[MOAB-dev] MOAB debug
    Tim Tautges
    timothy.tautges at cd-adapco.com
    Tue Jun 23 14:46:27 CDT 2015
Sigh; I'm working too hard I guess, I read that 4M as 4B.
- tim
On 06/23/2015 02:37 PM, Grindeanu, Iulian R. wrote:
> yes, but the mesh is only 10 mil/ vertices, hexes, 30 mil quads.
> so it should "work" up to 2B (with integer )
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Tim Tautges [timothy.tautges at cd-adapco.com]
> Sent: Tuesday, June 23, 2015 2:30 PM
> To: moab-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] MOAB debug
> Remember global ids are 32-bit...
> - tim
> On 06/23/2015 02:07 PM, Grindeanu, Iulian R. wrote:
>> hmmm
>> 4194304 = 2048^2
>> From: Kanaev A.A. [kanaev at ibrae.ac.ru]
>> Sent: Tuesday, June 23, 2015 1:57 PM
>> To: Grindeanu, Iulian R.
>> Subject: FW: MOAB debug
>> Here's the test program just in case
>> From: Kanaev A.A.
>> Sent: Tuesday, June 23, 2015 9:49 PM
>> Cc: moab-dev at mcs.anl.gov
>> Subject: RE: MOAB debug
>> Hello Iulian!
>> I've reduced the problem with that mesh to some point.
>> The mesh now contains no sets and no tags except for GLOBAL_ID and PARALLEL_PARTITION tags
>> For every quad i wrote its connectivity nodes global ids as tag NODES with 4 integer variables
>> Then i read the mesh on 1 processor but with PARALLEL=READ_PART option, get connectivity for each quad and check if new connectivity nodes' global ids are equal to what i have in NODES tags
>> I can see that starting from quad 4194304 connectivity is corrupted as can be seen on the screenshot attached
>> Previous tests show that tag data remains uncorrupted but connectivity table somehow shifts if there's PARALLEL=READ_PART option in load_file() function
>> Anton
>> From: Grindeanu, Iulian R. [iulian at mcs.anl.gov]
>> Sent: Monday, June 22, 2015 11:40 PM
>> To: Kanaev A.A.
>> Sorry, I didn't look at this problem.
>> One issue could be with the sets in the file.
>> Do you have many mesh sets?
>> Besides the parallel partition sets?
>> Can you delete the mesh sets that you do not need; probably you will want material sets and neumann sets, but if you have many geometry sets, it could be a problem.
>> to enable debug during reading or writing, you need to pass an option, like
>> -O DEBUG_IO=1 (reading) or -o DEBUG_IO=1 (for writing, with mbconvert)
>> It does not work very well if you run on too many procs, but on < 30 should be OK
>> Iulian
>> Sent: Monday, June 22, 2015 3:26 PM
>> Subject: MOAB debug
>> Actually, the issue is a bit more wider
>> I have a problem with reading that huge mesh with option PARALLEL even on 1 processor, while it doesn't appear for serial load_file
>> Any advices on debugging that?
>> From: Kanaev A.A.
>> Sent: Monday, June 22, 2015 11:22 PM
>> Subject: MOAB debug
>> Hello Iulian, how can i enable debug output like "dbgOut.tprint(1, "Reading all nodes...\n");"?
>> Thanks
>> Anton
> Timothy J. Tautges
> Manager, Directed Meshing, CD-adapco
> Phone: (631) 629-3139 (internal: x29130)
> Mobile/Gvoice: (608) 354-1459
Timothy J. Tautges
