[MOAB-dev] moab, tpetra::map
Nico Schlömer
nico.schloemer at gmail.com
Mon Nov 2 04:30:02 CST 2015
I would liket to create a Tpetra::Map [1] from a MOAB parallel partition.
To this end, I need to following:
* The notion of global ID of a node. I trust EntityHandle is what I'm
looking for? EntityID appears to be the index a lot of times, aka, a local
ID.
* Translate a Range into a std::vector. Seems easy given Range's
operator[].
* Get owned nodes. Get owned plus shared nodes.
I'm still not quite familiar on how to best pick out entity sets from a
pcomm. I see there's `get_pstatus_entities()`, but I don't see a
PSTATUS_OWNED.
Cheers,
Nico
[1]
https://trilinos.org/docs/dev/packages/tpetra/doc/html/classTpetra_1_1Map.html
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151102/4b6bf709/attachment.html>
