[MOAB-dev] commit/MOAB: 18 new changesets
commits-noreply at bitbucket.org
Fri Jun 27 16:56:44 CDT 2014
18 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/3b4e0576ea77/
Changeset: 3b4e0576ea77
Branch: None
User: pshriwise
Date: 2014-06-27 23:30:33
Summary: Implemented a new function add_vertices in ReadCGM.
Affected #: 2 files
diff --git a/src/io/ReadCGM.cpp b/src/io/ReadCGM.cpp
index d563293..dd309da 100644
--- a/src/io/ReadCGM.cpp
+++ b/src/io/ReadCGM.cpp
@@ -484,6 +484,7 @@ ErrorCode ReadCGM::store_group_content( Interface* /* moab */, std::map<RefEntit
return MB_SUCCESS;
void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
@@ -500,6 +501,31 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
+ ErrorCode ReadCGM::add_vertices( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] )
+ ErrorCode rval;
+ std::map<RefEntity*,EntityHandle>::iterator ci;
+ for (ci = entitymap[0].begin(); ci != entitymap[0].end(); ++ci) {
+ CubitVector pos = dynamic_cast<RefVertex*>(ci->first)->coordinates();
+ double coords[3] = {pos.x(), pos.y(), pos.z()};
+ EntityHandle vh;
+ rval = moab->create_vertex( coords, vh );
+ if (MB_SUCCESS != rval)
+ return MB_FAILURE;
+ rval = moab->add_entities( ci->second, &vh, 1 );
+ ci->second = vh;
+ return MB_SUCCESS;
// copy geometry into mesh database
ErrorCode ReadCGM::load_file(const char *cgm_file_name,
const EntityHandle* file_set,
@@ -587,23 +613,12 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
entmap[3].clear();
entmap[4].clear();
// create geometry for all vertices and replace
// vertex set handles with vertex handles in map
- for (ci = entmap[0].begin(); ci != entmap[0].end(); ++ci) {
- CubitVector pos = dynamic_cast<RefVertex*>(ci->first)->coordinates();
- double coords[3] = {pos.x(), pos.y(), pos.z()};
- EntityHandle vh;
- rval = mdbImpl->create_vertex( coords, vh );
- if (MB_SUCCESS != rval)
- return MB_FAILURE;
- rval = mdbImpl->add_entities( ci->second, &vh, 1 );
- ci->second = vh;
+ rval = add_vertices( mdbImpl, entmap );
+ if(rval!=MB_SUCCESS) return rval;
// maximum allowable curve-endpoint proximity warnings
// if this integer becomes negative, then abs(curve_warnings) is the
// number of warnings that were suppressed.
diff --git a/src/io/ReadCGM.hpp b/src/io/ReadCGM.hpp
index 2e38bbd..8150db4 100644
--- a/src/io/ReadCGM.hpp
+++ b/src/io/ReadCGM.hpp
@@ -95,8 +95,12 @@ public:
ErrorCode store_group_content( Interface* moab, std::map<RefEntity*,EntityHandle>* entitymap );
void set_cgm_attributes(bool const act_attributes, bool const verbost);
+ ErrorCode add_vertices( Interface* moab, std::map<RefEntity*,EntityHandle> entmap[5] );
//! Constructor
ReadCGM(Interface* impl = NULL);
https://bitbucket.org/fathomteam/moab/commits/6623f1b6612e/
Changeset: 6623f1b6612e
Branch: None
User: pshriwise
Date: 2014-06-27 23:30:34
Summary: Created a new function for faceting curves.
Affected #: 2 files
index dd309da..066c535 100644
@@ -476,7 +476,7 @@ ErrorCode ReadCGM::store_group_content( Interface* /* moab */, std::map<RefEntit
if (!entities.empty()) {
- rval = mdbImpl->add_entities( ci->second, entities );
+ rval = moab->add_entities( ci->second, entities );
return MB_FAILURE;
@@ -524,6 +524,128 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
return MB_SUCCESS;
+ErrorCode ReadCGM::create_curve_facets( Interface* moab,
+ std::map<RefEntity*,EntityHandle> entitymap[5],
+ int norm_tol,
+ double faceting_tol,
+ bool verbose_warn )
+ ErrorCode rval;
+ CubitStatus s;
+ // maximum allowable curve-endpoint proximity warnings
+ // if this integer becomes negative, then abs(curve_warnings) is the
+ // number of warnings that were suppressed.
+ int curve_warnings = 10;
+ //map iterator
+ // create geometry for all curves
+ GMem data;
+ for (ci = entitymap[1].begin(); ci != entitymap[1].end(); ++ci) {
+ RefEdge* edge = dynamic_cast<RefEdge*>(ci->first);
+ Curve* curve = edge->get_curve_ptr();
+ data.clean_out();
+#if CGM_MAJOR_VERSION>12
+ s = edge->get_graphics( data, norm_tol, faceting_tol);
+#else
+ s = edge->get_graphics( data, faceting_tol);
+#endif
+ if (CUBIT_SUCCESS != s)
+ std::vector<CubitVector> points;
+ for (int i = 0; i < data.pointListCount; ++i)
+ points.push_back( CubitVector( data.point_list()[i].x,
+ data.point_list()[i].y,
+ data.point_list()[i].z ) );
+ // need to reverse data?
+ if (curve->bridge_sense() == CUBIT_REVERSED)
+ std::reverse( points.begin(), points.end() );
+ // check for closed curve
+ RefVertex *start_vtx, *end_vtx;
+ start_vtx = edge->start_vertex();
+ end_vtx = edge->end_vertex();
+ // Special case for point curve
+ if (points.size() < 2) {
+ if (start_vtx != end_vtx || curve->measure() > GEOMETRY_RESABS ) {
+ std::cerr << "Warning: No facetting for curve " << edge->id() << std::endl;
+ continue;
+ EntityHandle h = entitymap[0][start_vtx];
+ rval = moab->add_entities( ci->second, &h, 1 );
+ continue;
+ const bool closed = (points.front() - points.back()).length() < GEOMETRY_RESABS;
+ if (closed != (start_vtx == end_vtx)) {
+ std::cerr << "Warning: topology and geometry inconsistant for possibly closed curve "
+ << edge->id() << std::endl;
+ // check proximity of vertices to end coordinates
+ if ((start_vtx->coordinates() - points.front()).length() > GEOMETRY_RESABS
+ || ( end_vtx->coordinates() - points.back() ).length() > GEOMETRY_RESABS ) {
+ curve_warnings--;
+ if( curve_warnings >= 0 || verbose_warn){
+ std::cerr << "Warning: vertices not at ends of curve " << edge->id() << std::endl;
+ if( curve_warnings == 0 && !verbose_warn){
+ std::cerr << " further instances of this warning will be suppressed..." << std::endl;
+ // create interior points
+ std::vector<EntityHandle> verts, edges;
+ verts.push_back( entitymap[0][start_vtx] );
+ for (size_t i = 1; i < points.size() - 1; ++i) {
+ double coords[] = { points[i].x(), points[i].y(), points[i].z() };
+ EntityHandle h;
+ rval = moab->create_vertex( coords, h );
+ verts.push_back( h );
+ verts.push_back( entitymap[0][end_vtx] );
+ // create edges
+ for (size_t i = 0; i < verts.size()-1; ++i) {
+ EntityHandle h;
+ rval = moab->create_element( MBEDGE, &verts[i], 2, h );
+ edges.push_back( h );
+ // if closed, remove duplicate
+ if (verts.front() == verts.back())
+ verts.pop_back();
+ rval = moab->add_entities( ci->second, &verts[0], verts.size() );
+ rval = moab->add_entities( ci->second, &edges[0], edges.size() );
+ if( !verbose_warn && curve_warnings < 0 ){
+ std::cerr << "Suppressed " << -curve_warnings
+ << " 'vertices not at ends of curve' warnings." << std::endl;
+ std::cerr << "To see all warnings, use reader param VERBOSE_CGM_WARNINGS." << std::endl;
@@ -618,8 +740,8 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
- // maximum allowable curve-endpoint proximity warnings
+ // maximum allowable curve-endpoint proximity warningsg
@@ -725,7 +847,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
// create geometry for all surfaces
for (ci = entmap[2].begin(); ci != entmap[2].end(); ++ci) {
RefFace* face = dynamic_cast<RefFace*>(ci->first);
index 8150db4..8304e0c 100644
@@ -100,6 +100,11 @@ public:
+ ErrorCode create_curve_facets( Interface* moab,
+ int norm_tol,
+ bool verbose_warn = false );
//! Constructor
https://bitbucket.org/fathomteam/moab/commits/58dd901c1377/
Changeset: 58dd901c1377
Branch: None
User: pshriwise
Summary: Implemented function for faceting curves in ReadCGM.
Affected #: 1 file
index 066c535..e06f20e 100644
@@ -741,113 +741,12 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
- // maximum allowable curve-endpoint proximity warningsg
- // if this integer becomes negative, then abs(curve_warnings) is the
- // number of warnings that were suppressed.
- int curve_warnings = 10;
+ // create facets for all curves
+ rval = create_curve_facets( mdbImpl, entmap, norm_tol, faceting_tol, verbose_warnings );
- // create geometry for all curves
GMem data;
- for (ci = entmap[1].begin(); ci != entmap[1].end(); ++ci) {
- RefEdge* edge = dynamic_cast<RefEdge*>(ci->first);
- Curve* curve = edge->get_curve_ptr();
- data.clean_out();
-#if CGM_MAJOR_VERSION>12
- edge->get_graphics( data, norm_tol, faceting_tol);
-#else
- edge->get_graphics( data, faceting_tol);
-#endif
- if (CUBIT_SUCCESS != s)
- std::vector<CubitVector> points;
- for (int i = 0; i < data.pointListCount; ++i)
- points.push_back( CubitVector( data.point_list()[i].x,
- data.point_list()[i].y,
- data.point_list()[i].z ) );
- // need to reverse data?
- if (curve->bridge_sense() == CUBIT_REVERSED)
- std::reverse( points.begin(), points.end() );
- // check for closed curve
- RefVertex *start_vtx, *end_vtx;
- start_vtx = edge->start_vertex();
- end_vtx = edge->end_vertex();
- // Special case for point curve
- if (points.size() < 2) {
- if (start_vtx != end_vtx || curve->measure() > GEOMETRY_RESABS ) {
- std::cerr << "Warning: No facetting for curve " << edge->id() << std::endl;
- continue;
- EntityHandle h = entmap[0][start_vtx];
- rval = mdbImpl->add_entities( ci->second, &h, 1 );
- continue;
- const bool closed = (points.front() - points.back()).length() < GEOMETRY_RESABS;
- if (closed != (start_vtx == end_vtx)) {
- std::cerr << "Warning: topology and geometry inconsistant for possibly closed curve "
- << edge->id() << std::endl;
- // check proximity of vertices to end coordinates
- if ((start_vtx->coordinates() - points.front()).length() > GEOMETRY_RESABS
- || ( end_vtx->coordinates() - points.back() ).length() > GEOMETRY_RESABS ) {
- curve_warnings--;
- if( curve_warnings >= 0 || verbose_warnings ){
- std::cerr << "Warning: vertices not at ends of curve " << edge->id() << std::endl;
- if( curve_warnings == 0 && !verbose_warnings ){
- std::cerr << " further instances of this warning will be suppressed..." << std::endl;
- // create interior points
- std::vector<EntityHandle> verts, edges;
- verts.push_back( entmap[0][start_vtx] );
- for (size_t i = 1; i < points.size() - 1; ++i) {
- double coords[] = { points[i].x(), points[i].y(), points[i].z() };
- EntityHandle h;
- rval = mdbImpl->create_vertex( coords, h );
- verts.push_back( h );
- verts.push_back( entmap[0][end_vtx] );
- // create edges
- for (size_t i = 0; i < verts.size()-1; ++i) {
- EntityHandle h;
- rval = mdbImpl->create_element( MBEDGE, &verts[i], 2, h );
- edges.push_back( h );
- // if closed, remove duplicate
- if (verts.front() == verts.back())
- verts.pop_back();
- rval = mdbImpl->add_entities( ci->second, &verts[0], verts.size() );
- rval = mdbImpl->add_entities( ci->second, &edges[0], edges.size() );
- if( !verbose_warnings && curve_warnings < 0 ){
- std::cerr << "Suppressed " << -curve_warnings
- << " 'vertices not at ends of curve' warnings." << std::endl;
- std::cerr << "To see all warnings, use reader param VERBOSE_CGM_WARNINGS." << std::endl;
https://bitbucket.org/fathomteam/moab/commits/274009e66f75/
Changeset: 274009e66f75
Branch: None
User: pshriwise
Summary: Added comments to the create_curve_facets function in ReadCGM.
Affected #: 1 file
index e06f20e..34c74bb 100644
@@ -544,9 +544,13 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
GMem data;
+ //get the start and end points of the curve in the form of a refernce edge
+ //get the edge's curve information
+ //clean out previous curve information
data.clean_out();
+ //facet curve accoring to parameters and CGM version
#else
@@ -557,6 +561,7 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
+ //add Cubit vertext points to a list
@@ -582,7 +587,8 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
return MB_FAILURE;
continue;
+ // check to see if the first and last interior vertices are considered to be
+ // coincident by CUBIT
@@ -608,6 +614,7 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
EntityHandle h;
+ //create vertex entity
return MB_FAILURE;
@@ -627,7 +634,7 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
verts.pop_back();
+ //Add entities to the curve meshset from entitymap
return MB_FAILURE;
@@ -744,7 +751,6 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
GMem data;
https://bitbucket.org/fathomteam/moab/commits/f64435ea8c6c/
Changeset: f64435ea8c6c
Branch: None
User: pshriwise
Summary: Added comments to ReadCGM. Moved a variable initialization closer to its use point.
Affected #: 1 file
index 34c74bb..26d4eb2 100644
@@ -653,8 +653,6 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
@@ -693,7 +691,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
//const char geom_categories[][CATEGORY_TAG_SIZE] =
//{"Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0"};
- DLIList<ModelEntity*> me_list;
// Initialize CGM
InitCGMA::initialize_cgma();
@@ -752,6 +750,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
+ DLIList<ModelEntity*> me_list;
GMem data;
@@ -766,22 +765,28 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
// declare array of all vertex handles
std::vector<EntityHandle> verts( data.pointListCount, 0 );
- // get list of vertices in surface
+ // get list of geometric vertices in surface
me_list.clean_out();
ModelQueryEngine::instance()->query_model( *face, DagType::ref_vertex_type(), me_list );
- // for each vertex, find coincident point in facets
+ // for each geometric vertex, find a single coincident point in facets
+ // otherwise, print a warning
for (int i = me_list.size(); i--; ) {
+ //assign geometric vertex
RefVertex* vtx = dynamic_cast<RefVertex*>(me_list.get_and_step());
CubitVector pos = vtx->coordinates();
for (int j = 0; j < data.pointListCount; ++j) {
+ //assign facet vertex
CubitVector vpos( data.point_list()[j].x,
data.point_list()[j].y,
data.point_list()[j].z );
+ //check to see if they are considered coincident
if ((pos - vpos).length_squared() < GEOMETRY_RESABS*GEOMETRY_RESABS ) {
+ // if this facet vertex has already been found coincident, print warning
if (verts[j])
std::cerr << "Warning: Coincident vertices in surface " << face->id() << std::endl;
+ //if a coincidence is found, keep track of it in the verts vector
verts[j] = entmap[0][vtx];
break;
@@ -795,6 +800,8 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
double coords[] = { data.point_list()[i].x,
data.point_list()[i].z };
+ // return vertex handle to verts to fill in all remaining facet
+ // vertices
rval = mdbImpl->create_vertex( coords, verts[i] );
return rval;
@@ -804,6 +811,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
Range facets;
std::vector<EntityHandle> corners;
for (int i = 0; i < data.fListCount; i += data.facet_list()[i]+1) {
+ // get number of facet verts
int* facet = data.facet_list() + i;
corners.resize( *facet );
for (int j = 1; j <= *facet; ++j) {
https://bitbucket.org/fathomteam/moab/commits/170a7387f5d8/
Changeset: 170a7387f5d8
Branch: None
User: pshriwise
Summary: Added a new function for creating surface facets in ReadCGM.
Affected #: 2 files
index 26d4eb2..571a00d 100644
@@ -652,6 +652,122 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
return MB_SUCCESS;
+ErrorCode ReadCGM::create_surface_facets( Interface* moab,
+ int norm_tol,
+ double facet_tol,
+ double length_tol )
+ ErrorCode rval;
+ CubitStatus s;
+ GMem data;
+ // create geometry for all surfaces
+ for (ci = entitymap[2].begin(); ci != entitymap[2].end(); ++ci) {
+ RefFace* face = dynamic_cast<RefFace*>(ci->first);
+ data.clean_out();
+ s = face->get_graphics( data, norm_tol, facet_tol, length_tol );
+ // declare array of all vertex handles
+ std::vector<EntityHandle> verts( data.pointListCount, 0 );
+ me_list.clean_out();
+ ModelQueryEngine::instance()->query_model( *face, DagType::ref_vertex_type(), me_list );
+ for (int i = me_list.size(); i--; ) {
+ RefVertex* vtx = dynamic_cast<RefVertex*>(me_list.get_and_step());
+ CubitVector pos = vtx->coordinates();
+ for (int j = 0; j < data.pointListCount; ++j) {
+ CubitVector vpos( data.point_list()[j].x,
+ data.point_list()[j].y,
+ data.point_list()[j].z );
+ if ((pos - vpos).length_squared() < GEOMETRY_RESABS*GEOMETRY_RESABS ) {
+ if (verts[j])
+ std::cerr << "Warning: Coincident vertices in surface " << face->id() << std::endl;
+ verts[j] = entitymap[0][vtx];
+ break;
+ // now create vertices for the remaining points in the facetting
+ for (int i = 0; i < data.pointListCount; ++i) {
+ if (verts[i]) // if a geometric vertex
+ continue;
+ double coords[] = { data.point_list()[i].x,
+ data.point_list()[i].z };
+ // vertices
+ rval = mdbImpl->create_vertex( coords, verts[i] );
+ return rval;
+ // now create facets
+ Range facets;
+ std::vector<EntityHandle> corners;
+ for (int i = 0; i < data.fListCount; i += data.facet_list()[i]+1) {
+ int* facet = data.facet_list() + i;
+ corners.resize( *facet );
+ for (int j = 1; j <= *facet; ++j) {
+ if (facet[j] >= (int)verts.size()) {
+ std::cerr << "ERROR: Invalid facet data for surface " << face->id() << std::endl;
+ corners[j-1] = verts[facet[j]];
+ EntityType type;
+ if (*facet == 3)
+ type = MBTRI;
+ else {
+ std::cerr << "Warning: non-triangle facet in surface " << face->id() << std::endl;
+ std::cerr << " entity has " << *facet << " edges" << std::endl;
+ if (*facet == 4)
+ type = MBQUAD;
+ else
+ type = MBPOLYGON;
+ // if (surf->bridge_sense() == CUBIT_REVERSED)
+ // std::reverse( corners.begin(), corners.end() );
+ EntityHandle h;
+ rval = mdbImpl->create_element( type, &corners[0], corners.size(), h );
+ facets.insert( h );
+ // add vertices and facets to surface set
+ rval = mdbImpl->add_entities( ci->second, &verts[0], verts.size() );
+ rval = mdbImpl->add_entities( ci->second, facets );
@@ -750,6 +866,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
GMem data;
index 8304e0c..395614a 100644
@@ -106,6 +106,12 @@ public:
+ ErrorCode create_surface_facets( Interface* moab,
+ int norm_tol,
+ double facet_tol,
+ double length_tol );
//! Constructor
https://bitbucket.org/fathomteam/moab/commits/2de7ccb920a1/
Changeset: 2de7ccb920a1
Branch: None
User: pshriwise
Summary: Implemented the function create_surface_facets in ReadCGM.
Affected #: 1 file
index 571a00d..ea27ff1 100644
@@ -855,120 +855,18 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
// done with volumes and groups
entmap[3].clear();
entmap[4].clear();
- // vertex set handles with vertex handles in map
- GMem data;
- // create geometry for all surfaces
- for (ci = entmap[2].begin(); ci != entmap[2].end(); ++ci) {
- RefFace* face = dynamic_cast<RefFace*>(ci->first);
- data.clean_out();
- s = face->get_graphics( data, norm_tol, faceting_tol, len_tol );
- // declare array of all vertex handles
- std::vector<EntityHandle> verts( data.pointListCount, 0 );
- // get list of geometric vertices in surface
- me_list.clean_out();
- ModelQueryEngine::instance()->query_model( *face, DagType::ref_vertex_type(), me_list );
- // for each geometric vertex, find a single coincident point in facets
- // otherwise, print a warning
- for (int i = me_list.size(); i--; ) {
- //assign geometric vertex
- RefVertex* vtx = dynamic_cast<RefVertex*>(me_list.get_and_step());
- CubitVector pos = vtx->coordinates();
- for (int j = 0; j < data.pointListCount; ++j) {
- //assign facet vertex
- CubitVector vpos( data.point_list()[j].x,
- data.point_list()[j].y,
- data.point_list()[j].z );
- //check to see if they are considered coincident
- if ((pos - vpos).length_squared() < GEOMETRY_RESABS*GEOMETRY_RESABS ) {
- // if this facet vertex has already been found coincident, print warning
- if (verts[j])
- std::cerr << "Warning: Coincident vertices in surface " << face->id() << std::endl;
- //if a coincidence is found, keep track of it in the verts vector
- verts[j] = entmap[0][vtx];
- break;
- // now create vertices for the remaining points in the facetting
- for (int i = 0; i < data.pointListCount; ++i) {
- if (verts[i]) // if a geometric vertex
- continue;
- double coords[] = { data.point_list()[i].x,
- data.point_list()[i].z };
- // return vertex handle to verts to fill in all remaining facet
- // vertices
- rval = mdbImpl->create_vertex( coords, verts[i] );
- return rval;
- // now create facets
- Range facets;
- std::vector<EntityHandle> corners;
- for (int i = 0; i < data.fListCount; i += data.facet_list()[i]+1) {
- // get number of facet verts
- int* facet = data.facet_list() + i;
- corners.resize( *facet );
- for (int j = 1; j <= *facet; ++j) {
- if (facet[j] >= (int)verts.size()) {
- std::cerr << "ERROR: Invalid facet data for surface " << face->id() << std::endl;
- corners[j-1] = verts[facet[j]];
- EntityType type;
- if (*facet == 3)
- type = MBTRI;
- else {
- std::cerr << "Warning: non-triangle facet in surface " << face->id() << std::endl;
- std::cerr << " entity has " << *facet << " edges" << std::endl;
- if (*facet == 4)
- type = MBQUAD;
- else
- type = MBPOLYGON;
- // if (surf->bridge_sense() == CUBIT_REVERSED)
- // std::reverse( corners.begin(), corners.end() );
- EntityHandle h;
- rval = mdbImpl->create_element( type, &corners[0], corners.size(), h );
- facets.insert( h );
- // add vertices and facets to surface set
- rval = mdbImpl->add_entities( ci->second, facets );
+ // create facets for surfaces
+ rval = create_surface_facets( mdbImpl, entmap, norm_tol, faceting_tol, len_tol);
return MB_SUCCESS;
https://bitbucket.org/fathomteam/moab/commits/331a8569fd53/
Changeset: 331a8569fd53
Branch: None
User: pshriwise
Summary: Renamed add_vertices in ReadCGM to create_vertices.
Affected #: 2 files
index ea27ff1..310eec4 100644
@@ -502,7 +502,7 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
- ErrorCode ReadCGM::add_vertices( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] )
+ ErrorCode ReadCGM::create_vertices( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] )
ErrorCode rval;
@@ -857,7 +857,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
entmap[4].clear();
- rval = add_vertices( mdbImpl, entmap );
+ rval = create_vertices( mdbImpl, entmap );
index 395614a..9eeadf6 100644
@@ -98,7 +98,9 @@ public:
- ErrorCode add_vertices( Interface* moab, std::map<RefEntity*,EntityHandle> entmap[5] );
+ ErrorCode create_vertices( Interface* moab, std::map<RefEntity*,EntityHandle> entmap[5] );
https://bitbucket.org/fathomteam/moab/commits/ef4e355aea3f/
Changeset: ef4e355aea3f
Branch: None
User: pshriwise
Summary: Removed the moab interface parameter from the store_group_content function in ReadCGM.
Affected #: 2 files
index 310eec4..66ddb10 100644
@@ -321,7 +321,7 @@ ErrorCode ReadCGM::store_curve_senses( std::map<RefEntity*,EntityHandle> entitym
// store group names and entities in the mesh
- rval = store_group_content( moab, entitymap );
+ rval = store_group_content(entitymap );
@@ -424,7 +424,7 @@ ErrorCode ReadCGM::create_group_entsets( Interface* moab, std::map<RefEntity*,En
return MB_SUCCESS;
-ErrorCode ReadCGM::store_group_content( Interface* /* moab */, std::map<RefEntity*,EntityHandle>* entitymap )
+ErrorCode ReadCGM::store_group_content(std::map<RefEntity*,EntityHandle>* entitymap )
ErrorCode rval;
- rval = moab->add_entities( ci->second, entities );
+ rval = mdbImpl->add_entities( ci->second, entities );
return MB_FAILURE;
index 9eeadf6..4a5a0b6 100644
@@ -93,7 +93,7 @@ public:
ErrorCode create_group_entsets( Interface* moab,
std::map<RefEntity*,EntityHandle>& entitymap );
- ErrorCode store_group_content( Interface* moab, std::map<RefEntity*,EntityHandle>* entitymap );
+ ErrorCode store_group_content( std::map<RefEntity*,EntityHandle>* entitymap );
https://bitbucket.org/fathomteam/moab/commits/2bdc9bd83dc8/
Changeset: 2bdc9bd83dc8
Branch: None
User: pshriwise
Summary: Removed un-needed moab interface passes to multiple functions.
Affected #: 2 files
index 66ddb10..87ce275 100644
@@ -159,7 +159,7 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
return MB_SUCCESS;
- ErrorCode ReadCGM::create_entity_sets( Interface* moab, std::map<RefEntity*, EntityHandle> (&entmap)[5] )
+ ErrorCode ReadCGM::create_entity_sets( std::map<RefEntity*, EntityHandle> (&entmap)[5] )
ErrorCode rval;
@@ -178,21 +178,21 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
RefEntity* ent = entlist.get_and_step();
EntityHandle handle;
// create the new meshset
- rval = moab->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle);
+ rval = mdbImpl->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle);
if (MB_SUCCESS != rval) return rval;
// map the geom reference entity to the corresponding moab meshset
entmap[dim][ent] = handle;
// create tags for the new meshset
- rval = moab->tag_set_data( geom_tag, &handle, 1, &dim );
+ rval = mdbImpl->tag_set_data( geom_tag, &handle, 1, &dim );
int id = ent->id();
- rval = moab->tag_set_data( id_tag, &handle, 1, &id );
+ rval = mdbImpl->tag_set_data( id_tag, &handle, 1, &id );
- rval = moab->tag_set_data( category_tag, &handle, 1, &geom_categories[dim] );
+ rval = mdbImpl->tag_set_data( category_tag, &handle, 1, &geom_categories[dim] );
@@ -203,7 +203,7 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
-ErrorCode ReadCGM::create_topology( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] )
+ErrorCode ReadCGM::create_topology( std::map<RefEntity*,EntityHandle> entitymap[5] )
ErrorCode rval;
DLIList<RefEntity*> entitylist;
@@ -218,7 +218,7 @@ ErrorCode ReadCGM::create_topology( Interface* moab, std::map<RefEntity*,EntityH
for (int i = entitylist.size(); i--; ) {
RefEntity* ent = entitylist.get_and_step();
EntityHandle h = entitymap[dim-1][ent];
- rval = moab->add_parent_child( ci->second, h );
+ rval = mdbImpl->add_parent_child( ci->second, h );
return rval;
@@ -312,12 +312,12 @@ ErrorCode ReadCGM::store_curve_senses( std::map<RefEntity*,EntityHandle> entitym
return MB_SUCCESS;
- ErrorCode ReadCGM::store_groups( Interface* moab, std::map<RefEntity*,EntityHandle>* entitymap )
+ ErrorCode ReadCGM::store_groups( std::map<RefEntity*,EntityHandle>* entitymap )
ErrorCode rval;
// create eneity sets for all ref groups
- rval = create_group_entsets( moab, entitymap[4] );
+ rval = create_group_entsets( entitymap[4] );
@@ -328,7 +328,7 @@ ErrorCode ReadCGM::store_curve_senses( std::map<RefEntity*,EntityHandle> entitym
return MB_SUCCESS;
-ErrorCode ReadCGM::create_group_entsets( Interface* moab, std::map<RefEntity*,EntityHandle>& entitymap )
+ErrorCode ReadCGM::create_group_entsets( std::map<RefEntity*,EntityHandle>& entitymap )
ErrorCode rval;
@@ -370,7 +370,7 @@ ErrorCode ReadCGM::create_group_entsets( Interface* moab, std::map<RefEntity*,En
#endif
// create entity handle for the group
EntityHandle h;
- rval = moab->create_meshset( MESHSET_SET, h );
+ rval = mdbImpl->create_meshset( MESHSET_SET, h );
return rval;
//set tag data for the group
@@ -380,16 +380,16 @@ ErrorCode ReadCGM::create_group_entsets( Interface* moab, std::map<RefEntity*,En
if (name1.length() >= (unsigned)NAME_TAG_SIZE)
std::cout << "WARNING: group name '" << name1.c_str()
<< "' truncated to '" << namebuf << "'" << std::endl;
- rval = moab->tag_set_data( name_tag, &h, 1, namebuf );
+ rval = mdbImpl->tag_set_data( name_tag, &h, 1, namebuf );
return MB_FAILURE;
int id = grp->id();
- rval = moab->tag_set_data( id_tag, &h, 1, &id );
+ rval = mdbImpl->tag_set_data( id_tag, &h, 1, &id );
return MB_FAILURE;
- rval = moab->tag_set_data( category_tag, &h, 1, &geom_categories[4] );
+ rval = mdbImpl->tag_set_data( category_tag, &h, 1, &geom_categories[4] );
return MB_FAILURE;
//check for extra group names
@@ -397,7 +397,7 @@ ErrorCode ReadCGM::create_group_entsets( Interface* moab, std::map<RefEntity*,En
for (int j = extra_name_tags.size(); j < name_list.size(); ++j) {
sprintf( namebuf, "EXTRA_%s%d", NAME_TAG_NAME, j );
Tag t;
- rval = moab->tag_get_handle( namebuf, NAME_TAG_SIZE, MB_TYPE_OPAQUE, t, MB_TAG_SPARSE|MB_TAG_CREAT );
+ rval = mdbImpl->tag_get_handle( namebuf, NAME_TAG_SIZE, MB_TYPE_OPAQUE, t, MB_TAG_SPARSE|MB_TAG_CREAT );
assert(!rval);
extra_name_tags.push_back(t);
@@ -413,7 +413,7 @@ ErrorCode ReadCGM::create_group_entsets( Interface* moab, std::map<RefEntity*,En
- rval = moab->tag_set_data( extra_name_tags[j], &h, 1, namebuf );
+ rval = mdbImpl->tag_set_data( extra_name_tags[j], &h, 1, namebuf );
return MB_FAILURE;
- ErrorCode ReadCGM::create_vertices( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] )
+ ErrorCode ReadCGM::create_vertices( std::map<RefEntity*,EntityHandle> entitymap[5] )
ErrorCode rval;
@@ -511,11 +511,11 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
EntityHandle vh;
- rval = moab->create_vertex( coords, vh );
+ rval = mdbImpl->create_vertex( coords, vh );
return MB_FAILURE;
- rval = moab->add_entities( ci->second, &vh, 1 );
+ rval = mdbImpl->add_entities( ci->second, &vh, 1 );
return MB_FAILURE;
@@ -524,8 +524,7 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
return MB_SUCCESS;
-ErrorCode ReadCGM::create_curve_facets( Interface* moab,
- std::map<RefEntity*,EntityHandle> entitymap[5],
+ErrorCode ReadCGM::create_curve_facets( std::map<RefEntity*,EntityHandle> entitymap[5],
int norm_tol,
bool verbose_warn )
@@ -582,7 +581,7 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
continue;
- rval = moab->add_entities( ci->second, &h, 1 );
+ rval = mdbImpl->add_entities( ci->second, &h, 1 );
return MB_FAILURE;
continue;
@@ -615,7 +614,7 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
EntityHandle h;
- rval = moab->create_vertex( coords, h );
+ rval = mdbImpl->create_vertex( coords, h );
return MB_FAILURE;
@@ -625,7 +624,7 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
// create edges
EntityHandle h;
- rval = moab->create_element( MBEDGE, &verts[i], 2, h );
+ rval = mdbImpl->create_element( MBEDGE, &verts[i], 2, h );
return MB_FAILURE;
@@ -635,10 +634,10 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
verts.pop_back();
- rval = moab->add_entities( ci->second, &verts[0], verts.size() );
return MB_FAILURE;
- rval = moab->add_entities( ci->second, &edges[0], edges.size() );
+ rval = mdbImpl->add_entities( ci->second, &edges[0], edges.size() );
return MB_FAILURE;
@@ -652,8 +651,7 @@ ErrorCode ReadCGM::create_curve_facets( Interface* moab,
return MB_SUCCESS;
-ErrorCode ReadCGM::create_surface_facets( Interface* moab,
+ErrorCode ReadCGM::create_surface_facets( std::map<RefEntity*,EntityHandle> entitymap[5],
int norm_tol,
double facet_tol,
double length_tol )
@@ -833,11 +831,11 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
DLIList<RefEntity*> entlist;
std::map<RefEntity*,EntityHandle> entmap[5]; // one for each dim, and one for groups
//std::map<RefEntity*,EntityHandle>* entmap_ptr = entmap;
- rval = create_entity_sets( mdbImpl, entmap );
+ rval = create_entity_sets( entmap );
if (rval!=MB_SUCCESS) return rval;
// create topology for all geometric entities
- rval = create_topology( mdbImpl, entmap );
+ rval = create_topology( entmap );
// store CoFace senses
@@ -849,7 +847,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
// get group information and store it in the mesh
- rval = store_groups( mdbImpl, entmap );
+ rval = store_groups( entmap );
@@ -857,15 +855,15 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
entmap[4].clear();
- rval = create_vertices( mdbImpl, entmap );
+ rval = create_vertices( entmap );
- rval = create_curve_facets( mdbImpl, entmap, norm_tol, faceting_tol, verbose_warnings );
+ rval = create_curve_facets( entmap, norm_tol, faceting_tol, verbose_warnings );
- rval = create_surface_facets( mdbImpl, entmap, norm_tol, faceting_tol, len_tol);
+ rval = create_surface_facets( entmap, norm_tol, faceting_tol, len_tol);
return MB_SUCCESS;
index 4a5a0b6..35e8dc0 100644
@@ -78,20 +78,17 @@ public:
bool& act_att,
bool& verbose_warnings);
- ErrorCode create_entity_sets( Interface* moab,
- std::map<RefEntity*,EntityHandle> (&entmap)[5] );
+ ErrorCode create_entity_sets( std::map<RefEntity*,EntityHandle> (&entmap)[5] );
- ErrorCode create_topology( Interface* moab,
- std::map<RefEntity*,EntityHandle> entitymap[5] );
+ ErrorCode create_topology( std::map<RefEntity*,EntityHandle> entitymap[5] );
ErrorCode store_surface_senses( std::map<RefEntity*,EntityHandle> entitymap[5] );
ErrorCode store_curve_senses( std::map<RefEntity*,EntityHandle> entitymap[5] );
- ErrorCode store_groups( Interface* moab, std::map<RefEntity*,EntityHandle>* entitymap );
+ ErrorCode store_groups( std::map<RefEntity*,EntityHandle>* entitymap );
- ErrorCode create_group_entsets( Interface* moab,
- std::map<RefEntity*,EntityHandle>& entitymap );
+ ErrorCode create_group_entsets( std::map<RefEntity*,EntityHandle>& entitymap );
@@ -99,17 +96,15 @@ public:
- ErrorCode create_vertices( Interface* moab, std::map<RefEntity*,EntityHandle> entmap[5] );
+ ErrorCode create_vertices( std::map<RefEntity*,EntityHandle> entmap[5] );
- ErrorCode create_curve_facets( Interface* moab,
+ ErrorCode create_curve_facets( std::map<RefEntity*,EntityHandle> entitymap[5],
int norm_tol,
- ErrorCode create_surface_facets( Interface* moab,
+ ErrorCode create_surface_facets( std::map<RefEntity*,EntityHandle> entitymap[5],
int norm_tol,
double facet_tol,
https://bitbucket.org/fathomteam/moab/commits/27cc103347d8/
Changeset: 27cc103347d8
Branch: None
User: pshriwise
Summary: Removed unused variables/structures in ReadCGM.
Affected #: 1 file
index 87ce275..6b4d9b5 100644
@@ -515,10 +515,7 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
return MB_FAILURE;
+ //replace meshset with the vertex handle
ci->second = vh;
return MB_SUCCESS;
@@ -800,13 +797,6 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
rval = mdbImpl->tag_set_data( geometry_resabs_tag, &set, 1, &GEOMETRY_RESABS );
if(MB_SUCCESS != rval) return rval;
- // CGM data
- std::map<RefEntity*,EntityHandle>::iterator ci;
- //const char geom_categories[][CATEGORY_TAG_SIZE] =
- //{"Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0"};
// Initialize CGM
@@ -828,9 +818,8 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
// create entity sets for all geometric entities
- DLIList<RefEntity*> entlist;
- //std::map<RefEntity*,EntityHandle>* entmap_ptr = entmap;
@@ -854,7 +843,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
entmap[3].clear();
entmap[4].clear();
- // create geometry for all vertices and replace
+ // create geometry for all vertices
https://bitbucket.org/fathomteam/moab/commits/da20591ba6e4/
Changeset: da20591ba6e4
Branch: None
User: pshriwise
Summary: Revert "Removed unused variables/structures in ReadCGM."
This reverts commit a5d3b32b123c88dd96286c01ae64d36c1f9773be.
Affected #: 1 file
index 6b4d9b5..87ce275 100644
@@ -515,7 +515,10 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
return MB_FAILURE;
- //replace meshset with the vertex handle
ci->second = vh;
return MB_SUCCESS;
@@ -797,6 +800,13 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
+ // CGM data
+ //const char geom_categories[][CATEGORY_TAG_SIZE] =
+ //{"Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0"};
// Initialize CGM
@@ -818,8 +828,9 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
+ DLIList<RefEntity*> entlist;
+ //std::map<RefEntity*,EntityHandle>* entmap_ptr = entmap;
@@ -843,7 +854,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
entmap[3].clear();
entmap[4].clear();
+ // create geometry for all vertices and replace
https://bitbucket.org/fathomteam/moab/commits/6609b229e651/
Changeset: 6609b229e651
Branch: None
User: pshriwise
Summary: Removed unused variables/structures. Added comments to create_vertices function.
Affected #: 1 file
index 87ce275..52673a4 100644
@@ -515,11 +515,15 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
return MB_FAILURE;
+ //add the vertex to its tagged meshset
return MB_FAILURE;
+ // replace the meshset handle with the vertex handle
+ // this makes adding the vertex to higher dim sets easier
ci->second = vh;
return MB_SUCCESS;
@@ -800,13 +804,6 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
- // CGM data
// Initialize CGM
@@ -828,9 +825,8 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
https://bitbucket.org/fathomteam/moab/commits/5464ead0e8d4/
Changeset: 5464ead0e8d4
Branch: None
User: pshriwise
Summary: Spelling correction to set_cgm_attributes variable
Affected #: 1 file
index 35e8dc0..511e140 100644
- void set_cgm_attributes(bool const act_attributes, bool const verbost);
+ void set_cgm_attributes(bool const act_attributes, bool const verbose);
https://bitbucket.org/fathomteam/moab/commits/7ad94bbdd580/
Changeset: 7ad94bbdd580
Branch: None
User: pshriwise
Summary: Altered ReadCGM methods to pass maps by reference.
Affected #: 2 files
index 52673a4..e7682af 100644
-ErrorCode ReadCGM::create_topology( std::map<RefEntity*,EntityHandle> entitymap[5] )
+ ErrorCode ReadCGM::create_topology( std::map<RefEntity*,EntityHandle> (&entitymap)[5] )
ErrorCode rval;
@@ -227,7 +227,7 @@ ErrorCode ReadCGM::create_topology( std::map<RefEntity*,EntityHandle> entitymap[
return MB_SUCCESS;
-ErrorCode ReadCGM::store_surface_senses( std::map<RefEntity*,EntityHandle> entitymap[5] )
+ ErrorCode ReadCGM::store_surface_senses( std::map<RefEntity*,EntityHandle> (&entitymap)[5] )
ErrorCode rval;
@@ -278,7 +278,7 @@ ErrorCode ReadCGM::store_surface_senses( std::map<RefEntity*,EntityHandle> entit
return MB_SUCCESS;
-ErrorCode ReadCGM::store_curve_senses( std::map<RefEntity*,EntityHandle> entitymap[5] )
+ ErrorCode ReadCGM::store_curve_senses( std::map<RefEntity*,EntityHandle> (&entitymap)[5] )
ErrorCode rval;
@@ -312,7 +312,7 @@ ErrorCode ReadCGM::store_curve_senses( std::map<RefEntity*,EntityHandle> entitym
return MB_SUCCESS;
- ErrorCode ReadCGM::store_groups( std::map<RefEntity*,EntityHandle>* entitymap )
+ ErrorCode ReadCGM::store_groups( std::map<RefEntity*,EntityHandle> (&entitymap)[5] )
ErrorCode rval;
@@ -424,7 +424,7 @@ ErrorCode ReadCGM::create_group_entsets( std::map<RefEntity*,EntityHandle>& enti
return MB_SUCCESS;
-ErrorCode ReadCGM::store_group_content(std::map<RefEntity*,EntityHandle>* entitymap )
+ ErrorCode ReadCGM::store_group_content(std::map<RefEntity*,EntityHandle> (&entitymap)[5] )
ErrorCode rval;
@@ -502,12 +502,12 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
- ErrorCode ReadCGM::create_vertices( std::map<RefEntity*,EntityHandle> entitymap[5] )
+ ErrorCode ReadCGM::create_vertices( std::map<RefEntity*,EntityHandle> &entitymap )
ErrorCode rval;
- for (ci = entitymap[0].begin(); ci != entitymap[0].end(); ++ci) {
+ for (ci = entitymap.begin(); ci != entitymap.end(); ++ci) {
EntityHandle vh;
@@ -528,7 +528,7 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
return MB_SUCCESS;
-ErrorCode ReadCGM::create_curve_facets( std::map<RefEntity*,EntityHandle> entitymap[5],
+ ErrorCode ReadCGM::create_curve_facets( std::map<RefEntity*,EntityHandle> (&entitymap)[5],
int norm_tol,
bool verbose_warn )
@@ -655,7 +655,7 @@ ErrorCode ReadCGM::create_curve_facets( std::map<RefEntity*,EntityHandle> entity
return MB_SUCCESS;
-ErrorCode ReadCGM::create_surface_facets( std::map<RefEntity*,EntityHandle> entitymap[5],
+ ErrorCode ReadCGM::create_surface_facets( std::map<RefEntity*,EntityHandle> (&entitymap)[5],
int norm_tol,
double facet_tol,
double length_tol )
@@ -851,7 +851,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
entmap[4].clear();
- rval = create_vertices( entmap );
+ rval = create_vertices( entmap[0] );
index 511e140..640ae4a 100644
@@ -80,31 +80,31 @@ public:
- ErrorCode create_topology( std::map<RefEntity*,EntityHandle> entitymap[5] );
+ ErrorCode create_topology( std::map<RefEntity*,EntityHandle> (&entitymap)[5] );
- ErrorCode store_surface_senses( std::map<RefEntity*,EntityHandle> entitymap[5] );
+ ErrorCode store_surface_senses( std::map<RefEntity*,EntityHandle> (&entitymap)[5] );
- ErrorCode store_curve_senses( std::map<RefEntity*,EntityHandle> entitymap[5] );
+ ErrorCode store_curve_senses( std::map<RefEntity*,EntityHandle> (&entitymap)[5] );
- ErrorCode store_groups( std::map<RefEntity*,EntityHandle>* entitymap );
+ ErrorCode store_groups( std::map<RefEntity*,EntityHandle> (&entitymap)[5] );
- ErrorCode store_group_content( std::map<RefEntity*,EntityHandle>* entitymap );
+ ErrorCode store_group_content( std::map<RefEntity*,EntityHandle> (&entitymap)[5] );
- ErrorCode create_vertices( std::map<RefEntity*,EntityHandle> entmap[5] );
+ ErrorCode create_vertices( std::map<RefEntity*,EntityHandle> &entitymap );
- ErrorCode create_curve_facets( std::map<RefEntity*,EntityHandle> entitymap[5],
+ ErrorCode create_curve_facets( std::map<RefEntity*,EntityHandle> (&entitymap)[5],
int norm_tol,
- ErrorCode create_surface_facets( std::map<RefEntity*,EntityHandle> entitymap[5],
+ ErrorCode create_surface_facets( std::map<RefEntity*,EntityHandle> (&entitymap)[5],
int norm_tol,
double facet_tol,
https://bitbucket.org/fathomteam/moab/commits/52baa949e61d/
Changeset: 52baa949e61d
Branch: None
User: pshriwise
Summary: Moved newly created re-factor functions from public to private.
Affected #: 1 file
index 640ae4a..83fc8b5 100644
@@ -71,6 +71,15 @@ public:
std::vector<int>& tag_values_out,
const SubsetList* subset_list = 0 );
+ //! Constructor
+ ReadCGM(Interface* impl = NULL);
+ //! Destructor
+ virtual ~ReadCGM();
+private:
ErrorCode set_options( const FileOptions& opts,
int& norm_tol,
double& faceting_tol,
@@ -109,13 +118,6 @@ public:
double facet_tol,
- //! Constructor
- ReadCGM(Interface* impl = NULL);
- //! Destructor
- virtual ~ReadCGM();
-private:
ReadUtilIface* readUtilIface;
https://bitbucket.org/fathomteam/moab/commits/c334cb120fdd/
Changeset: c334cb120fdd
Branch: None
User: pshriwise
Summary: Updated arguments to store_*_sense functions to make them more readable.
Affected #: 2 files
index e7682af..c1b3f2a 100644
@@ -227,12 +227,13 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
return MB_SUCCESS;
- ErrorCode ReadCGM::store_surface_senses( std::map<RefEntity*,EntityHandle> (&entitymap)[5] )
+ ErrorCode ReadCGM::store_surface_senses( std::map<RefEntity*,EntityHandle>& surface_map,
+ std::map<RefEntity*,EntityHandle>& volume_map )
ErrorCode rval;
- for (ci = entitymap[2].begin(); ci != entitymap[2].end(); ++ci) {
+ for (ci = surface_map.begin(); ci != surface_map.end(); ++ci) {
RefFace* face = (RefFace*)(ci->first);
BasicTopologyEntity *forward = 0, *reverse = 0;
for (SenseEntity* cf = face->get_first_sense_entity_ptr();
@@ -264,12 +265,12 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
if (forward) {
- rval = myGeomTool->set_sense( ci->second, entitymap[3][forward], SENSE_FORWARD );
+ rval = myGeomTool->set_sense( ci->second, volume_map[forward], SENSE_FORWARD );
return rval;
if (reverse) {
- rval = myGeomTool->set_sense( ci->second, entitymap[3][reverse], SENSE_REVERSE );
+ rval = myGeomTool->set_sense( ci->second, volume_map[reverse], SENSE_REVERSE );
return rval;
@@ -278,21 +279,22 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
return MB_SUCCESS;
- ErrorCode ReadCGM::store_curve_senses( std::map<RefEntity*,EntityHandle> (&entitymap)[5] )
+ ErrorCode ReadCGM::store_curve_senses( std::map<RefEntity*,EntityHandle>& curve_map,
+ std::map<RefEntity*,EntityHandle>& surface_map )
ErrorCode rval;
std::vector<EntityHandle> ents;
std::vector<int> senses;
- for (ci = entitymap[1].begin(); ci != entitymap[1].end(); ++ci) {
+ for (ci = curve_map.begin(); ci != curve_map.end(); ++ci) {
RefEdge* edge = (RefEdge*)(ci->first);
ents.clear();
senses.clear();
for (SenseEntity* ce = edge->get_first_sense_entity_ptr();
ce; ce = ce->next_on_bte()) {
BasicTopologyEntity* fac = ce->get_parent_basic_topology_entity_ptr();
- EntityHandle face = entitymap[2][fac];
+ EntityHandle face = surface_map[fac];
if (ce->get_sense() == CUBIT_UNKNOWN ||
ce->get_sense() != edge->get_curve_ptr()->bridge_sense()) {
ents.push_back(face);
@@ -835,11 +837,11 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
- rval = store_surface_senses( entmap );
+ rval = store_surface_senses( entmap[2], entmap[3] );
// store CoEdge senses
- rval = store_curve_senses( entmap );
+ rval = store_curve_senses( entmap[1], entmap[2] );
index 83fc8b5..21dc386 100644
@@ -91,9 +91,11 @@ private:
- ErrorCode store_surface_senses( std::map<RefEntity*,EntityHandle> (&entitymap)[5] );
+ ErrorCode store_surface_senses( std::map<RefEntity*,EntityHandle>& surface_map,
+ std::map<RefEntity*,EntityHandle>& volume_map );
- ErrorCode store_curve_senses( std::map<RefEntity*,EntityHandle> (&entitymap)[5] );
+ ErrorCode store_curve_senses( std::map<RefEntity*,EntityHandle>& curve_map,
+ std::map<RefEntity*,EntityHandle>& surface_map );
https://bitbucket.org/fathomteam/moab/commits/afabd70a8c36/
Changeset: afabd70a8c36
Branch: master
User: pshriwise
Date: 2014-06-27 23:30:35
Summary: Updated faceting functions to use two distinct entitymaps for readability.
Affected #: 2 files
index c1b3f2a..28c4986 100644
@@ -330,7 +330,7 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
return MB_SUCCESS;
-ErrorCode ReadCGM::create_group_entsets( std::map<RefEntity*,EntityHandle>& entitymap )
+ErrorCode ReadCGM::create_group_entsets( std::map<RefEntity*,EntityHandle>& group_map )
ErrorCode rval;
@@ -421,7 +421,7 @@ ErrorCode ReadCGM::create_group_entsets( std::map<RefEntity*,EntityHandle>& enti
//add the group handle
- entitymap[grp] = h;
+ group_map[grp] = h;
return MB_SUCCESS;
@@ -504,12 +504,12 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
- ErrorCode ReadCGM::create_vertices( std::map<RefEntity*,EntityHandle> &entitymap )
+ ErrorCode ReadCGM::create_vertices( std::map<RefEntity*,EntityHandle> &vertex_map )
ErrorCode rval;
- for (ci = entitymap.begin(); ci != entitymap.end(); ++ci) {
+ for (ci = vertex_map.begin(); ci != vertex_map.end(); ++ci) {
EntityHandle vh;
@@ -530,7 +530,8 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
return MB_SUCCESS;
- ErrorCode ReadCGM::create_curve_facets( std::map<RefEntity*,EntityHandle> (&entitymap)[5],
+ ErrorCode ReadCGM::create_curve_facets( std::map<RefEntity*,EntityHandle>& curve_map,
+ std::map<RefEntity*,EntityHandle>& vertex_map,
int norm_tol,
bool verbose_warn )
@@ -548,7 +549,7 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
GMem data;
@@ -586,7 +587,7 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
continue;
- EntityHandle h = entitymap[0][start_vtx];
+ EntityHandle h = vertex_map[start_vtx];
return MB_FAILURE;
@@ -615,7 +616,7 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
- verts.push_back( entitymap[0][start_vtx] );
+ verts.push_back( vertex_map[start_vtx] );
EntityHandle h;
@@ -625,7 +626,7 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
return MB_FAILURE;
- verts.push_back( entitymap[0][end_vtx] );
+ verts.push_back( vertex_map[end_vtx] );
// create edges
@@ -657,7 +658,8 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
return MB_SUCCESS;
- ErrorCode ReadCGM::create_surface_facets( std::map<RefEntity*,EntityHandle> (&entitymap)[5],
+ ErrorCode ReadCGM::create_surface_facets( std::map<RefEntity*,EntityHandle>& surface_map,
int norm_tol,
double facet_tol,
double length_tol )
@@ -669,7 +671,7 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
GMem data;
data.clean_out();
@@ -703,7 +705,7 @@ void ReadCGM::set_cgm_attributes(bool const act_attributes, bool const verbose)
if (verts[j])
- verts[j] = entitymap[0][vtx];
+ verts[j] = vertex_map[vtx];
break;
@@ -857,11 +859,11 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
- rval = create_curve_facets( entmap, norm_tol, faceting_tol, verbose_warnings );
+ rval = create_curve_facets( entmap[1], entmap[0], norm_tol, faceting_tol, verbose_warnings );
- rval = create_surface_facets( entmap, norm_tol, faceting_tol, len_tol);
+ rval = create_surface_facets( entmap[2], entmap[0], norm_tol, faceting_tol, len_tol);
return MB_SUCCESS;
index 21dc386..ce119af 100644
@@ -99,7 +99,7 @@ private:
- ErrorCode create_group_entsets( std::map<RefEntity*,EntityHandle>& entitymap );
+ ErrorCode create_group_entsets( std::map<RefEntity*,EntityHandle>& group_map );
@@ -107,15 +107,17 @@ private:
- ErrorCode create_vertices( std::map<RefEntity*,EntityHandle> &entitymap );
+ ErrorCode create_vertices( std::map<RefEntity*,EntityHandle> &vertex_map );
- ErrorCode create_curve_facets( std::map<RefEntity*,EntityHandle> (&entitymap)[5],
+ ErrorCode create_curve_facets( std::map<RefEntity*,EntityHandle>& curve_map,
int norm_tol,
- ErrorCode create_surface_facets( std::map<RefEntity*,EntityHandle> (&entitymap)[5],
+ ErrorCode create_surface_facets( std::map<RefEntity*,EntityHandle>& surface_map,
int norm_tol,
double facet_tol,
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
