[MOAB-dev] Converting to .h5m from Fluent .msh
Tim Tautges
timothy.tautges at cd-adapco.com
Mon Apr 13 08:14:23 CDT 2015
There are some local functions in ReadCCMIO for creating cells based on faces. Eventually these could be generalized to
a reader helper or API-level class, but only after verifying there's a general enough need for them.
- tim
On 04/13/2015 07:30 AM, Paul Wilson wrote:
> Hi Anton,
> I don't believe that such an option exists. The cells are defined based on canonical ordering of the nodes, so this
> relationship is important. I might not be hard to write a method that would do this for your purposes. There may be
> something useful in the ReadCCMIO reader as well, as Tim suggested.
> Paul
> On 04/10/2015 04:13 PM, Kanaev A.A. wrote:
>> Hello Paul,
>> Thanks for the recommendations!
>> Short question: is there an option in MOAB to create cells from faces, not from nodes?
>> Anton
>> ________________________________________
>> From: Paul Wilson [paul.wilson at wisc.edu]
>> Sent: Thursday, April 09, 2015 5:12 PM
>> To: Kanaev A.A.
>> Subject: Re: [MOAB-dev] Converting to .h5m from Fluent .msh
>> Hello Anton,
>> There are a number of mesh format readers in moab/src/io that might
>> provide a good template. I know of a few different formats that have
>> had features implemented on an as-needed basis, so they are not
>> complete, but provide just enough for what the person needed at the
>> time. For example, I'll take the credit/blame for the ABAQUS reader
>> that only supports a subset of the element types that ABAQUS can generate.
>> Many of the mesh files have very similar formats, so it might make sense
>> to take a look at other readers to see which is the best match to use as
>> a starting point and/or guide.
>> Paul
>> On 04/08/2015 06:44 PM, Kanaev A.A. wrote:
>>> Hello MOAB-dev,
>>> I'm considering writing conversion utility from Fluent .msh to MOAB .h5m
>>> .msh format is:
>>> -nodes declaration
>>> - a list of nodes (x, y, z)
>>> -cells declaration
>>> -faces declaration
>>> - a list of faces (node1, node2, node3, node4, adj cell1, adj cell2)
>>> What should i do next to create mesh from scratch with MOAB?
>>> Thanks,
>>> Anton
>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://go.wisc.edu/pphw-cal
>> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Infrastructure ~ http://aci.wisc.edu
Timothy J. Tautges
Manager, Directed Meshing, CD-adapco
Phone: (631) 629-3139 (internal: x29130)
Mobile/Gvoice: (608) 354-1459
