-fPIC -pipe'
>     -DOCE_DIR:PATH='/opt/volatile-clangcxx11/oce-OCE-0.17-txc.r1462-sersh/OCE.framework/Versions/0.17/Resources'
>     /sources/projects/composerall/cgm
>     The configure worked fine, but the build failed at
>     /usr/bin/clang++  -std=c++11 -stdlib=libc++ -fPIC -pipe -O3 -DNDEBUG
>     -dynamiclib -Wl,-headerpad_max_install_names  -o
>     ../lib/libcubit_util.dylib ...
>     Undefined symbols for architecture x86_64:
>        "CubitColor::CubitColor(unsigned char, unsigned char, unsigned
>     char,
>     unsigned char)", referenced from:
>            __GLOBAL__sub_I_GfxDebug.cpp in GfxDebug.cpp.o
>        "CubitColor::CubitColor()", referenced from:
>        "CubitEvent::~CubitEvent()", referenced from:
>            CubitCoordinateSystem::~CubitCoordinateSystem() in
>     CubitCoordinateSystem.cpp.o
>     Is CUBIT now required?
>     Thx...John Cary
>     PS - looking at geom/CMakeLists.txt, I see that I needed to add
>     -DCGM_OCC:BOOL=ON
>     to pick up OCC/OCE, but that did not help the build.....
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151219/3d4c8412/attachment.html>
