[MOAB-dev] DMMoabOutput
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Sat Dec 13 09:13:48 CST 2014
The problem is the type of the tags
Probably the new tags are created with iMesh_createTag() method from iMesh
This method creates sparse tags
(I don't remember why it is not sparse by default; maybe to be more general)
In order to create a dense tag with iMesh, you need to use iMesh extensions method
iMesh_createTagWithOptions
something like
iBase_TagHandle tagh;
iMesh_createTagWithOptions(mesh, "dum", "moab:TAG_STORAGE_TYPE=DENSE", 1, iBase_DOUBLE, &tagh, &err, 3, 27);
With the right options, the tag will be dense, and saved in the entities portion of the h5m file
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Vijay S. Mahadevan [vijay.m at gmail.com]
Sent: Friday, December 12, 2014 10:31 PM
To: Gerd Heber
Cc: MOAB dev
Subject: Re: [MOAB-dev] DMMoabOutput
Gerd, this is possibly a bug in MOAB writer. I'll test your input file
and see if I can replicate the issue on output. DMMoabOutput does not
do anything else explicitly other than calling save on the Core object
itself.
Iulian, can you also take a look at this to see if you can replicate
the issue. I want to make sure that the problem is not just due to
mixed elements + element tag combinations.
Vijay
On Fri, Dec 12, 2014 at 7:24 AM, Gerd Heber <gheber at hdfgroup.org> wrote:
> Maybe I'm doing something stupid, but I see some weird behavior
> from DMMoabOutput. My input mesh is feawd.3.h5m. It has a mixture
> of Hex8 and Prism6 elements. I create a few nodal and element tags and
> call DMMoabOutput to create feawd.out.h5m. The nodal tags look fine,
> but the element tags get written correctly only for the prisms.
> Something gets written for the hex elements, but it gets written in
> the wrong place (under /tstt/tags/ instead of /tstt/elements/Hex8/tags).
> Another indicator that something fishy is going on is that the
> GLOBAL_ID tag has disappeared from Hex8 in the output file.
> Maybe another "protocol error"?
> Thanks for your help.
> G.
