[MOAB-dev] commit/MOAB: iulian07: Merged in iulian07/without_hdf5 (pull request #34)
commits-noreply at bitbucket.org
Mon Jul 14 09:14:05 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/fda46ce7dea8/
Changeset: fda46ce7dea8
Branch: master
User: iulian07
Date: 2014-07-14 16:14:00
Summary: Merged in iulian07/without_hdf5 (pull request #34)
configure without hdf5 in parallel fix
Affected #: 6 files
diff --git a/itaps/igeom/Makefile.am b/itaps/igeom/Makefile.am
index 93314d0..28d619d 100644
--- a/itaps/igeom/Makefile.am
+++ b/itaps/igeom/Makefile.am
@@ -27,7 +27,10 @@ libFBiGeomMOAB_la_include_HEADERS = \
FBiGeom_f.h
# stuff for test program
-check_PROGRAMS = testgeom testSmoothGeom testSmooth2
+check_PROGRAMS =
+if HDF5_FILE
+ check_PROGRAMS += testgeom testSmoothGeom testSmooth2
testgeom_SOURCES = testgeom.cc
testgeom_DEPENDENCIES = libFBiGeomMOAB.la \
$(top_builddir)/itaps/imesh/libiMesh.la \
@@ -54,7 +57,9 @@ testSmooth2_LDADD = libFBiGeomMOAB.la \
$(top_builddir)/src/libMOAB.la \
${MOAB_CXX_LINKFLAGS} ${MOAB_CXX_LIBS}
+endif
TESTS = $(check_PROGRAMS)
# Automake doesn't seem to have a directory defined for
diff --git a/itaps/imesh/Makefile.am b/itaps/imesh/Makefile.am
index 647b8c1..06e2c50 100644
--- a/itaps/imesh/Makefile.am
+++ b/itaps/imesh/Makefile.am
@@ -37,7 +37,9 @@ if PARALLEL
AM_CPPFLAGS += -I$(top_srcdir)/src/parallel -I$(top_srcdir)/src/parallel/moab
# check_PROGRAMS += partest iMeshP_unit_tests moabtest
- check_PROGRAMS += partest MOAB_iMeshP_unit_tests
+if PARALLEL_HDF5
+ check_PROGRAMS += MOAB_iMeshP_unit_tests partest
+endif
# moabtest_SOURCES = moabtest.F
# check_PROGRAMS += ftest
diff --git a/src/parallel/ParallelComm.cpp b/src/parallel/ParallelComm.cpp
index 10ce709..886ef77 100644
--- a/src/parallel/ParallelComm.cpp
+++ b/src/parallel/ParallelComm.cpp
@@ -8143,9 +8143,11 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
if (MB_SUCCESS != result && print_em) {
+#ifdef HDF5_FILE
std::ostringstream ent_str;
ent_str << "mesh." << procConfig.proc_rank() << ".h5m";
mbImpl->write_mesh(ent_str.str().c_str());
+#endif
return result;
diff --git a/test/io/read_gcrm_nc.cpp b/test/io/read_gcrm_nc.cpp
index c4a2290..b079574 100644
--- a/test/io/read_gcrm_nc.cpp
+++ b/test/io/read_gcrm_nc.cpp
@@ -71,8 +71,6 @@ void test_read_all()
ErrorCode rval = mb.load_file(example, 0, opts.c_str());
CHECK_ERR(rval);
- mb.write_file("gcrm.h5m");
int procs = 1;
#ifdef USE_MPI
ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
diff --git a/test/parallel/Makefile.am b/test/parallel/Makefile.am
index b42ba0b..4d7705b 100644
--- a/test/parallel/Makefile.am
+++ b/test/parallel/Makefile.am
@@ -31,8 +31,6 @@ if USE_MPIEXEC
endif
TESTS = pcomm_unit \
- parallel_unit_tests \
- uber_parallel_test \
scdtest \
pcomm_serial \
par_spatial_locator_test \
@@ -42,7 +40,9 @@ TESTS = pcomm_unit \
$(MBCSLAM_TESTS)
if PARALLEL_HDF5
- HDF5_TESTS = parallel_hdf5_test mhdf_parallel parallel_write_test
+ HDF5_TESTS = parallel_hdf5_test mhdf_parallel parallel_write_test \
+ parallel_unit_tests \
+ uber_parallel_test
else
HDF5_TESTS =
endif
@@ -61,19 +61,31 @@ else
endif
endif
if ENABLE_mbcoupler
+if PARALLEL_HDF5
COUPLER_TESTS = par_coupler_test
else
COUPLER_TESTS =
+endif
+else
+ COUPLER_TESTS =
endif
if ENABLE_mbcslam
+if PARALLEL_HDF5
MBCSLAM_TESTS = par_intx_sph
else
+ MBCSLAM_TESTS =
+endif
+else
MBCSLAM_TESTS =
endif
-check_PROGRAMS = $(TESTS) mbparallelcomm_test partcheck structured3 parmerge
+check_PROGRAMS = $(TESTS) mbparallelcomm_test partcheck structured3
+if PARALLEL_HDF5
+ check_PROGRAMS += parmerge
+endif
pcomm_unit_SOURCES = pcomm_unit.cpp
parallel_hdf5_test_SOURCES = parallel_hdf5_test.cc
diff --git a/test/parallel/ucdtrvpart.cpp b/test/parallel/ucdtrvpart.cpp
index cdd5e70..062f1c1 100644
--- a/test/parallel/ucdtrvpart.cpp
+++ b/test/parallel/ucdtrvpart.cpp
@@ -128,8 +128,10 @@ void test_read_parallel(int num_verts, bool test_nb_nodes)
CHECK_EQUAL(total_verts, num_verts);
+#ifdef HDF5_PARALLEL
std::string write_options("PARALLEL=WRITE_PART;");
mb.write_file("test.h5m", NULL, write_options.c_str());
+#endif
void test_multiple_loads_of_same_file()
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
