[MOAB-dev] commit/MOAB: iulian07: Merged in iulian07/vtk_polydata (pull request #33)
commits-noreply at bitbucket.org
Mon Jul 14 09:15:47 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/d5336a950414/
Changeset: d5336a950414
Branch: master
User: iulian07
Date: 2014-07-14 16:15:43
Summary: Merged in iulian07/vtk_polydata (pull request #33)
fix vtk polydata reader
Affected #: 5 files
diff --git a/MeshFiles/unittest/io/Makefile.am b/MeshFiles/unittest/io/Makefile.am
index f259b82..2fd6cb3 100644
--- a/MeshFiles/unittest/io/Makefile.am
+++ b/MeshFiles/unittest/io/Makefile.am
@@ -30,5 +30,6 @@ EXTRA_DIST = HommeMapping.nc \
cube.stp \
cylcube.sat \
cylcube.stp \
+ poly8-10.vtk \
gcrm_r3.nc
diff --git a/MeshFiles/unittest/io/poly8-10.vtk b/MeshFiles/unittest/io/poly8-10.vtk
new file mode 100644
index 0000000..3a4d242
--- /dev/null
+++ b/MeshFiles/unittest/io/poly8-10.vtk
@@ -0,0 +1,42 @@
+# vtk DataFile Version 3.0
+MOAB 4.7.0pre
+ASCII
+DATASET POLYDATA
+POINTS 26 double
+3.073901530231682e-06 2.977455744718462e-01 0.000000000000000e+00
+-7.071067811865476e-01 7.071067811865475e-01 0.000000000000000e+00
+-1.715691137876366e-01 3.536798274750831e-01 0.000000000000000e+00
+-4.719776146377113e-01 1.857355490854607e-01 0.000000000000000e+00
+-8.508854127205038e-01 3.599944589578263e-01 0.000000000000000e+00
+2.775557561562891e-16 1.000000000000000e+00 0.000000000000000e+00
+-3.406715072241552e-01 8.588892413936710e-01 0.000000000000000e+00
+1.715662369808998e-01 3.536768053562428e-01 0.000000000000000e+00
+4.719754417201190e-01 1.857347459630188e-01 0.000000000000000e+00
+-4.719756118732749e-01 -1.857348097293946e-01 0.000000000000000e+00
+-1.000000000000000e+00 1.110223024625157e-16 0.000000000000000e+00
+-8.508847507623047e-01 -3.599960570662885e-01 0.000000000000000e+00
+7.071067811865476e-01 7.071067811865476e-01 0.000000000000000e+00
+3.406701269292776e-01 8.588898131305294e-01 0.000000000000000e+00
+8.508845922027242e-01 3.599964398629780e-01 0.000000000000000e+00
+-7.071067811865476e-01 -7.071067811865476e-01 0.000000000000000e+00
+4.719777412790575e-01 -1.857356073815120e-01 0.000000000000000e+00
+7.071067811865472e-01 -7.071067811865477e-01 0.000000000000000e+00
+-3.051853356210140e-16 -1.000000000000000e+00 0.000000000000000e+00
+1.715687253344436e-01 -3.536802010232855e-01 0.000000000000000e+00
+-3.319925237351595e-06 -2.977459818644166e-01 0.000000000000000e+00
+-1.715662714497118e-01 -3.536770586038507e-01 0.000000000000000e+00
+-3.406707216059742e-01 -8.588895668073767e-01 0.000000000000000e+00
+3.406712167592965e-01 -8.588893617081550e-01 0.000000000000000e+00
+1.000000000000000e+00 -2.775557561562891e-17 0.000000000000000e+00
+8.508853951409249e-01 -3.599945013986841e-01 0.000000000000000e+00
+POLYGONS 10 64
+6 21 22 18 23 19 20
+6 20 0 7 8 16 19
+5 10 4 3 9 11
+5 12 13 7 8 14
+5 24 14 8 16 25
+5 21 9 11 15 22
+6 7 0 2 6 5 13
+5 19 23 17 25 16
+5 3 4 1 6 2
+6 21 9 3 2 0 20
diff --git a/src/io/ReadVtk.cpp b/src/io/ReadVtk.cpp
index 2936a85..90b7a41 100644
--- a/src/io/ReadVtk.cpp
+++ b/src/io/ReadVtk.cpp
@@ -685,7 +685,7 @@ ErrorCode ReadVtk::vtk_read_polygons( FileTokenizer& tokens,
if (prev +1 != handle) {
if (first) { // true except for first iteration (first == 0)
- if (first < elem_list.back().front()) // only need new range if order would get mixed up
+ if ( elem_list.empty() || first < elem_list.back().front()) // only need new range if order would get mixed up, or we just began inserting
elem_list.push_back( empty );
elem_list.back().insert( first, prev );
@@ -694,7 +694,7 @@ ErrorCode ReadVtk::vtk_read_polygons( FileTokenizer& tokens,
prev = handle;
if (first) { // true unless no elements (size[0] == 0)
+ if (elem_list.empty() || first < elem_list.back().front()) // only need new range if order would get mixed up, or we just began inserting
diff --git a/test/io/VtkTest.cpp b/test/io/VtkTest.cpp
index d6208a2..076c28b 100644
--- a/test/io/VtkTest.cpp
+++ b/test/io/VtkTest.cpp
@@ -12,6 +12,14 @@ using namespace moab;
#include <algorithm>
#include <sstream>
+#include "TestUtil.hpp"
+#ifdef MESHDIR
+static const char poly_example[] = STRINGIFY(MESHDIR) "/io/poly8-10.vtk";
+#else
+static const char poly_example[] = "poly8-10.vtk";
+#endif
#define DECLARE_TEST(A) \
bool test_ ## A(); \
int A ## _reg_var = register_test( &test_ ## A, #A );
@@ -38,6 +46,7 @@ DECLARE_TEST(quad4)
DECLARE_TEST(quad8)
DECLARE_TEST(quad9)
DECLARE_TEST(polygon)
+DECLARE_TEST(polygon_mix)
DECLARE_TEST(tet4)
DECLARE_TEST(tet10)
DECLARE_TEST(hex8)
@@ -155,7 +164,8 @@ int main( int argc, char* argv[] )
return fail_count;
+// CHECK is defined in TestUtil now
+#undef CHECK
#define CHECK(A) if (is_error((A))) return do_error( #A, __LINE__ )
static bool do_error( const char* string, int line )
@@ -383,6 +393,19 @@ bool test_polygon()
return test_read_write_element( coords, 13, conn, conn, 16, 2, 7, MBPOLYGON );
+bool test_polygon_mix()
+ // just read the polygon file with mixed sequences
+ Core moab;
+ Interface& mb = moab;
+ ErrorCode rval = mb.load_file(poly_example);
+ if (MB_SUCCESS!=rval)
+ return false;
+ return true;
bool test_tet4()
const double coords[] =
diff --git a/tools/size.cpp b/tools/size.cpp
index 7d4311d..737fb00 100644
--- a/tools/size.cpp
+++ b/tools/size.cpp
@@ -169,7 +169,7 @@ static ErrorCode gather_set_stats( EntityHandle set, set_stats& stats )
if (type == MBPOLYGON) {
edge_vtx_idx[0] = e;
- edge_vtx_idx[1] = e+1;
+ edge_vtx_idx[1] = (e+1)%num_edges;
else
CN::SubEntityVertexIndices( type, 1, e, edge_vtx_idx );
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
