[MOAB-dev] Issue with PyTaps1.4
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Tue Oct 28 17:26:08 CDT 2014
Is your system a Red Hat?
On some of those systems, /usr/local/lib is not in the default path for loading libraries
for example, see this:
http://stackoverflow.com/questions/4743233/is-usr-local-lib-searched-for-shared-libraries
Still, I would install moab somewhere else, especially if you install a development (not released) version.
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Chris Eldred [chris.eldred at gmail.com]
Sent: Tuesday, October 28, 2014 4:52 PM
To: Anthony Scopatz
Cc: MOAB Dev
Subject: Re: [MOAB-dev] Issue with PyTaps1.4
It is in /usr/local/lib, which should be on LD_LIBRARY_PATH.
-Chris
On Tue, Oct 28, 2014 at 3:45 PM, Anthony Scopatz <scopatz at gmail.com<mailto:scopatz at gmail.com>> wrote:
Hi Chris,
Is libiMesh.so on your LD_LIBRARY_PATH?
Be Well
Anthony
On Tue, Oct 28, 2014 at 4:44 PM, Chris Eldred <chris.eldred at gmail.com<mailto:chris.eldred at gmail.com>> wrote:
Not sure if this is the correct location for this query, but I haven't been able to find a mailing address for the PyTaps project.
I am attempting to use the python interface to iTAPS (PyTAPS), but the following issue arises:
>>> import itaps
>>> from itaps import iBase
>>> from itaps import iMesh
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
ImportError: libiMesh.so.0: cannot open shared object file: No such file or directory
I have the latest version of MOAB installed with shared libraries, so it not clear to me why python cannot find the correct shared object file.
Chris Eldred
Chris Eldred
DOE Computational Science Graduate Fellow
Graduate Student, Atmospheric Science, Colorado State University
B.S. Applied Computational Physics, Carnegie Mellon University, 2009
chris.eldred at gmail.com<mailto:chris.eldred at gmail.com> / celdred at atmos.colostate.edu<mailto:celdred at atmos.colostate.edu>
Chris Eldred
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141028/53a197ce/attachment.html>
