[MOAB-dev] h5m with data
Nico Schlömer
nico.schloemer at gmail.com
Sun Nov 8 20:01:34 CST 2015
In both ways, actually. I need to build h5m files from data and I need to
extract data from h5m meshes.
With [1], I'm digging my way through understanding the sets group now.
--Nico
[1] https://trac.mcs.anl.gov/projects/ITAPS/wiki/MOAB/h5m
On Mon, Nov 9, 2015 at 2:53 AM Patrick Shriwise <shriwise at wisc.edu> wrote:
> Hi Nico,
> I see. I may have misunderstood your problem. It seems you're trying to
> apply data to the mesh. Is that right?
> Cheers,
> Patrick C. Shriwise
> Research Fellow
> University of Wisconsin - Madison
> Engineering Research Building - Rm. 428
> 1500 Engineering Drive
> Madison, WI 53706
> (608) 446-8173
> On 11/08/15 20:03, Nico Schlömer wrote:
> Thanks Patrick for your reply.
> I'm still having problems where data should be stores. In a h5m file, I
> see tags, I see sets with tags in them, and it seems they are somehow
> related, but I don't know where and how to put the actual data. I would
> help to see a file with some mesh and a custom data element in it, e.g., an
> array of values associated with the vertices.
> Cheers,
> Nico
> On Sun, Nov 8, 2015 at 9:20 PM Patrick Shriwise <shriwise at wisc.edu> wrote:
>> Hi Nico,
>> The vertex data should be stored in MOAB tags. You can access these tags
>> via their name. There is a set of conventions for the tag names in an
>> Exodus file (here
>> <http://ftp.mcs.anl.gov/pub/fathom/moab-docs/MBTagConventions_8hpp.html>
>> I think). However, if the tag has a custom name and isn't recognized by the
>> Exodus reader, then the data might not be read in from the Exodus file and
>> as a result won't be saved into the .h5m. Do you have an idea of what the
>> tag name might be for your data?
>> There's also a good example here
>> <http://ftp.mcs.anl.gov/pub/fathom/moab-docs/SetsNTags_8cpp-example.html>
>> of how to access the tag data on an entity. The example I linked you to
>> accesses EntitySets rather than Entities, but they work the same way.
>> If you think the data might be in the .h5m, you can use
>> tag_get_tags_on_entity
>> <http://ftp.mcs.anl.gov/pub/fathom/moab-docs/classmoab_1_1Interface.html#a6c737e7900d9c1b29b53d994076d204f>
>> to get all of the tags on a vertex and then check for the tag data you're
>> looking for. An easier way of doing this in the cmd line is by using mbsize
>> -t <your_file>.h5m to print out the count by tag.
>> Hope this helps!
>> Cheers,
>> Patrick C. Shriwise
>> Research Fellow
>> Madison, WI 53706
>> (608) 446-8173
>> On 11/08/15 13:43, Nico Schlömer wrote:
>> Hi everyone,
>> I have an Exodus file with vertex data in it (i.e., "a function" defined
>> on the vertices). When converting this file to h5m, where does the vertex
>> data go? And how to I retrieve the data after having it read with
>> `load_file()`?
>> Cheers,
>> Nico
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151109/7c7476bf/attachment.html>
