[MOAB-dev] h5m with data
Patrick Shriwise shriwise at wisc.edu
Sun Nov 8 14:19:37 CST 2015
Hi Nico,
The vertex data should be stored in MOAB tags. You can access these tags
via their name. There is a set of conventions for the tag names in an
Exodus file (here
<http://ftp.mcs.anl.gov/pub/fathom/moab-docs/MBTagConventions_8hpp.html>
I think). However, if the tag has a custom name and isn't recognized by
the Exodus reader, then the data might not be read in from the Exodus
file and as a result won't be saved into the .h5m. Do you have an idea
of what the tag name might be for your data?
There's also a good example here
<http://ftp.mcs.anl.gov/pub/fathom/moab-docs/SetsNTags_8cpp-example.html> of
how to access the tag data on an entity. The example I linked you to
accesses EntitySets rather than Entities, but they work the same way.
If you think the data might be in the .h5m, you can use
tag_get_tags_on_entity
<http://ftp.mcs.anl.gov/pub/fathom/moab-docs/classmoab_1_1Interface.html#a6c737e7900d9c1b29b53d994076d204f>
to get all of the tags on a vertex and then check for the tag data
you're looking for. An easier way of doing this in the cmd line is by
using mbsize -t <your_file>.h5m to print out the count by tag.
Hope this helps!
Cheers,
Patrick C. Shriwise
Research Fellow
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
On 11/08/15 13:43, Nico Schlömer wrote:
> Hi everyone,
> I have an Exodus file with vertex data in it (i.e., "a function"
> defined on the vertices). When converting this file to h5m, where does
> the vertex data go? And how to I retrieve the data after having it
> read with `load_file()`?
> Cheers,
> Nico
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151108/3f2bad4b/attachment.html>
