[MOAB-dev] boundary nodes on parallel mesh
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Mon Nov 2 00:44:55 CST 2015
Hi Nico,
This is a modified HelloParMOAB example, which it dumps the "true" skin of the model
it can work in parallel, in the sense that even if you load a model in parallel
(mpiexec -np 3 HelloParMOAB <file.h5m> or
mpiexec -np 1 HelloParMOAB <file.h5m>)
will get the same skin in skin.h5m
this example assumes for simplicity that your model has 3d elements
it first computes the skin on each local part, then filters out the faces that are shared with other parts
it puts what is left in a set, then writes in parallel the set (so each processor will write its part of the true skin)
If you want also the edges on the true skin, there is a little more work, but the idea is almost the same.
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Nico Schlömer [nico.schloemer at gmail.com]
Sent: Sunday, November 01, 2015 10:16 PM
To: Timothy Tautges
Cc: moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] boundary nodes on parallel mesh
The issue is not understanding what's supposed to happen, but how to make it happen. I'm sure if I code this myself, I'll make mistakes. Something I could just copy-and-paste would prevent that.
--Nico
On Mon, Nov 2, 2015 at 3:35 AM Timothy Tautges <timothy.tautges at cd-adapco.com<mailto:timothy.tautges at cd-adapco.com>> wrote:
Draw an example out on paper with a ghost layer and mark shared, skin, etc and it will be clear.
On Nov 1, 2015 7:45 PM, "Nico Schlömer" <nico.schloemer at gmail.com<mailto:nico.schloemer at gmail.com>> wrote:
Yes, that would be much appreciated! (I don't understand from the thread [1] what exactly the solution is. People talk about a fork of sorts, shared and owned filtering etc. A piece of code in the FAQs would help.)
By the way, where do I find the FAQs? :)
--Nico
[1] http://lists.mcs.anl.gov/pipermail/moab-dev/2013/005509.html
On Mon, Nov 2, 2015 at 2:40 AM Timothy Tautges <timothy.tautges at cd-adapco.com<mailto:timothy.tautges at cd-adapco.com>> wrote:
Moab folks, this should be put in the faq if it isn't there already.
On Nov 1, 2015 7:38 PM, "Timothy Tautges" <timothy.tautges at cd-adapco.com<mailto:timothy.tautges at cd-adapco.com>> wrote:
I think that's still the way.
- tim
On Nov 1, 2015 7:27 PM, "Nico Schlömer" <nico.schloemer at gmail.com<mailto:nico.schloemer at gmail.com>> wrote:
Hi everyone,
As I'm diving deeper into MOAB, more questions pop up. Right now: I need to loop over the actual physical boundary of a parallel mesh and get the node IDs and their coordinates.
I found an old mailing list thread on the topic [1], but I'm not sure it was conclusive. What's the current best practice here?
Cheers,
Nico
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151102/8a81f53b/attachment-0001.html>
Type: text/x-c++src
Desc: HelloParMOAB.cpp
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151102/8a81f53b/attachment-0001.cpp>
