[MOAB-dev] error while loading shared libraries: libnetcdf.so.7:
Vijay S. Mahadevan vijay.m at gmail.com
Mon Jul 13 23:27:27 CDT 2015
Make sure your HDF5, NetCDF library paths (i.e., paths to INSTALL_DIR/lib)
are added to your LD_LIBRARY_PATH. This is necessary if you are compiling
shared libraries.
Vijay
On Mon, Jul 13, 2015 at 11:23 PM, Xu Wu <xuwu2 at illinois.edu> wrote:
>  Dear MOAB developers,
> I was trying to play with MOAB on my own laptop (Ubuntu 14.04).
> I was able to compile those examples, but when I try to run them the
> following error occured:
> However, as you can see above, I do have netcdf libraries installed and
> they are on the search path for MOAB.
> I attached the configuration log, the "makefile" in " /examples", as well
> as the "moab.make" in "/moab-4.8.1/lib/".
> Thank you,
> -Xu
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150713/9c1e3aca/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150713/9c1e3aca/attachment-0001.png>
