[MOAB-dev] commit/MOAB: 4 new changesets
Vijay S. Mahadevan vijay.m at gmail.com
Mon Jun 30 08:48:00 CDT 2014
> I think this name is too specific, and the allowed input is too constrained.
> This example should be able to generate any structured mesh, not just a
> large one.  And, there are functions that will compute the right partition
> for you, so there shouldn't be any defaults for A/B/C.  Also, by convention
> in structured meshes, the parameters are usually I/J/K.
Agreed with everything there about the name, inputs and functionality.
But this is just a first commit and it needs revisions based on
comments. So its fine for now.
> IMO, any changes to Interface.hpp should at least go through pull requests,
There is a PR with this change although entwined within the changeset
including example addition. I think is_valid needs to be exposed since
I've had instances when writing DMMoab when I wanted a sure fire way
to check if something was garbage or a valid entity handle. Especially
true for many asserts internal/external to MOAB in debug mode.
> I think this is fixing the symptom, not the problem.  Deleting entities
I haven't looked at this in detail since I'm traveling. But Tim's
suggestion to include this functionality directly within ParallelComm
makes sense.
Vijay
On Mon, Jun 30, 2014 at 8:25 AM, Tim Tautges
<timothy.tautges at cd-adapco.com> wrote:
> Several things bother me about this change:
>> --- /dev/null
>> +++ b/examples/GenLargeMesh.cpp
>> diff --git a/src/moab/Interface.hpp b/src/moab/Interface.hpp
> and also should be discussed on the general list first.  I'm on the fence
> about is_valid being a function on Interface, but only because we have sets
> that don't track owners.  The reason you included it (to allow it being
> called by ParallelComm) IMO isn't a valid one.
>> --- a/src/parallel/ParallelComm.cpp
>> +++ b/src/parallel/ParallelComm.cpp
>> @@ -8789,7 +8789,22 @@ ErrorCode
>> ParallelComm::settle_intersection_points(Range & edges, Range & shared
>>     return MB_SUCCESS;
>>     // end copy
>> +ErrorCode ParallelComm::correct_shared_entities()
> should check with ParallelComm in parallel cases, and there should be a
> ParallelComm function for a collective delete entities that takes care of
> checking the sharers.
> - tim
> Timothy J. Tautges
> Manager, Directed Meshing, CD-adapco
> Phone: 608-354-1459
