[MOAB-dev] Installation problem Mac OS Yosemite
    Rajeev Jain
    jain at mcs.anl.gov
    Mon Dec 22 12:09:19 CST 2014
Dear Dr. Graeme Edwards,
We're in the process of releasing a version MOAB that has fixes for building on Yosemite. When this release (4.7.1) is done, I'll have a formula for it.
In the meantime, try this formula:
https://github.com/rajeeja/homebrew-science/blob/master/moab.rb
I've made it work from our nightly tarball. Let me know if you have problems.
Thanks.
Rajeev Jain
630-252-3176 / 630-252-5986 (fax)
jain at mcs.anl.gov
P.S. You might have to use brew edit moab to change the sha, since I'm pointing to nightly tarball.
 From: Graeme Edwards <gedwards812 at googlemail.com>
To: "MOAB-dev at mcs.anl.gov" <MOAB-dev at mcs.anl.gov>
Sent: Sunday, December 21, 2014 4:58 AM
Subject: [MOAB-dev] Installation problem Mac OS Yosemite
Hello,
I have been trying to install MOAB today and am running into problems.  I have been trying to using brew to install moab but have been unsuccessful. When using the suggested command on the website:
brew install https://raw.github.com/rajeeja/homebrew/moab-460/Library/Formula/moab.rb
I have been given the error message below:
Graemes-MacBook-Air:Library graeme$ brew install https://raw.github.com/rajeeja/homebrew/moab-460/Library/Formula/moab.rb
######################################################################## 100.0%
Error: invalid attribute: version
Please report this bug:
    http://git.io/brew-troubleshooting
/usr/local/Library/Homebrew/formula.rb:119:in `block in validate_attributes'
/usr/local/Library/Homebrew/formula.rb:117:in `each'
/usr/local/Library/Homebrew/formula.rb:117:in `validate_attributes'
/usr/local/Library/Homebrew/formula.rb:95:in `initialize'
/usr/local/Library/Homebrew/formulary.rb:50:in `new'
/usr/local/Library/Homebrew/formulary.rb:50:in `get_formula'
/usr/local/Library/Homebrew/formulary.rb:159:in `get_formula'
/usr/local/Library/Homebrew/formulary.rb:198:in `factory'
/usr/local/Library/Homebrew/extend/ARGV.rb:16:in `block in formulae'
/usr/local/Library/Homebrew/extend/ARGV.rb:16:in `map'
/usr/local/Library/Homebrew/extend/ARGV.rb:16:in `formulae'
/usr/local/Library/Homebrew/cmd/install.rb:42:in `install'
/usr/local/Library/brew.rb:136:in `<main>'
Do you have any ideas how I can overcome this issue so that I can start to use Moab.
Thanks is advance.
Regards
Dr Graeme Edwards
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141222/a95a813d/attachment.html>
