[MOAB-dev] Is cubit now required by cgma?
    JR Cary
    cary at txcorp.com
    Sat Dec 19 07:57:17 CST 2015
I recently updated cgm and tried building it as I had been, configuring with
'/opt/contrib-clangcxx11/cmake-3.2.2-ser/bin/cmake'
-DCMAKE_INSTALL_PREFIX:PATH=/opt/volatile-clangcxx11/cgm-master.r1494-ser -DCMAKE_BUILD_TYPE:STRING=Release
-DCMAKE_COLOR_MAKEFILE:BOOL=FALSE -DCMAKE_VERBOSE_MAKEFILE:BOOL=TRUE
-DBUILD_WITH_SHARED_RUNTIME:BOOL=TRUE
-DCMAKE_C_COMPILER:FILEPATH='/usr/bin/clang'
-DCMAKE_CXX_COMPILER:FILEPATH='/usr/bin/clang++'
-DCMAKE_Fortran_COMPILER:FILEPATH='/opt/homebrew/bin/gfortran-4.9'
-DCMAKE_C_FLAGS:STRING='-fPIC -pipe'
-DCMAKE_CXX_FLAGS:STRING='-std=c++11 -stdlib=libc++ -fPIC -pipe'
-DCMAKE_Fortran_FLAGS:STRING='-fPIC -pipe'
-DOCE_DIR:PATH='/opt/volatile-clangcxx11/oce-OCE-0.17-txc.r1462-sersh/OCE.framework/Versions/0.17/Resources'
/sources/projects/composerall/cgm
The configure worked fine, but the build failed at
/usr/bin/clang++  -std=c++11 -stdlib=libc++ -fPIC -pipe -O3 -DNDEBUG
-dynamiclib -Wl,-headerpad_max_install_names  -o
../lib/libcubit_util.dylib ...
Undefined symbols for architecture x86_64:
   "CubitColor::CubitColor(unsigned char, unsigned char, unsigned char,
unsigned char)", referenced from:
       __GLOBAL__sub_I_GfxDebug.cpp in GfxDebug.cpp.o
   "CubitColor::CubitColor()", referenced from:
   "CubitEvent::~CubitEvent()", referenced from:
       CubitCoordinateSystem::~CubitCoordinateSystem() in
CubitCoordinateSystem.cpp.o
Is CUBIT now required?
Thx...John Cary
PS - looking at geom/CMakeLists.txt, I see that I needed to add
-DCGM_OCC:BOOL=ON
to pick up OCC/OCE, but that did not help the build.....
