[MOAB-dev] error while loading shared libraries: libnetcdf.so.7:
Xu Wu xuwu2 at illinois.edu
Mon Jul 13 23:33:01 CDT 2015
Thanks, Vijay,
It works.
-Xu
On 07/13/2015 11:27 PM, Vijay S. Mahadevan wrote:
> Make sure your HDF5, NetCDF library paths (i.e., paths to
> INSTALL_DIR/lib) are added to your LD_LIBRARY_PATH. This is necessary
> if you are compiling shared libraries.
> Vijay
> On Mon, Jul 13, 2015 at 11:23 PM, Xu Wu <xuwu2 at illinois.edu
> <mailto:xuwu2 at illinois.edu>> wrote:
>     Dear MOAB developers,
>     I was trying to play with MOAB on my own laptop (Ubuntu 14.04).
>     I was able to compile those examples, but when I try to run them
>     the following error occured:
>     However, as you can see above, I do have netcdf libraries
>     installed and they are on the search path for MOAB.
>     I attached the configuration log, the "makefile" in " /examples",
>     as well as the "moab.make" in "/moab-4.8.1/lib/".
>     Thank you,
>     -Xu
Department of Nuclear, Plasma, and Radiological Engineering
University of Illinois Urbana-Champaign
224 Talbot Laboratory
104 South Wright Street
Urbana, IL 61801
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150713/7899890b/attachment-0001.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150713/7899890b/attachment-0001.png>
