[MOAB-dev] commit/MOAB: 3 new changesets
    commits-noreply at bitbucket.org
    Sun Jul 13 13:56:17 CDT 2014
3 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/b79528d925af/
Changeset:   b79528d925af
Branch:      None
User:        vijaysm
Date:        2014-07-13 20:55:01
Summary:     Making an API change to estimate the memory usage in all of the MOAB routines: changing long to long long
Affected #:  10 files
diff --git a/src/AEntityFactory.cpp b/src/AEntityFactory.cpp
index e29df97..650ad49 100644
--- a/src/AEntityFactory.cpp
+++ b/src/AEntityFactory.cpp
@@ -1473,8 +1473,8 @@ ErrorCode AEntityFactory::set_adjacency_ptr( EntityHandle entity,
-void AEntityFactory::get_memory_use( unsigned long& entity_total,
-                                     unsigned long& memory_total )
+void AEntityFactory::get_memory_use( unsigned long long& entity_total,
+                                     unsigned long long& memory_total )
   entity_total = memory_total = 0;
@@ -1506,8 +1506,8 @@ void AEntityFactory::get_memory_use( unsigned long& entity_total,
 ErrorCode AEntityFactory::get_memory_use( const Range& ents_in,
-                                       unsigned long& min_per_ent,
-                                       unsigned long& amortized )
+                                       unsigned long long& min_per_ent,
+                                       unsigned long long& amortized )
   min_per_ent = amortized = 0;
   SequenceData* prev_data = 0;
diff --git a/src/AEntityFactory.hpp b/src/AEntityFactory.hpp
index 5d3c3f3..c84a0d3 100644
--- a/src/AEntityFactory.hpp
+++ b/src/AEntityFactory.hpp
@@ -163,11 +163,11 @@ public:
   ErrorCode merge_adjust_adjacencies(EntityHandle entity_to_keep,
                                        EntityHandle entity_to_remove);
-  void get_memory_use( unsigned long& total_entity_storage,
-                       unsigned long& total_storage );
+  void get_memory_use( unsigned long long& total_entity_storage,
+                       unsigned long long& total_storage );
   ErrorCode get_memory_use( const Range& entities,
-                              unsigned long& total_entity_storage,
-                              unsigned long& total_amortized_storage );
+                              unsigned long long& total_entity_storage,
+                              unsigned long long& total_amortized_storage );
 private:
diff --git a/src/AdaptiveKDTree.cpp b/src/AdaptiveKDTree.cpp
index 4b104b4..f629cc4 100644
--- a/src/AdaptiveKDTree.cpp
+++ b/src/AdaptiveKDTree.cpp
@@ -2154,7 +2154,7 @@ namespace moab {
       all.merge( elem2d );
       all.merge( elem3d );
       tree_sets.insert( myRoot );
-      unsigned long set_used, set_amortized, set_store_used, set_store_amortized,
+      unsigned long long set_used, set_amortized, set_store_used, set_store_amortized,
           set_tag_used, set_tag_amortized, elem_used, elem_amortized;
       moab()->estimated_memory_use( tree_sets,
                                        &set_used, &set_amortized,
diff --git a/src/Core.cpp b/src/Core.cpp
index 0bd882f..620c2dd 100644
--- a/src/Core.cpp
+++ b/src/Core.cpp
@@ -3851,22 +3851,22 @@ ErrorCode Core::get_set_iterators(EntityHandle meshset,
 void Core::estimated_memory_use_internal( const Range* ents,
-                                  unsigned long* total_storage,
-                                  unsigned long* total_amortized_storage,
-                                  unsigned long* entity_storage,
-                                  unsigned long* amortized_entity_storage,
-                                  unsigned long* adjacency_storage,
-                                  unsigned long* amortized_adjacency_storage,
+                                  unsigned long long* total_storage,
+                                  unsigned long long* total_amortized_storage,
+                                  unsigned long long* entity_storage,
+                                  unsigned long long* amortized_entity_storage,
+                                  unsigned long long* adjacency_storage,
+                                  unsigned long long* amortized_adjacency_storage,
                                   const Tag* tag_array,
                                   unsigned num_tags,
-                                  unsigned long* tag_storage,
-                                  unsigned long* amortized_tag_storage )
+                                  unsigned long long* tag_storage,
+                                  unsigned long long* amortized_tag_storage )
     // Figure out which values we need to calulate
-  unsigned long i_entity_storage,    ia_entity_storage,
+  unsigned long long i_entity_storage,    ia_entity_storage,
                 i_adjacency_storage, ia_adjacency_storage,
                 i_tag_storage,       ia_tag_storage;
-  unsigned long *total_tag_storage = 0,
+  unsigned long long *total_tag_storage = 0,
                 *amortized_total_tag_storage =0;
   if (!tag_array) {
     total_tag_storage = tag_storage;
@@ -3998,16 +3998,16 @@ void Core::estimated_memory_use_internal( const Range* ents,
 void  Core::estimated_memory_use( const EntityHandle* ent_array,
                                     unsigned long num_ents,
                                     unsigned num_tags,
   Range range;
@@ -4035,16 +4035,16 @@ void  Core::estimated_memory_use( const EntityHandle* ent_array,
 void Core::estimated_memory_use( const Range& ents,
                                    unsigned num_tags,
   estimated_memory_use_internal( &ents,
                          total_storage,     total_amortized_storage,
diff --git a/src/SequenceManager.cpp b/src/SequenceManager.cpp
index f896cf2..8ca1755 100644
--- a/src/SequenceManager.cpp
+++ b/src/SequenceManager.cpp
@@ -767,13 +767,13 @@ SequenceManager::replace_subsequence( EntitySequence* new_seq )
   return typeData[type].replace_subsequence( new_seq, &tagSizes[0], tagSizes.size() );
-void SequenceManager::get_memory_use( unsigned long& total_entity_storage,
-                                      unsigned long& total_storage ) const
+void SequenceManager::get_memory_use( unsigned long long& total_entity_storage,
+                                      unsigned long long& total_storage ) const
   total_entity_storage = 0;
   total_storage = 0;
-  unsigned long temp_entity, temp_total;
+  unsigned long long temp_entity, temp_total;
   for (EntityType i = MBVERTEX; i < MBMAXTYPE; ++i) {
     temp_entity = temp_total = 0;
     get_memory_use( i, temp_entity, temp_total );
@@ -783,19 +783,19 @@ void SequenceManager::get_memory_use( unsigned long& total_entity_storage,
 void SequenceManager::get_memory_use( EntityType type,
   typeData[type].get_memory_use( total_entity_storage, total_storage );
 void SequenceManager::get_memory_use( const Range& entities,
-                                      unsigned long& total_amortized_storage ) const
+                                      unsigned long long& total_amortized_storage ) const
   total_amortized_storage = 0;
   Range::const_pair_iterator i;
   for (i = entities.const_pair_begin(); i != entities.const_pair_end(); ++i) {
     const EntityType t1 = TYPE_FROM_HANDLE(i->first);
diff --git a/src/SequenceManager.hpp b/src/SequenceManager.hpp
index 50b1010..be70710 100644
--- a/src/SequenceManager.hpp
+++ b/src/SequenceManager.hpp
@@ -236,16 +236,16 @@ class SequenceManager
     const TypeSequenceManager& entity_map( EntityType type ) const
       { return typeData[type]; }
-                         unsigned long& total_storage ) const;
+                         unsigned long long& total_storage ) const;
     void get_memory_use( EntityType type,
     void get_memory_use( const Range& entities,
-                         unsigned long& total_amortized_storage ) const;
+                         unsigned long long& total_amortized_storage ) const;
diff --git a/src/TypeSequenceManager.cpp b/src/TypeSequenceManager.cpp
index 50d6ef6..59f1d42 100644
--- a/src/TypeSequenceManager.cpp
+++ b/src/TypeSequenceManager.cpp
@@ -807,8 +807,8 @@ ErrorCode TypeSequenceManager::notify_prepended( iterator seq )
   return rval;
-void TypeSequenceManager::get_memory_use( unsigned long& entity_storage,
+void TypeSequenceManager::get_memory_use( unsigned long long& entity_storage,
   entity_storage = total_storage = 0;
   if (empty())
@@ -825,8 +825,8 @@ void TypeSequenceManager::get_memory_use( unsigned long& entity_storage,
 void TypeSequenceManager::append_memory_use( EntityHandle first,
                                              EntityHandle last,
                                              const SequenceData* data,
-                                             unsigned long& entity_storage,
+                                             unsigned long long& entity_storage,
   const unsigned long allocated_count = data->size();
@@ -865,8 +865,8 @@ void TypeSequenceManager::append_memory_use( EntityHandle first,
 void TypeSequenceManager::get_memory_use( EntityHandle first,
                                           EntityHandle last,
diff --git a/src/TypeSequenceManager.hpp b/src/TypeSequenceManager.hpp
index f69bf15..bbc89fd 100644
--- a/src/TypeSequenceManager.hpp
+++ b/src/TypeSequenceManager.hpp
@@ -75,8 +75,8 @@ private:
   void append_memory_use( EntityHandle first,
                           EntityHandle last,
     // check if sequence at passed iterator should be merged with
     // the subsequent sequence, and if so merge them retaining i.
@@ -332,12 +332,12 @@ public:
   ErrorCode notify_appended( iterator seq );
   void get_memory_use( EntityHandle start, EntityHandle end,
   unsigned long get_sequence_count() const
     { return sequenceSet.size(); }
diff --git a/src/moab/Core.hpp b/src/moab/Core.hpp
index aa7d9da..d767226 100644
--- a/src/moab/Core.hpp
+++ b/src/moab/Core.hpp
@@ -1224,16 +1224,16 @@ public:
   void estimated_memory_use( const EntityHandle* ent_array = 0,
                              unsigned long  num_ents = 0,
-                             unsigned long* total_storage = 0,
-                             unsigned long* total_amortized_storage = 0,
-                             unsigned long* entity_storage = 0,
-                             unsigned long* amortized_entity_storage = 0,
-                             unsigned long* adjacency_storage = 0,
-                             unsigned long* amortized_adjacency_storage = 0,
+                             unsigned long long* total_storage = 0,
+                             unsigned long long* total_amortized_storage = 0,
+                             unsigned long long* entity_storage = 0,
+                             unsigned long long* amortized_entity_storage = 0,
+                             unsigned long long* adjacency_storage = 0,
+                             unsigned long long* amortized_adjacency_storage = 0,
                              const Tag*   tag_array = 0,
                              unsigned       num_tags = 0,
-                             unsigned long* tag_storage = 0,
-                             unsigned long* amortized_tag_storage = 0 );
+                             unsigned long long* tag_storage = 0,
+                             unsigned long long* amortized_tag_storage = 0 );
   /**\brief Calculate amount of memory used to store MOAB data
@@ -1262,16 +1262,16 @@ public:
    *                   all tags.
   void estimated_memory_use( const Range& ents,
   void print_database() const;
@@ -1284,16 +1284,16 @@ private:
   Core& operator=( const Core& copy );
   void estimated_memory_use_internal( const Range* ents,
                             unsigned       num_tags,
-                            unsigned long* amortized_tag_storage );
+                            unsigned long long* amortized_tag_storage );
     //! database init and de-init routines
   ErrorCode initialize();
diff --git a/src/moab/Interface.hpp b/src/moab/Interface.hpp
index 09f4219..88ce232 100644
--- a/src/moab/Interface.hpp
+++ b/src/moab/Interface.hpp
@@ -1043,16 +1043,16 @@ public:
   virtual void estimated_memory_use( const EntityHandle* ent_array = 0,
-                             unsigned long* amortized_tag_storage = 0 ) = 0;
+                             unsigned long long* amortized_tag_storage = 0 ) = 0;
@@ -1082,16 +1082,16 @@ public:
    *                   for all tags.
   virtual void estimated_memory_use( const Range& ents,
     /** \name Higher-order elements */
https://bitbucket.org/fathomteam/moab/commits/2c9939708a03/
Changeset:   2c9939708a03
Branch:      None
User:        vijaysm
Date:        2014-07-13 20:55:27
Summary:     Modifying the mbmem (memory estimator) tool to use the new API
Affected #:  1 file
diff --git a/tools/mbmem.cpp b/tools/mbmem.cpp
index a881fcd..538abca 100644
--- a/tools/mbmem.cpp
+++ b/tools/mbmem.cpp
@@ -116,14 +116,14 @@ int main( int argc, char* argv[] )
   // struct to store memory stats
 struct MemStats {
-  unsigned long total_storage;
-  unsigned long total_amortized;
-  unsigned long entity_storage;
-  unsigned long entity_amortized;
-  unsigned long adjacency_storage;
-  unsigned long adjacency_amortized;
-  unsigned long tag_storage;
-  unsigned long tag_amortized;
+  unsigned long long total_storage;
+  unsigned long long total_amortized;
+  unsigned long long entity_storage;
+  unsigned long long entity_amortized;
+  unsigned long long adjacency_storage;
+  unsigned long long adjacency_amortized;
+  unsigned long long tag_storage;
+  unsigned long long tag_amortized;
  // test if MemStats object indicates no memory
@@ -136,7 +136,7 @@ static void get_mem_stats( moab::Interface& mb,
                            moab::EntityType type = moab::MBMAXTYPE );
   // Formatted string representation of memory size value
-static std::string memstr( unsigned long val );
+static std::string memstr( unsigned long long val );
   // Get string describing tag data type
 static std::string tag_type_string( moab::Interface& mb, moab::Tag tag );
@@ -244,7 +244,7 @@ void print_memory_stats( moab::Interface& mb,
       if (moab::MB_SUCCESS != rval || name.empty())
         name = ANON_TAG_NAME;
-      unsigned long occupied, allocated;
+      unsigned long long occupied, allocated;
       mb.estimated_memory_use( 0, 0, 0, 0, 0, 0, 0, 0, &*ti, 1, &occupied, &allocated );
       std::cout << std::left << std::setw(maxlen) << name << ' '
@@ -270,8 +270,8 @@ void print_memory_stats( moab::Interface& mb,
   if (sysstats) {
     std::FILE* filp = std::fopen("/proc/self/stat", "r");
-    unsigned long vsize;
-    long rss;
+    unsigned long long vsize;
+    long long rss;
     if (filp && 2 == std::fscanf(filp,
                   "%*d " // pid
                   "%*s " // comm
@@ -295,8 +295,8 @@ void print_memory_stats( moab::Interface& mb,
                   "%*d " // num_threads
                   "%*d " // itrealvalue
                   "%*u " // starttime
-                  "%lu " // vsize
-                  "%ld", // rss
+                  "%llu " // vsize
+                  "%lld", // rss
                   &vsize, &rss )) {
   #ifndef _MSC_VER
       rss *= getpagesize();
@@ -313,7 +313,7 @@ void print_memory_stats( moab::Interface& mb,
         std::cerr << "getrusage failed" << std::endl;
       else {
-        long int tmp_rss = sysdata.ru_maxrss;
+        long long int tmp_rss = sysdata.ru_maxrss;
         std::cerr << std::endl << "SYSTEM:"
                   << std::endl << "Resident set size: " << memstr(tmp_rss)
@@ -360,17 +360,17 @@ void get_mem_stats( moab::Interface& mb,
 // rounded division
-static unsigned long rdiv( unsigned long num, unsigned long den )
+static unsigned long long rdiv( unsigned long long num, unsigned long long den )
   return (num + den/2) / den;
-std::string memstr( unsigned long val )
+std::string memstr( unsigned long long val )
-  const unsigned long kb = 1024;
-  const unsigned long mb = kb*kb;
-  const unsigned long gb = kb*mb;
-  const unsigned long tb = kb*gb;
+  const unsigned long long kb = 1024;
+  const unsigned long long mb = kb*kb;
+  const unsigned long long gb = kb*mb;
+  const unsigned long long tb = kb*gb;
   std::ostringstream s;
   if (UNITS == HUMAN) {
@@ -388,7 +388,7 @@ std::string memstr( unsigned long val )
       s << "0  ";
   else {
-    unsigned long den = 1;
+    unsigned long long den = 1;
     switch (UNITS) {
       case BYTES: den = 1; break;
       case KILOBYTES: den = kb; break;
https://bitbucket.org/fathomteam/moab/commits/f24cd5db25f9/
Changeset:   f24cd5db25f9
Branch:      vijaysm/memory_api_llu
User:        vijaysm
Date:        2014-07-13 20:55:50
Summary:     Fixing all the tests to conform to the new long long API change
Affected #:  4 files
diff --git a/test/MBTest.cpp b/test/MBTest.cpp
index d70753f..3b6795c 100644
--- a/test/MBTest.cpp
+++ b/test/MBTest.cpp
@@ -6044,7 +6044,7 @@ ErrorCode mb_poly_adjacency_test2()
 ErrorCode mb_memory_use_test()
   Core mb;
-  unsigned long init_total, total_with_elem, total_with_tag, total_with_tag_data;
+  unsigned long long init_total, total_with_elem, total_with_tag, total_with_tag_data;
   mb.estimated_memory_use(0,0,0,&init_total);
   double coords[12] = { 1, 2, 0, 3, 4, 0, 5, 6, 0, 7, 8, 0 };
@@ -6060,7 +6060,7 @@ ErrorCode mb_memory_use_test()
   if (total_with_elem <= init_total)
     return MB_FAILURE;
-  unsigned long min, am;
+  unsigned long long min, am;
   Range r;
   r.insert( elem );
   mb.estimated_memory_use( r, &min, &am );
diff --git a/test/kd_tree_time.cpp b/test/kd_tree_time.cpp
index 9c34430..ecc3024 100644
--- a/test/kd_tree_time.cpp
+++ b/test/kd_tree_time.cpp
@@ -19,7 +19,7 @@ void print_file_stats(Interface& moab)
   ErrorCode rval;
   int num_tri;
   Range sets;
-  unsigned long set_mem, set_am, tag_mem, tag_am;
+  unsigned long long set_mem, set_am, tag_mem, tag_am;
   rval = moab.get_number_entities_by_type(0, MBTRI, num_tri);
   if (MB_SUCCESS != rval)
@@ -31,8 +31,8 @@ void print_file_stats(Interface& moab)
   moab.estimated_memory_use(sets, 0, 0, &set_mem, &set_am, 0, 0, 0, 0, &tag_mem, &tag_am);
   printf("Triangles:   %d\n", num_tri);
   printf("Sets:        %lu\n", (unsigned long)sets.size());
-  printf("Set storage: %lu (%lu)\n", set_mem, set_am);
-  printf("Tag storage: %lu (%lu)\n", tag_mem, tag_am);
+  printf("Set storage: %llu (%llu)\n", set_mem, set_am);
+  printf("Tag storage: %llu (%llu)\n", tag_mem, tag_am);
 int main(int argc, char* argv[])
diff --git a/test/obb/obb_tree_tool.cpp b/test/obb/obb_tree_tool.cpp
index f6fb539..bb76d88 100644
--- a/test/obb/obb_tree_tool.cpp
+++ b/test/obb/obb_tree_tool.cpp
@@ -60,10 +60,10 @@ static void usage( bool err = true )
 #if defined(_MSC_VER)  || defined(__MINGW32__)
-static void memory_use( unsigned long& vsize, unsigned long& rss )
+static void memory_use( unsigned long long& vsize, unsigned long long& rss )
   { vsize = rss = 0; }
 #else
   char buffer[512];
   int filp = open( "/proc/self/stat", O_RDONLY );
@@ -80,7 +80,7 @@ static void memory_use( unsigned long& vsize, unsigned long& rss )
                   "%*u %*u %*d %*d " // utime stime cutime cstime
                   "%*d %*d %*d "      // priority nice (unused)
                   "%*d %*u "           // itrealval starttime
-                  "%lu %lu",             &vsize, &rss );
+                  "%llu %llu",             &vsize, &rss );
 #endif
@@ -374,7 +374,7 @@ void print_stats( Interface* interface )
   interface->get_entities_by_type( 0, MBVERTEX, verts );
   triangles.merge( verts );
   tree_sets.insert( root );
                 set_tag_used, set_tag_amortized, tri_used, tri_amortized;
   interface->estimated_memory_use( tree_sets,
@@ -388,7 +388,7 @@ void print_stats( Interface* interface )
   tool.stats( root, std::cout );
-  unsigned long real_rss, real_vsize;
+  unsigned long long real_rss, real_vsize;
   memory_use( real_vsize, real_rss );
   printf("------------------------------------------------------------------\n");
diff --git a/test/perf/point_location/point_location.cpp b/test/perf/point_location/point_location.cpp
index 4f5ddcc..39fde21 100644
--- a/test/perf/point_location/point_location.cpp
+++ b/test/perf/point_location/point_location.cpp
@@ -143,7 +143,7 @@ int main( int argc, char* argv[] )
     // GET MEMORY USE BEFORE BUILDING TREE
-  unsigned long init_total_storage;
+  unsigned long long init_total_storage;
   mb.estimated_memory_use( 0, 0, &init_total_storage );
     // RUN TIMING TEST
@@ -159,7 +159,7 @@ int main( int argc, char* argv[] )
       break;
-  unsigned long fini_total_storage;
+  unsigned long long fini_total_storage;
   mb.estimated_memory_use( 0, 0, &fini_total_storage );
     // VALIDATE RESULTS
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
