[MOAB-dev] commit/MOAB: 3 new changesets
    commits-noreply at bitbucket.org
    Fri Jul 11 19:07:30 CDT 2014
3 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/f6bf2e4501ce/
Changeset:   f6bf2e4501ce
Branch:      None
User:        vijaysm
Date:        2014-07-12 02:05:35
Summary:     Fix warnings shown by PGI compilers
Affected #:  5 files
diff --git a/src/FBEngine.cpp b/src/FBEngine.cpp
index b2f1d19..7f4a8a6 100644
--- a/src/FBEngine.cpp
+++ b/src/FBEngine.cpp
@@ -1979,7 +1979,6 @@ ErrorCode FBEngine::BreakTriangle2(EntityHandle tri, EntityHandle e1, EntityHand
     _newTriangles.insert(newTriangle);
     if (debug_splits)
       print_debug_triangle(newTriangle);
-    return MB_SUCCESS;
   else if (MBVERTEX == et2)
@@ -2004,7 +2003,6 @@ ErrorCode FBEngine::BreakTriangle2(EntityHandle tri, EntityHandle e1, EntityHand
     if (debug_splits)
   else
@@ -2071,7 +2069,6 @@ ErrorCode FBEngine::BreakTriangle2(EntityHandle tri, EntityHandle e1, EntityHand
     if (debug_splits)
   return MB_SUCCESS;
@@ -2769,8 +2766,7 @@ ErrorCode FBEngine::split_boundary(EntityHandle face, EntityHandle atNode)
         _mbImpl->id_from_handle(atNode) << "\n";
   Range bound_edges;
-  ErrorCode rval = getAdjacentEntities(face, 1, bound_edges);
-  MBERRORR(rval, " can't get boundary edges");
+  ErrorCode rval = getAdjacentEntities(face, 1, bound_edges);MBERRORR(rval, " can't get boundary edges");
   bool brokEdge = _brokenEdges.find(atNode)!=_brokenEdges.end();
   for (Range::iterator it =bound_edges.begin(); it!=bound_edges.end(); it++ )
@@ -2779,8 +2775,7 @@ ErrorCode FBEngine::split_boundary(EntityHandle face, EntityHandle atNode)
     // get all edges in range
     Range mesh_edges;
     rval = _mbImpl->get_entities_by_dimension(b_edge, 1,
-        mesh_edges);
-    MBERRORR(rval, " can't get mesh edges");
+        mesh_edges);MBERRORR(rval, " can't get mesh edges");
     if (brokEdge)
       EntityHandle brokenEdge = _brokenEdges[atNode];
@@ -2794,8 +2789,7 @@ ErrorCode FBEngine::split_boundary(EntityHandle face, EntityHandle atNode)
     else
       Range nodes;
-      rval = _mbImpl->get_connectivity(mesh_edges, nodes);
-      MBERRORR(rval, " can't get nodes from mesh edges");
+      rval = _mbImpl->get_connectivity(mesh_edges, nodes);MBERRORR(rval, " can't get nodes from mesh edges");
       if (nodes.find(atNode)!=nodes.end())
@@ -2809,7 +2803,6 @@ ErrorCode FBEngine::split_boundary(EntityHandle face, EntityHandle atNode)
   // if the node was not found in any "current" boundary, it broke an existing
   // boundary edge
   MBERRORR(MB_FAILURE, " we did not find an appropriate boundary edge"); ; //
-  return MB_FAILURE; // needed to suppress compile warning
 bool FBEngine::find_vertex_set_for_node(EntityHandle iNode, EntityHandle & oVertexSet)
diff --git a/src/Skinner.cpp b/src/Skinner.cpp
index 02acf2c..f9c092e 100644
--- a/src/Skinner.cpp
+++ b/src/Skinner.cpp
@@ -1228,7 +1228,7 @@ public:
         default:
           assert(false);
           break;
-        case 4: handles[2] = array[(idx+3)%CORNERS];
+        case 4: handles[2] = array[(idx+3)%CORNERS]; // TODO: This is a violation if CORNERS=3
         case 3: handles[1] = array[(idx+2)%CORNERS];
         case 2: handles[0] = array[(idx+1)%CORNERS];
@@ -1256,7 +1256,7 @@ public:
         default:
           assert(false);
           break;
-        case 4: handles[2] = array[indices[(idx+3)%CORNERS]];
+        case 4: handles[2] = array[indices[(idx+3)%CORNERS]]; // TODO: Violation for instantiation with CORNERS=3
         case 3: handles[1] = array[indices[(idx+2)%CORNERS]];
         case 2: handles[0] = array[indices[(idx+1)%CORNERS]];
@@ -1277,7 +1277,7 @@ public:
         case 4:
           return handles[0] == other.handles[0]
               && handles[1] == other.handles[1]
-              && handles[2] == other.handles[2];
+              && handles[2] == other.handles[2]; // TODO: VSM: Again a violation for instantiation with CORNERS=3 -- Fix this bad code
         case 3:
               && handles[1] == other.handles[1];
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 613ce13..8ff0aed 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -1084,7 +1084,6 @@ ErrorCode ScdNCHelper::read_scd_variables_to_nonset_allocate(std::vector<ReadNC:
       case ReadNC::ENTLOCEWEDGE:
       case ReadNC::ENTLOCEDGE:
         ERRORR(MB_NOT_IMPLEMENTED, "Reading edge data not implemented yet.");
-        break;
       case ReadNC::ENTLOCFACE:
         // Faces
         vdatas[i].readStarts[2] = lCDims[1];
diff --git a/src/moab/BVHTree.hpp b/src/moab/BVHTree.hpp
index eb0e4e4..3eab2d8 100644
--- a/src/moab/BVHTree.hpp
+++ b/src/moab/BVHTree.hpp
@@ -193,7 +193,7 @@ namespace moab {
         unsigned int dim, child;
         double Lmax, Rmin;
         BoundBox box;
-        Node() : dim(-2), child(-1), Lmax(-DBL_MAX), Rmin(DBL_MAX) {}
+        Node() : dim(UINT_MAX), child(UINT_MAX), Lmax(-DBL_MAX), Rmin(DBL_MAX) {}
         Node &operator=(const Node& f) {
           dim = f.dim; child = f.child;
           Lmax = f.Lmax; Rmin = f.Rmin;
diff --git a/test/io/read_cgm_group_test.cpp b/test/io/read_cgm_group_test.cpp
index 6fd2d3c..d040b89 100644
--- a/test/io/read_cgm_group_test.cpp
+++ b/test/io/read_cgm_group_test.cpp
@@ -40,7 +40,12 @@ void read_file( Interface* moab, const char* input_file );
 int geom_id_by_handle( Interface* moab, const EntityHandle set );
 //Function for checking retrieved group data
-void check_group_data( std::vector<int> & group_ids, std::vector<std::string> & group_names, std::vector<int> & group_ent_ids );
+void check_group_data( std::vector<int> & group_ids, std::vector<std::string> & group_names,
+#ifdef HAVE_OCC_STEP
+                      std::vector<int> & );
+#else
+                      std::vector<int> & group_ent_ids );
+#endif
 //Function for loading all reference data
 void load_group_references( std::vector<int>& ids, std::vector<std::string>& names, std::vector<int>& ent_ids);
@@ -129,15 +134,13 @@ void read_cylcube_groups_test()
   check_group_data( g_ids, g_names, g_ent_ids );
-void check_group_data(std::vector<int> & group_ids, std::vector<std::string> & group_names, std::vector<int> &
+void check_group_data(std::vector<int>& group_ids, std::vector<std::string>& group_names,
-  /* group_ent_ids */
+                      std::vector<int>& /*group_ent_ids*/ )
 #else
-     group_ent_ids
+                      std::vector<int>& group_ent_ids )
 #endif
   // Step files do not contain group data, MOAB shouldn't return errors when trying to access
   // this data but there shouldn't be any found.
https://bitbucket.org/fathomteam/moab/commits/cb158e3e6211/
Changeset:   cb158e3e6211
Branch:      None
User:        vijaysm
Summary:     Fix some unused variable warnings in tests
Affected #:  2 files
diff --git a/test/mbcn_test.cc b/test/mbcn_test.cc
index 1ad8778..f57343a 100644
--- a/test/mbcn_test.cc
+++ b/test/mbcn_test.cc
@@ -142,7 +142,7 @@ const EntityType elem_types[] = { MBTRI,
                                     MBPRISM,
                                     MBHEX,
                                     MBMAXTYPE };
-const int num_elem_types = sizeof(elem_types)/sizeof(elem_types[0]) - 1;
+// const int num_elem_types = sizeof(elem_types)/sizeof(elem_types[0]) - 1;
 void test_dimension_pair()
diff --git a/test/parallel/scdtest.cpp b/test/parallel/scdtest.cpp
index 5338b81..dbcde62 100644
--- a/test/parallel/scdtest.cpp
+++ b/test/parallel/scdtest.cpp
@@ -13,17 +13,17 @@ using namespace std;
 using namespace moab;
 // Number of cells in each direction:
-const int NC = 2;
+// const int NC = 2;
 const int NI = 2;
 const int NJ = 2;
 const int NK = 1;
 // Number of processes:
-const int NPROCS = 4;
+// const int NPROCS = 4;
 // Domain size:
-const double DSIZE = 10.0;
+// const double DSIZE = 10.0;
 // MOAB objects:
 Interface *mbint = NULL;
https://bitbucket.org/fathomteam/moab/commits/36bf22f841b9/
Changeset:   36bf22f841b9
Branch:      vijaysm/fix-warnings
User:        vijaysm
Date:        2014-07-12 02:05:36
Summary:     Fixing warnings related to array subscript is above array bounds
Affected #:  1 file
diff --git a/src/moab/ScdInterface.hpp b/src/moab/ScdInterface.hpp
index 1f2a482..1635dc6 100644
--- a/src/moab/ScdInterface.hpp
+++ b/src/moab/ScdInterface.hpp
@@ -314,7 +314,7 @@ private:
      * For description of arguments, see ScdInterface::compute_partition.
   inline static ErrorCode compute_partition_alljorkori(int np, int nr,
-                                                       const int * const gijk, const int * const gperiodic,
+                                                       const int gijk[6], const int * const gperiodic,
                                                        int *lijk, int *lperiodic, int *pijk);
     //! Compute a partition of structured parameter space
@@ -322,28 +322,28 @@ private:
      * seeking square regions of jk space
-  inline static ErrorCode compute_partition_alljkbal(int np, int nr, const int * const gijk, const int * const gperiodic,
+  inline static ErrorCode compute_partition_alljkbal(int np, int nr, const int gijk[6], const int * const gperiodic,
     /** Partitions the structured parametric space by seeking square ij partitions
-  inline static ErrorCode compute_partition_sqij(int np, int nr, const int * const gijk, const int * const gperiodic,
+  inline static ErrorCode compute_partition_sqij(int np, int nr, const int gijk[6], const int * const gperiodic,
     /** Partitions the structured parametric space by seeking square jk partitions
-  inline static ErrorCode compute_partition_sqjk(int np, int nr, const int * const gijk, const int * const gperiodic,
+  inline static ErrorCode compute_partition_sqjk(int np, int nr, const int gijk[6], const int * const gperiodic,
     /** Partitions the structured parametric space by seeking square ijk partitions
-  inline static ErrorCode compute_partition_sqijk(int np, int nr, const int * const gijk, const int * const gperiodic,
+  inline static ErrorCode compute_partition_sqijk(int np, int nr, const int gijk[6], const int * const gperiodic,
     //! Get vertices shared with other processors
@@ -775,7 +775,7 @@ inline ErrorCode ScdInterface::compute_partition(int np, int nr, const ScdParDat
 inline ErrorCode ScdInterface::compute_partition_alljorkori(int np, int nr,
                                                             int *ldims, int *lperiodic, int *pijk)
     // partition *the elements* over the parametric space; 1d partition for now, in the j, k, or i
@@ -858,7 +858,7 @@ inline ErrorCode ScdInterface::compute_partition_alljorkori(int np, int nr,
 inline ErrorCode ScdInterface::compute_partition_alljkbal(int np, int nr,
   int tmp_lp[3], tmp_pijk[3];
@@ -932,7 +932,7 @@ inline ErrorCode ScdInterface::compute_partition_alljkbal(int np, int nr,
 inline ErrorCode ScdInterface::compute_partition_sqij(int np, int nr,
@@ -1012,7 +1012,7 @@ inline ErrorCode ScdInterface::compute_partition_sqij(int np, int nr,
 inline ErrorCode ScdInterface::compute_partition_sqjk(int np, int nr,
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
