[MOAB-dev] DMMoabOutput
    Gerd Heber
    gheber at hdfgroup.org
    Fri Dec 12 07:24:19 CST 2014
Maybe I'm doing something stupid, but I see some weird behavior
from DMMoabOutput. My input mesh is feawd.3.h5m. It has a mixture
of Hex8 and Prism6 elements. I create a few nodal and element tags and
call DMMoabOutput to create feawd.out.h5m. The nodal tags look fine,
but the element tags get written correctly only for the prisms.
Something gets written for the hex elements, but it gets written in
the wrong place (under /tstt/tags/ instead of /tstt/elements/Hex8/tags).
Another indicator that something fishy is going on is that the
GLOBAL_ID tag has disappeared from Hex8 in the output file.
Maybe another "protocol error"?
Thanks for your help.
G.
Desc: feawd.3.h5m
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141212/a8b8d745/attachment-0002.obj>
Desc: feawd.out.h5m
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141212/a8b8d745/attachment-0003.obj>
