[MOAB-dev] Matrix3 EigenDecomp Bug
shriwise shriwise at wisc.edu
Tue Aug 18 15:56:38 CDT 2015
Hey all,
After a day or so of working on this, I found an error in the Eigenvalue
decomposition function provided by Matrix3.
I believe that its computation is correct, but the way that it returns
the Eigenvectors is at the very least ambiguous, and I would argue that
it is simply incorrect.
Typically the matrix produced by this decomposition contains the vectors
in a column-based manner, but the vectors are being returned in an array
of CartVects where each CartVect contains a row of the resulting matrix.
The problem being that the solution matrix in this case is indeed column
based. So while the correct information is available, it is returned in
such a way that leads one to believe each CartVect contains one of the
EigenVectors when this is not the case.
I found this by comparing the results of this function to that of a
common linear algebra library, Armadillo.
I've attached the test program I was using if anyone is curious.
Normally, I would simply fix it and create a PR but I'm not quite
certain how to proceed. I think probably the best way is to fix this at
the source in Matrix3.hpp but I don't want any reliant functionality to
be affected without notice. This is a long standing bug affecting the
OBBTree. I'll start working on a fix tomorrow morning, perhaps by
finding anywhere this is used and double checking the use of the
returned Eigenvectors. Does that sound amenable to all?
Cheers,
Patrick C. Shriwise
Research Fellow
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150818/944e7dbe/attachment.cpp>
