[MOAB-dev] moab, tpetra::map
    Nico Schlömer
    nico.schloemer at gmail.com
    Mon Nov  2 06:55:25 CST 2015
> Get owned nodes.
Aha, I think `get_entities_by_dimension()` is my friend.
> * Translate a Range into a std::vector. Seems easy given Range's
operator[].
The above function also spits out a std::vector. Nice.
> Get owned plus shared nodes.
That should be easy now. :)
--Nico
On Mon, Nov 2, 2015 at 11:30 AM Nico Schlömer <nico.schloemer at gmail.com>
wrote:
> I would liket to create a Tpetra::Map [1] from a MOAB parallel partition.
> To this end, I need to following:
>  * The notion of global ID of a node. I trust EntityHandle is what I'm
> looking for? EntityID appears to be the index a lot of times, aka, a local
> ID.
> operator[].
>  * Get owned nodes. Get owned plus shared nodes.
>     I'm still not quite familiar on how to best pick out entity sets from
> a pcomm. I see there's `get_pstatus_entities()`, but I don't see a
> PSTATUS_OWNED.
> Cheers,
> Nico
> [1]
> https://trilinos.org/docs/dev/packages/tpetra/doc/html/classTpetra_1_1Map.html
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151102/8543e15d/attachment.html>
