[MOAB-dev] MOAB insights?
Grindeanu, Iulian R. iulian at mcs.anl.gov
Thu Oct 29 18:39:52 CDT 2015
Hi Nico,
Sorry I missed your message
I modified one of the examples to construct all edges and faces, and output them in some files
after compiling it, you can launch it with
./HelloMOAB
or
./HelloMOAB <other_file>
other_file can be any file that can be loaded in MOAB, in serial (for example, a gmsh file)
for parallel IO, you can look at HelloParMOAB example, or tests in test/parallel
There is a list of examples on doxygen page, with more links on how is data accessed.
http://ftp.mcs.anl.gov/pub/fathom/moab-docs/examples.html
Iulian
Sent: Thursday, October 29, 2015 3:37 PM
To: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] MOAB insights?
Absolutely!
I'm interested to see
 * how I/O works,
 * how edges/faces arecreated,
 * how relationships are queried (Which cells does this face border on? Which nodes does this cell have? etc)
If there's an example in the sources, I'd be more than happy to look at that, too, of course.
Cheers,
Nico
On Thu, Oct 29, 2015 at 9:19 PM Grindeanu, Iulian R. <iulian at mcs.anl.gov<mailto:iulian at mcs.anl.gov>> wrote:
From: Nico Schlömer [nico.schloemer at gmail.com<mailto:nico.schloemer at gmail.com>]
Sent: Thursday, October 29, 2015 12:45 PM
To: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov<mailto:moab-dev at mcs.anl.gov>
> what means long for you, and what is the size of the mesh on one
> rank? what is a cell for you? a polyhedra or a
> tet/hex/prism/quad/triangle?
For me, long means (much) longer than the actual (linear) solver in the end. On a test cube [1] of 140k tets and 27k nodes, creating edges takes about one minutes, faces about two (on one core that is). The linear solver in the end takes about seven seconds.
hmmm, that is too long, indeed.
For moab, creating the edges and/or faces for that size of a mesh is on the order  of seconds, on a laptop
I will write a small example if you are interested
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151029/bc0ceb7c/attachment.html>
Type: text/x-c++src
Desc: HelloMOAB.cpp
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151029/bc0ceb7c/attachment.cpp>
