[MOAB-dev] GLOBAL_IDs, building map from moab mesh
Vijay S. Mahadevan
vijay.m at gmail.com
Mon Dec 7 15:29:32 CST 2015
Using GLOBAL_ID for finding matching entities is the simplest way to
address your use case.
> I now bumped into a bug in serial execution. I noticed that the output of
> `mbconvert somefile.vtk somefile.h5m` generates GLOBAL_ID list full of 0s,
> as opposed to the nice list of 1, 2, 3,... as generated by `mbpart`.
> Apparently you're not supposed to rely on GLOBAL_ID after all? Is there a
> better approach that also works in serial?
This seems fishy. Are you overwriting the GLOBAL_ID or setting it
yourselves in memory ?
Vijay
On Mon, Dec 7, 2015 at 4:13 PM, Nico Schlömer <nico.schloemer at gmail.com> wrote:
> Hi everyone,
> To build a map for multi-process meshes, I need to be able to identify that
> node N on proc 0 is the same as node M on proc 1. For this, I'm using the
> GLOBAL_ID property. I know that this list isn't necessarily contiguous or
> 1-based, but that's fine.
> Cheers,
> Nico
