[MOAB-dev] Issue with PyTaps1.4
    Anthony Scopatz
    scopatz at gmail.com
    Tue Oct 28 17:01:31 CDT 2014
Hmm can you send the LD_LIBRARY_PATH and LIBRARY_PATH?
On Tue, Oct 28, 2014 at 5:00 PM, Chris Eldred <chris.eldred at gmail.com>
wrote:
> Here are the contents of /usr/local/lib:
> drwxr-sr-x 10 8338 1500    4096 Jul 27  2011 ..
> -rwxr-xr-x  1 root root  386485 Nov 27  2013 libnfft3.so.1.0.0
> lrwxrwxrwx  1 root root      17 Nov 27  2013 libnfft3.so.1 ->
> libnfft3.so.1.0.0
> lrwxrwxrwx  1 root root      17 Nov 27  2013 libnfft3.so ->
> libnfft3.so.1.0.0
> -rwxr-xr-x  1 root root     936 Nov 27  2013 libnfft3.la
> -rw-r--r--  1 root root  512588 Nov 27  2013 libnfft3.a
> drwxr-xr-x  2 root root    4096 Nov 27  2013 pkgconfig
> drwxr-sr-x  4 8338 1500    4096 Mar 11  2014 python2.7
> -rwxr-xr-x  1 root 1500 2695447 Oct 28 14:58 libMOAB.so.0.0.0
> lrwxrwxrwx  1 root 1500      16 Oct 28 14:58 libMOAB.so.0 ->
> libMOAB.so.0.0.0
> lrwxrwxrwx  1 root 1500      16 Oct 28 14:58 libMOAB.so -> libMOAB.so.0.0.0
> -rwxr-xr-x  1 root 1500    1078 Oct 28 14:58 libMOAB.la
> -rw-r--r--  1 root 1500 5203408 Oct 28 14:58 libMOAB.a
> -rwxr-xr-x  1 root 1500  173197 Oct 28 14:58 libiMesh.so.0.0.0
> lrwxrwxrwx  1 root 1500      17 Oct 28 14:58 libiMesh.so.0 ->
> libiMesh.so.0.0.0
> lrwxrwxrwx  1 root 1500      17 Oct 28 14:58 libiMesh.so ->
> libiMesh.so.0.0.0
> -rwxr-xr-x  1 root 1500    1111 Oct 28 14:58 libiMesh.la
> -rw-r--r--  1 root 1500  201020 Oct 28 14:58 libiMesh.a
> -rw-r--r--  1 root 1500    1840 Oct 28 14:58 iMesh-Defs.inc
> -rwxr-xr-x  1 root 1500  102596 Oct 28 14:58 libmbcslam.so.0.0.0
> lrwxrwxrwx  1 root 1500      19 Oct 28 14:58 libmbcslam.so.0 ->
> libmbcslam.so.0.0.0
> lrwxrwxrwx  1 root 1500      19 Oct 28 14:58 libmbcslam.so ->
> libmbcslam.so.0.0.0
> -rwxr-xr-x  1 root 1500    1152 Oct 28 14:58 libmbcslam.la
> -rw-r--r--  1 root 1500  180744 Oct 28 14:58 libmbcslam.a
> -rwxr-xr-x  1 root 1500   99357 Oct 28 14:58 libdagmc.so.0.0.0
> lrwxrwxrwx  1 root 1500      17 Oct 28 14:58 libdagmc.so.0 ->
> libdagmc.so.0.0.0
> lrwxrwxrwx  1 root 1500      17 Oct 28 14:58 libdagmc.so ->
> libdagmc.so.0.0.0
> -rwxr-xr-x  1 root 1500    1036 Oct 28 14:58 libdagmc.la
> -rw-r--r--  1 root 1500  119174 Oct 28 14:58 libdagmc.a
> -rw-r--r--  1 root 1500     112 Oct 28 14:58 moab.config
> drwxr-sr-x  4 8338 1500    4096 Oct 28 14:58 .
> -rw-r--r--  1 root 1500    1993 Oct 28 14:58 moab.make
> -rw-r--r--  1 root 1500    1593 Oct 28 14:58 MOABConfig.cmake
> -Chris
> On Tue, Oct 28, 2014 at 3:59 PM, Chris Eldred <chris.eldred at gmail.com>
> wrote:
>> I get:
>> ldd
>> /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg/itaps/iMesh.so
>>     linux-vdso.so.1 =>  (0x00007fff8ffff000)
>>     libiMesh.so.0 => not found
>>     libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0
>> (0x00007f607df08000)
>>     libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f607db47000)
>>     /lib64/ld-linux-x86-64.so.2 (0x00007f607e35f000)
>> But libiMesh.so.0 exists in /usr/local/lib.
>> -Chris
>> On Tue, Oct 28, 2014 at 3:54 PM, Anthony Scopatz <scopatz at gmail.com>
>> wrote:
>>> What are the results of
>>> ldd
>>> ~/.local/lib/python2.7/site-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg/itaps/iMesh.so
>>> Or similar for your system?
>>> On Tue, Oct 28, 2014 at 4:52 PM, Chris Eldred <chris.eldred at gmail.com>
>>> wrote:
>>>> It is in /usr/local/lib, which should be on LD_LIBRARY_PATH.
>>>> -Chris
>>>> On Tue, Oct 28, 2014 at 3:45 PM, Anthony Scopatz <scopatz at gmail.com>
>>>> wrote:
>>>>> Hi Chris,
>>>>> Is libiMesh.so on your LD_LIBRARY_PATH?
>>>>> Be Well
>>>>> Anthony
>>>>> On Tue, Oct 28, 2014 at 4:44 PM, Chris Eldred <chris.eldred at gmail.com>
>>>>> wrote:
>>>>>> Not sure if this is the correct location for this query, but I
>>>>>> haven't been able to find a mailing address for the PyTaps project.
>>>>>> I am attempting to use the python interface to iTAPS (PyTAPS), but
>>>>>> the following issue arises:
>>>>>> >>> import itaps
>>>>>> >>> from itaps import iBase
>>>>>> >>> from itaps import iMesh
>>>>>> Traceback (most recent call last):
>>>>>>   File "<stdin>", line 1, in <module>
>>>>>> ImportError: libiMesh.so.0: cannot open shared object file: No such
>>>>>> file or directory
>>>>>> I have the latest version of MOAB installed with shared libraries, so
>>>>>> it not clear to me why python cannot find the correct shared object file.
>>>>>> Thanks,
>>>>>> Chris Eldred
>>>>>> Chris Eldred
>>>>>> DOE Computational Science Graduate Fellow
>>>>>> Graduate Student, Atmospheric Science, Colorado State University
>>>>>> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
>>>>>> chris.eldred at gmail.com / celdred at atmos.colostate.edu
>>>> Chris Eldred
>> Chris Eldred
> Chris Eldred
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141028/f1590fe7/attachment-0001.html>
