[MOAB-dev] Installation problem Mac OS Yosemite
    Graeme Edwards
    gedwards812 at googlemail.com
    Sun Dec 21 04:58:53 CST 2014
Hello,
I have been trying to install MOAB today and am running into problems.  I have been trying to using brew to install moab but have been unsuccessful. When using the suggested command on the website:
brew install https://raw.github.com/rajeeja/homebrew/moab-460/Library/Formula/moab.rb
I have been given the error message below:
Graemes-MacBook-Air:Library graeme$ brew install https://raw.github.com/rajeeja/homebrew/moab-460/Library/Formula/moab.rb
######################################################################## 100.0%
Error: invalid attribute: version
Please report this bug:
    http://git.io/brew-troubleshooting
/usr/local/Library/Homebrew/formula.rb:119:in `block in validate_attributes'
/usr/local/Library/Homebrew/formula.rb:117:in `each'
/usr/local/Library/Homebrew/formula.rb:117:in `validate_attributes'
/usr/local/Library/Homebrew/formula.rb:95:in `initialize'
/usr/local/Library/Homebrew/formulary.rb:50:in `new'
/usr/local/Library/Homebrew/formulary.rb:50:in `get_formula'
/usr/local/Library/Homebrew/formulary.rb:159:in `get_formula'
/usr/local/Library/Homebrew/formulary.rb:198:in `factory'
/usr/local/Library/Homebrew/extend/ARGV.rb:16:in `block in formulae'
/usr/local/Library/Homebrew/extend/ARGV.rb:16:in `map'
/usr/local/Library/Homebrew/extend/ARGV.rb:16:in `formulae'
/usr/local/Library/Homebrew/cmd/install.rb:42:in `install'
/usr/local/Library/brew.rb:136:in `<main>'
Do you have any ideas how I can overcome this issue so that I can start to use Moab.
Thanks is advance.
Regards
Dr Graeme Edwards
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141221/3d3b1b9a/attachment.html>
