[MOAB-dev] Converting to .h5m from Fluent .msh
Paul Wilson paul.wilson at wisc.edu
Mon Apr 13 07:30:04 CDT 2015
Hi Anton,
I don't believe that such an option exists.  The cells are defined based
on canonical ordering of the nodes, so this relationship is important.
I might not be hard to write a method that would do this for your
purposes.  There may be something useful in the ReadCCMIO reader as
well, as Tim suggested.
Paul
On 04/10/2015 04:13 PM, Kanaev A.A. wrote:
> Hello Paul,
> Thanks for the recommendations!
> Short question: is there an option in MOAB to create cells from faces, not from nodes?
> Anton
> From: Paul Wilson [paul.wilson at wisc.edu]
> Sent: Thursday, April 09, 2015 5:12 PM
> To: Kanaev A.A.
> Subject: Re: [MOAB-dev] Converting to .h5m from Fluent .msh
> Hello Anton,
> There are a number of mesh format readers in moab/src/io that might
> provide a good template.  I know of a few different formats that have
> had features implemented on an as-needed basis, so they are not
> complete, but provide just enough for what the person needed at the
> time.  For example, I'll take the credit/blame for the ABAQUS reader
> that only supports a subset of the element types that ABAQUS can generate.
> Many of the mesh files have very similar formats, so it might make sense
> to take a look at other readers to see which is the best match to use as
> a starting point and/or guide.
> Paul
> On 04/08/2015 06:44 PM, Kanaev A.A. wrote:
>> Hello MOAB-dev,
>> I'm considering writing conversion utility from Fluent .msh to MOAB .h5m
>> .msh format is:
>> -nodes declaration
>> - a list of nodes (x, y, z)
>> -cells declaration
>> -faces declaration
>> - a list of faces (node1, node2, node3, node4, adj cell1, adj cell2)
>> What should i do next to create mesh from scratch with MOAB?
>> Thanks,
>> Anton
> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://go.wisc.edu/pphw-cal
> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Infrastructure ~ http://aci.wisc.edu
