[MOAB-dev] make check returns error when installing moab
    the lily
    the.1.lily at hotmail.com
    Mon Jul 21 17:32:24 CDT 2014
Hi Vegendla,
Thank you for your help, I installed hdf5 but when I try installing moab I get some errors
here is the output of running ./configure --with-mpi --with-hdf5=/home/user/install/hdf5 --prefix=/home/user/install/moab/bld
checking how to get verbose linking output from mpif90... configure: WARNING: compilation failed
checking for Fortran libraries of mpif90...
checking for dummy main to link with Fortran libraries... none
checking for Fortran name-mangling scheme... configure: error: in `/Users/robabinyahib/Documents/Code/moab-4.6.3':
configure: error: cannot compile a simple Fortran program
See `config.log' for more details
any thoughts of what is going wrong?
thank you.From: svegendla at anl.gov
To: the.1.lily at hotmail.com; moab-dev at mcs.anl.gov
Subject: RE: [MOAB-dev] make check returns error when installing moab
Date: Mon, 21 Jul 2014 13:53:13 +0000
Lily,
You have to install HDF5. The following steps may help you.
#hdf5 install procedure##
> mkdir /home/user/install/hdf5
> cd hdf5
> tar xzf ~/hdf5-1.8.12.tar.gz
> ln -s hdf5-1.8.12 src
> cd bld
> CC=/software/mvapich2-intel-psm-1.9.5/bin/mpicc ../src/configure --enable-shared --prefix=/home/user/install/hdf5
> make
> make install
#MOAB##
>git clone https://bitbucket.org/fathomteam/moab
>cd moab
>autoreconf -fi
>make
>make install
Prasad
From: moab-dev-bounces at mcs.anl.gov [mailto:moab-dev-bounces at mcs.anl.gov]
On Behalf Of the lily
Sent: Monday, July 21, 2014 3:07 AM
To: moab-dev at mcs.anl.gov
Subject: [MOAB-dev] make check returns error when installing moab
Hi everyone,
I keep getting an error when I try to install moab, here are the steps I did and the output for each step,
Step1: ./configure
output:
configure: WARNING:
*            MOAB has been configured w/out the HDF5 library.
*              Support for native file format is disabled!
configure: WARNING:
*           MOAB has been configured w/out the NetCDF library.
*     Support for ExodusII/Genesis and other file formats is disabled!
Step2: make
output:
make[3]: Nothing to be done for `all-am'.
Making all in io
make[3]: Nothing to be done for `all'.
Making all in dual
Making all in obb
Making all in perf
Making all in point_location
make[4]: Nothing to be done for `all'.
make[4]: Nothing to be done for `all-am'.
Making all in dagmc
Making all in oldinc
Making all in doc
make[2]: Nothing to be done for `all'.
./config.status --version | \
  sed -e 's/.*options "\(.*\)"/\1/p' -e 'd' | \
  tr "'" "\n" | \
  sed -e '/^ *$/d' > moab.config
Step3: make check
output:
libtool: link: unrecognized option `-O2'
libtool: link: Try `libtool --help' for more information.
make[4]: *** [ScdMeshF90] Error 1
make[3]: *** [check-am] Error 2
make[2]: *** [check] Error 2
make[1]: *** [check-recursive] Error 1
make: *** [check-recursive] Error 1
I do not know what exactly went wrong, do I need to install any libraries before installing moab?
Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140722/5eb163d6/attachment.html>
