[MOAB-dev] moab-dev Digest, Vol 86, Issue 21
    Andrew Davis
    andrewdavis.davis at gmail.com
    Sat Dec 19 12:39:58 CST 2015
Hi John
I've found that on Linux if you at the cubit/bin directory to your
LD_LIBRARY_PATH that fixes that. Try adding the equivalent to the
DYLD_LIBRARY_PATH.
Thanks
Andy
On Dec 19, 2015 12:00 PM, <moab-dev-request at mcs.anl.gov> wrote:
> Send moab-dev mailing list submissions to
>         moab-dev at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/moab-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         moab-dev-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of moab-dev digest..."
> Today's Topics:
>    1.  Is cubit now required by cgma? (JR Cary)
> Message: 1
> Date: Sat, 19 Dec 2015 06:57:17 -0700
> From: JR Cary <cary at txcorp.com>
> To: moab-dev at mcs.anl.gov
> Subject: [MOAB-dev] Is cubit now required by cgma?
> Message-ID: <5675623D.6000001 at txcorp.com>
> Content-Type: text/plain; charset=utf-8; format=flowed
> I recently updated cgm and tried building it as I had been, configuring
> with
> '/opt/contrib-clangcxx11/cmake-3.2.2-ser/bin/cmake'
> -DCMAKE_INSTALL_PREFIX:PATH=/opt/volatile-clangcxx11/cgm-master.r1494-ser
> -DCMAKE_BUILD_TYPE:STRING=Release
> -DCMAKE_COLOR_MAKEFILE:BOOL=FALSE -DCMAKE_VERBOSE_MAKEFILE:BOOL=TRUE
> -DBUILD_WITH_SHARED_RUNTIME:BOOL=TRUE
> -DCMAKE_C_COMPILER:FILEPATH='/usr/bin/clang'
> -DCMAKE_CXX_COMPILER:FILEPATH='/usr/bin/clang++'
> -DCMAKE_Fortran_COMPILER:FILEPATH='/opt/homebrew/bin/gfortran-4.9'
> -DCMAKE_C_FLAGS:STRING='-fPIC -pipe'
> -DCMAKE_CXX_FLAGS:STRING='-std=c++11 -stdlib=libc++ -fPIC -pipe'
> -DCMAKE_Fortran_FLAGS:STRING='-fPIC -pipe'
> -DOCE_DIR:PATH='/opt/volatile-clangcxx11/oce-OCE-0.17-txc.r1462-sersh/OCE.framework/Versions/0.17/Resources'
> /sources/projects/composerall/cgm
> The configure worked fine, but the build failed at
> /usr/bin/clang++  -std=c++11 -stdlib=libc++ -fPIC -pipe -O3 -DNDEBUG
> -dynamiclib -Wl,-headerpad_max_install_names  -o
> ../lib/libcubit_util.dylib ...
> Undefined symbols for architecture x86_64:
>    "CubitColor::CubitColor(unsigned char, unsigned char, unsigned char,
> unsigned char)", referenced from:
>        __GLOBAL__sub_I_GfxDebug.cpp in GfxDebug.cpp.o
>    "CubitColor::CubitColor()", referenced from:
>    "CubitEvent::~CubitEvent()", referenced from:
>        CubitCoordinateSystem::~CubitCoordinateSystem() in
> CubitCoordinateSystem.cpp.o
> Is CUBIT now required?
> Thx...John Cary
> PS - looking at geom/CMakeLists.txt, I see that I needed to add
> -DCGM_OCC:BOOL=ON
> to pick up OCC/OCE, but that did not help the build.....
> End of moab-dev Digest, Vol 86, Issue 21
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151219/070fd707/attachment.html>
